Dana 60 Swap!
Old Dec 29, 2013 | 08:30 PM
  #221
redneck_ram's Avatar
redneck_ram
Originally Posted by Ham Bone
Got a the u joints done. Those c clips fought to the bitter end.
Truck could be driving tomorrow! Just gotta rent/find/buy a half inch drive torque wrench and I'll be all set!
You can borrow mine! You have to come get it though... hahahahaha
Old Dec 29, 2013 | 08:52 PM
  #222
Ham Bone's Avatar
Ham Bone
I'm on my way! I'll mail it back after I'm done hahahaha
Old Dec 30, 2013 | 12:33 PM
  #223
Ham Bone's Avatar
Ham Bone
Is that enough clearance?
Old Dec 30, 2013 | 12:55 PM
  #224
Yeah, no problem. The steering box isn't going to move, so, it will never get any closer there. You are golden.
Old Dec 30, 2013 | 01:48 PM
  #225
Ham Bone's Avatar
Ham Bone
Ok just wanted to make sure
One side is ready to have a wheel mounted!
I gotta find one wheel bearing bolt though one I have is unusable, and it's really setting me back
Old Dec 30, 2013 | 04:02 PM
  #226
Ham Bone's Avatar
Ham Bone
We'll had a minor setback today. Wheel bearing bolt won't be here till Thursday!
But oh we'll. passenger side is ready to be bled then it's ready to go. Shocks and everything are in. Sway bar, cool springs control arms all that jazz.
I should be rolling Thursday
Axle nuts are torqued to 175 ft lbs correct?
Old Dec 30, 2013 | 04:14 PM
  #227
merc225hp's Avatar
merc225hp
Yep. So is the back end done as well?
From the 2001 FSM
(4) Install hub bearing bolts and tighten to 170 N·m (125 ft. lbs.).
(5) Install axle washer and nut, tighten nut to 237 N·m (175 ft. lbs.).
Old Dec 30, 2013 | 04:16 PM
  #228
Ham Bone's Avatar
Ham Bone
Ok that's what I have. Just wanted to make sure I wasn't reading things wrong.
Thanks.
Looks more and more like my steering setup is sh*t
Haven't started back end yet. It should go much smoother tho. Just have to get those little 2.5 hangars offf. Grade 8 bolts back in with the big hangars. Then just roll the rear axle in
Old Dec 30, 2013 | 04:24 PM
  #229
merc225hp's Avatar
merc225hp
Thanks.
It's always great to double check what you are up to if needed good on your behalf.
Np anytime
Idk what to say about that steering other that I will not be going that route now, but hey thats just one guys op.
Old Dec 30, 2013 | 04:29 PM
  #230
Ham Bone's Avatar
Ham Bone
Idk either. I will have to run it at least for a while because I don't have any other options. And I can't afford to buy a whole other setup. I didn't take the 2500 steering from the truck. It looked like junk anyway.
y-steering sucks but at least the tre didn't snap off.
Know of any aftermarket tre? Moog or anything like that?
I thought Chrysler wasn't actually replacing anything until after Jan 1st. So maybe I have something different. Idk anymore.
