Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old Aug 12, 2011 | 12:20 AM
  #231
bandroidx's Avatar
bandroidx
am i correct in understanding that 4 x 50 watt resistors would be wasting 200 watts at all time from the electrical system?
I am guessing if it does waste 200+ watts that it isnt enough to care about?
Old Aug 12, 2011 | 07:52 AM
  #232
weedahoe's Avatar
weedahoe
Hall of Fame Member
That is correct but you still arent really losing anything because you were using that same amount of power when you had OEM bulbs. So essentially, you are neither gaining or losing.
Old Aug 14, 2011 | 10:00 PM
  #233
Ben D.'s Avatar
Ben D.
keep in mind only your high beam or low beams are on at one time... so that 200 watts can be cut in half..
also those resistors you buy are rated for 50 watts each.. that is not what they actually consume. If you do the math a 6 ohm resistor burns approximately 35 watts of power running on a circuit at 14.4v... so really at one time your resistors are eating about 70 watts of power and your HIDS while on are only pulling maybe 4 amps each after they start up.. so in the long run your not putting any extra load on the vehicles electrical system... maybe by 10-20 watts but that's nothing.
Old Aug 15, 2011 | 09:19 PM
  #234
pousaan's Avatar
pousaan
I hooked up both my HID kits today. The 9008 (H13) Bixenon kit and my 9006 Xenon kit in my 2007 Dodge Ram.
When I turn on my fog's and low beams, everything works fine. But when I turn my hi-beams on, the actuators on the lights don't change, they just flutter for a split second. I wired in the 50 watt resistors as I was told. Then when I go back to my low beam's, sometimes all the lights do not come back on. I usually only get 1 head and 1 fog, both on opposite sides. Does anyone know why this is happening?
Also, I live in Canada and I have DRL's that are on whenever my truck is moving, no matter if I have my headlights on or not. Does this matter?
If you could help me out it would be greatly appreciated.
Old Aug 17, 2011 | 11:10 AM
  #235
pousaan's Avatar
pousaan
No one has any suggestions or can offer any help? I thought the reason for this sticky was to post problems. I would have posted a new topic but I know shouldn't.
Old Aug 17, 2011 | 11:46 AM
  #236
weedahoe's Avatar
weedahoe
Hall of Fame Member
Drls always screw with hids. Does your truck have a wire for drls and then two more for low and high beam? Or is the drl wire the same as low beam?
Old Aug 17, 2011 | 11:55 AM
  #237
pousaan's Avatar
pousaan
My headlights are H13 (9008) and they are a 3 wire plug. I am pretty sure that the DRL's are on the high side.
Old Aug 17, 2011 | 01:16 PM
  #238
weedahoe's Avatar
weedahoe
Hall of Fame Member
One wire is low beam. One is high beam and the other is ground. You can take a meter or test light and probe to see where the low voltage drl is at.
Old Aug 17, 2011 | 01:25 PM
  #239
pousaan's Avatar
pousaan
I just verified its on the high side (hi beam)
Old Aug 17, 2011 | 01:51 PM
  #240
weedahoe's Avatar
weedahoe
Hall of Fame Member
drls have always been an issue for our canadian friends. seems your may be no different. however, with the engine off but the key on, see if you can duplicate the issue. lastly, try disconnecting the high beam wire fro the oem headlight sockets and see how the lights perform
