2001 Dodge B3500 van mystery battery drain
Old 08-22-2022, 12:34 PM
jimneill's Avatar
jimneill
jimneill is offline
Default 2001 Dodge B3500 van mystery battery drain
Mystery battery drain. Battery is NEW. I did parasitic drain check.....attached multimeter in series to battery NEG. .Multimeter reads 0 drain.
Did fuse voltage loss check...all circuits good. NOTHING electrical is on in van. Battery drains to about 7 volts in 3-4 days. WHAT CAUSING THIS?????
Old 08-22-2022, 01:29 PM
Busted Nuckles's Avatar
Busted Nuckles
Busted Nuckles is offline
"Attached multimeter in series to battery NEG"
Maybe I am wrong but I do not think you tested amp flow correctly using your meter. Do you get a slight arc when you touch the battery cable terminal back onto the battery?
I would try to pull the fuses one at a time, while monitoring the amp flow to isolate the faulty circuit and go from there.
Old 08-22-2022, 06:05 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,266 Likes on 3,013 Posts
Yeah, gotta measure amp draw on the positive cable.
Old 08-22-2022, 09:48 PM
jimneill's Avatar
jimneill
jimneill is offline
Thanks for your reply.
Yes I get a small arc when attaching NEG cable back onto NEG battery post.
Did the fuse check and every circuit checks out OK. Still a mystery ????
Old 08-23-2022, 05:30 AM
Busted Nuckles
Glove box light? Alarm system? I would also disconnect the alternator and check for drain.
Old 08-23-2022, 06:48 AM
Moparite's Avatar
Moparite
Moparite is offline
Meter needs to be set on milivolts.
Old 08-23-2022, 09:57 AM
jimneill's Avatar
jimneill
jimneill is offline
Thanks for your reply. You suggest I set meter at millivolts...yet the uTube you attached clearly shows meter set at AMPS....which I did. Confused !
Old 08-23-2022, 10:34 AM
HeyYou is offline
Should be set for milliamps. Do NOT turn the key on while testing. The meter isn't designed for much more than about 10 milliamps...... you'll smoke it right quick.
Old 08-23-2022, 10:33 PM
jimneill's Avatar
jimneill
jimneill is offline
Can't pull the fuses one at a time, while monitoring the amp flowt because I have ZERO amp flow reading on my meter !
Old 08-24-2022, 12:10 AM
Busted Nuckles
Send us a pic of your meter set where you are testing. Something doesnt sound right. Do you have another meter?
Quick Reply: 2001 Dodge B3500 van mystery battery drain
