Old Jan 31, 2014 | 08:54 PM
  #13341
Dieselweasle's Avatar
Dieselweasle
Removed my passenger headlight bulb, since the running light and highbeam weren't working, to find that neither of the filaments were burnt out, put it back in and wiggled the connections and it came back on no problem.
Also, checked the front and rear diff fluid. Both clean and full. Then moved to break both of the O2 sensors free, no problems there, then moved to check the transmission... Wth is that? What do I use to remove the fill and drain plugs? A 1" ratchet won't fit, too small and threads on the outside, so not much to grip.
Old Jan 31, 2014 | 08:57 PM
  #13342
snowboundrmk's Avatar
snowboundrmk
Replaced the map sensor.
Old Jan 31, 2014 | 09:38 PM
  #13343
Spillage's Avatar
Spillage
Well, that 93 Octane & tune does seem to be a nice improvement... and it's only an additional $7 a tank.
Old Feb 1, 2014 | 10:32 AM
  #13344
Just a pipe plug screwed into the side of the trans isn't it? 1" is too SMALL??? Gotta pic?
Old Feb 1, 2014 | 11:53 AM
  #13345
Dieselweasle
Googled it and it's a giant allen key. Supposedly 17mm, but that's a little bigger than 1/2"
Going to shop around for something today.
Also, bought a jug of Valvoline Synthetic for $10, last one at Walmart and a 2 3/8" Tachometer. Installing after my coffee
Old Feb 1, 2014 | 02:48 PM
  #13346
Ham Bone's Avatar
Ham Bone
Put a starter on it. Still doesn't start.....
Old Feb 1, 2014 | 09:41 PM
  #13347
snowboundrmk
Applied some fluid film and put in my rear fender liners.
Old Feb 2, 2014 | 01:38 PM
  #13348
Johnn123's Avatar
Johnn123
Goin to push the mountain the mountain of snow off it in a bit.
Old Feb 2, 2014 | 01:41 PM
  #13349
trail3n's Avatar
trail3n
I changed out sway bar link ends, track bar bushing, sway bar bushings, and tie rod ends with energy suspension products as well as replaced my radiator, hoses, belt tensioner, serpentine belt and thermostat.
Sorry for some reason it makes you open pictures on a new page, there nothing special.
Old Feb 3, 2014 | 11:59 PM
  #13350
dman12323's Avatar
dman12323
Well used my Ram today to save my friend on the mountain. He has a bagged s10 and somehow the rear axle control arm became unwelded and ripped apart the axle shafts. There was axle lube and diff lube all over the ground. We even tried moving it off to the side of the road but eventually the driveshaft came lose from the tranny and fail. Oh well another attempt tomorrow to rescue the s10 again...
