Old Aug 5, 2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
Got *HID* Problems? Check in here...
Old Aug 1, 2014 | 10:01 AM
  #721
FreezLe223's Avatar
FreezLe223
i DONT use any connectors from my projectors all i did was put a h1 hid in and install a relay with it wich a relay only uses one of the factory headlight plugs to turn on the hids...so therefor how would the resistors even work for me when i dont use the projector harness and only use 1 factory h13 light connector.
Old Aug 1, 2014 | 10:05 AM
  #722
weedahoe's Avatar
weedahoe
Hall of Fame Member
Did you read on the first page why you need the load resistors and what they do?
Your connections, connectors and relay(s) have nothingto do with it.
You are over complicating it. If you don't want to use a pre-made PnP load resistor harness then just buy the load resistors and wire them in place
Your other mistake is using cheap eBay projectors designed for halogens and trying to install HIDs in them. There are a lot of threads here about that also. Your light output is going to suck compared to actual HID projectors designed for HIDs.
  #723
weedahoe's Avatar
weedahoe
Hall of Fame Member
Old Aug 1, 2014 | 10:13 AM
  #724
FreezLe223's Avatar
FreezLe223
Better then putting HIDS into a regular housing of a headlight thats not even ment for HID and you blind everyone oncoming to you... AND i have read all the things u keep posting but u still have yet to tell me how resistors wire into a hid kit with a single beam wiring harness..and single beam hid kit.
Old Aug 1, 2014 | 10:18 AM
  #725
weedahoe's Avatar
weedahoe
Hall of Fame Member
Halogen projectors with HIDs still will blind because you don't have internal cut off shields which lower the level of light output on the left hand side where on coming traffic is at.
Reading the first page answers everything. Not sure why you are against reading, specifically Post #2, last paragraph.
Old Aug 1, 2014 | 10:28 AM
  #726
FreezLe223's Avatar
FreezLe223
I am not against reading i am simply from africa learning english as we speak! i was adopeted by a loving family after 6 long years of segregation and depression. i might not be the brightest on the block sir but i am trying to learn! Now i went on ebay and i looked for resistors for single beam hid kit and i found these reistors will they work since i am only using low beam HIDs and halogens in Highs
http://www.ebay.com/itm/2-X-Car-HID-Xenon-Stop-Flicker-Canbus-Warning-Canceller-Decoder-Resistor-H13-/221309498879?pt=Motors_Car_Truck_Parts_Accessories&hash=item338712f5ff&vxp=mtr
Old Aug 1, 2014 | 10:32 AM
  #727
FreezLe223's Avatar
FreezLe223
i just find it funny how my friends 05 dodge ram 2500 5.9L has a lamp out feature but my 2006 dodge ram 2500 5.9L dosnt. weird...(scratching head)
  #728
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you can write it then you can read it and you are doing a great job at writing. Your language skills, grammar and punctuation are better than most here. LoL
Those PnP harnesses will work fine for you.
Old Aug 1, 2014 | 10:33 AM
  #729
weedahoe's Avatar
weedahoe
Hall of Fame Member
Maybe the bulb in the dash is burnt out.
Old Aug 1, 2014 | 10:38 AM
  #730
FreezLe223's Avatar
FreezLe223
i just hook them black wires from the resistors to a negative or ground correct? and the flickering i am having should be fixed?
