Any interest here in better mpg mods?
Old Dec 4, 2021 | 10:07 AM
  #161
The Rivian is over 100K. I haven't spent that much money on EVERY vehicle I have ever owned, and you can throw my house in on top of that, and STILL not hit 100K.
Old Dec 4, 2021 | 10:13 AM
  #162
V8Cowboy's Avatar
V8Cowboy
Oops.... i might have the money in about hundred years or so.....
Old Dec 4, 2021 | 11:01 AM
  #163
Yeah, me too, but only if I can keep working.
Old Dec 4, 2021 | 06:44 PM
  #164
steve05ram360's Avatar
steve05ram360
Brakes fixed... problem was a pad failed, new pads in, did not swap rotors since I am going to an '03 setup. And... brakes are dragging so I expect mpg's do drop. sigh... well at least I can park the ram again.
I have decided to go to the newer setup, will get the steering knuckles and all new parts after that. Looking on rockauto.com it appears that the bearings I just bought should swap over. Is there any gotcha's I need to be aware of?
Old Dec 5, 2021 | 08:01 AM
  #165
V8Cowboy's Avatar
V8Cowboy
[QUOTE=steve05ram360;Is there any gotcha's I need to be aware of?[/QUOTE]
Only things you should check after dismanteling or order new parts are :
The threads on the brake lines, but should be the same.
The taper sides of the baljoints, but they should be the same, same on the tie rod side.
I know you will order those all new anyway, at least it's recommended, get it all done and you have a complete new front end.
You have to have at least the 16" rims for the upgrade, but you do, so no problem on this end.
And last and most important, on the new spindle the brake caliper bracket will mount a little bit more to the outside, and it's most likely you're brake caliper is grinding inside the rim.
You have to grind a little of the caliper as i understand, some have no problems others have to grind it down a bit.
I have no experience on it just yet, but i should take a closer look at the bracket and see if i could make a shim plate to get it mounted completely a bit more to the inside, instead of grinding off some material to clear the rim.
Good luck and i am looking forward to here you're results and improvement on the brake performance.
Old Dec 5, 2021 | 05:22 PM
  #166
steve05ram360
....And the DS caliper is sticking... going to see if I can exercise it and free it up... I dont want to dump $ into the current setup so hoping this attempt works.
Old Dec 5, 2021 | 07:55 PM
  #167
Is it the caliper, or is it the soft line?
Jack it up, take off the wheel/tire, pump the brakes a couple times to get the caliper to 'set', then, crack open the bleeder. If the caliper releases nicely, then the soft line is bad. Not the caliper.
Old Dec 6, 2021 | 09:38 AM
  #168
steve05ram360
When I first got it in the garage and in the air, the caliper released over time, 1x. Now the caliper never releases...
I think I'm going to go get a Pick & Pull caliper and go that route since they are cheap and there are a few in the yard. I need the truck up and going the upgraded brake route requires time I dont really have atm...
Old Dec 6, 2021 | 09:45 PM
  #169
steve05ram360
ok the dak is bak... this tank will he off a bit, 20ish miles with dragging brake
Old Dec 8, 2021 | 10:08 AM
  #170
steve05ram360
I heard back from Airaid on the intake tube install problem... they mention that I may not have had the clamp oriented correctly which will cause the coupler to not install. Going to check this tonight.
