Old Mar 24, 2014 | 03:52 PM
  #13611
rollinlow's Avatar
rollinlow
friday night door pins driver and pass
sat timing chain, water pump
today alternator
and none of it was planned a head of time
Old Mar 24, 2014 | 06:07 PM
  #13612
vandezande1's Avatar
vandezande1
Smile AirFlow
added a new airaid today should get better air flow and mpg's plus hp.just waiting for the tank to go empty to see the results.
Old Mar 24, 2014 | 06:10 PM
  #13613
Johnn123's Avatar
Johnn123
What? That makes no sense?
Today I yelled at my ram, wont hold an idle now. Idles fine cold, when its warm it intermittently will drop the rpms down, start bucking and pinging, then rev right up. CEL is on, but is all for o2 sensor codes ive had awhile now and cant seem to clear them.
Old Mar 24, 2014 | 09:41 PM
  #13614
Unplug the front O2 sensor, and drive it that way for a bit, see if the idle issues clear up.
Old Mar 24, 2014 | 09:55 PM
  #13615
topkin's Avatar
topkin
Check my TV cable for correct alignment, It was off a bit so I adjusted it. Fixed the 100-300rpm climb between some shifts.
I love the feeling of fixing the small things.
Old Mar 24, 2014 | 10:23 PM
  #13616
redneck_ram's Avatar
redneck_ram
Drove it more than just around the yard for the first time in about 3-4 weeks. Felt good to be sitting up high again.
jeep is at my buddys shop having the pass inner rocker replaced.
Old Mar 25, 2014 | 10:27 AM
  #13617
Wh1t3NuKle's Avatar
Wh1t3NuKle
Jeep?
Are you going to sell the Ram?
Old Mar 25, 2014 | 05:01 PM
  #13618
Johnn123's Avatar
Johnn123
Hadnt thought to do that yet, will try that! Id be surprised if it was clogged though, brand new last january. But stranger things have happened I suppose.
Old Mar 25, 2014 | 05:20 PM
  #13619
tincan57's Avatar
tincan57
Picked up a used unscratched Dodge Ram tailgate for the diesel from Salvage $160.
Wrong color, but going to switch it with the black farm truck. K.
Old Mar 25, 2014 | 06:31 PM
  #13620
That will just test the O2 sensor, to test the cat, you would have to physically remove the sensor from the exhaust.
