Old Aug 26, 2019 | 10:22 PM
  #16301
ranjanty's Avatar
ranjanty
Default New Ram owner
I replaced the power steering pump and new hoses. Also rebuilt the vacuum pump with a Kit from Geno's Garage. I also replaced the AC compressor Dryer and high Pressure line.
99 2500 5 speed Trans. But not in one day!
Old Aug 31, 2019 | 10:17 PM
  #16302
1997DodgeRam's Avatar
1997DodgeRam
Filled it up with gas and figured out after changing my timing chain I averaged a full MPG better this tank of gas over the same roads on my commute as the past year. For some reason 12.6 seems so much better than 11.6
Now if I want to feel better I can factor in the uncalibrated odometer with the larger tires and the ethanol that wasn’t in the gas in 97 and it really isn’t much worse now than it was new.
Old Sep 13, 2019 | 08:22 PM
  #16303
pershingd's Avatar
pershingd
It's in the shop getting a bunch of steering components and a ball joint replaced so it can be properly aligned and stop eating tires. Oh yeah - it's getting those too. There goes this paycheck...
Yeah - I could do most of the parts replacement myself, but 1 ton suspension parts beat the crap out of me anymore.
Old Sep 14, 2019 | 08:31 AM
  #16304
I wish I could do some front end work, and replace my tires, on one paycheck.
Old Sep 14, 2019 | 09:02 AM
  #16305
pershingd's Avatar
pershingd
Well - nothing else is getting done that's for sure. Fortunately I have reserves to dip into, but certainly took a huge chunk of it.
Old Sep 15, 2019 | 01:36 PM
  #16306
pershingd's Avatar
pershingd
Truck came home yesterday with new rubber and an alignment. It only took a new pitman arm, idler arm, tie rod, and steering stabilizer to get there. Funny, between the tires and alignment I never realized just how bad our local roads have become. Sheesh...
Old Sep 15, 2019 | 02:23 PM
  #16307
You think you have it bad? Our potholes might have some road around them.....
Old Sep 15, 2019 | 03:32 PM
  #16308
pershingd's Avatar
pershingd
I drove some of the roads in southern Michigan years ago and you are quite correct. Between the winter rust and the potholes, I was surprised there wasn't more than random mufflers and tailpipes hanging around at the side of the road.
Missouri's problem is that they have some of the lowest fuel taxes in the country so they don't generate enough money to properly maintain the roads & bridges. The roads that get the most attention are usually the ones that are around the major metropolitan areas so us country bumpkins just have to make do.
Old Sep 15, 2019 | 07:45 PM
  #16309
Spillage's Avatar
Spillage
Do you remember this one?
Old Sep 16, 2019 | 06:33 PM
  #16310
2bit's Avatar
2bit
If the raise the fuel tax, they'll **** it away and still not fix the roads. Then they'll raise the tax again, over and over.
