When i press on gas engine slows then revs up
Old Oct 17, 2021 | 12:30 PM
  #71
Eddy67's Avatar
Eddy67
So plug everything back in and just have ignition on or have it running?
Old Oct 17, 2021 | 12:34 PM
  #72
Ignition on will be sufficient.
Old Oct 17, 2021 | 01:36 PM
  #73
Eddy67's Avatar
Eddy67
I thought I would send you all three pages worth, I am not sure any of this will help.
Old Oct 17, 2021 | 09:55 PM
  #74
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Is that engine off? If so your TPS sensor is bad because it should be at zero
Old Oct 18, 2021 | 07:31 AM
  #75
Eddy67's Avatar
Eddy67
Yes engine is off
I don't know if you read all of this thread it is getting kinda long. My PCM is outputting more than 5 volts through the power wire AND signal wire to the TPS, the signal wire shouldn't be putting out power, this may be making a mess of what the hand held unit is reading
Can I go to the scrap yard and get a used PCM to try or is it not that simple?
Old Oct 18, 2021 | 10:05 AM
  #76
I am unsure if TPS should be zero..... It's not showing better than 80%, which is what I would expect to see if the return wire was at 5 volts as well..... I know on GM cars, so long as TPS voltage was correct, (right about .54 volts at closed throttle) everything was good. I don't recall what my truck told me throttle % was last time I plugged into it.
What year is your truck? If its 97 or older, you can just swap the PCM, and call it a day. 98 or newer, and it will have to be flashed to the correct VIN, else the ABS and SRS systems get upset.
Old Oct 18, 2021 | 10:15 AM
  #77
Eddy67's Avatar
Eddy67
Shoot its a 2003, that will complicate things, I did find this on ebay,
https://www.ebay.com/itm/32412981310...kAAOSwZ4dZJeAz
Do you think its worth a try?
Old Oct 18, 2021 | 10:17 AM
  #78
That assumes there is something wrong with yours....... I am not entirely sure that is the case. Even though the voltages you are measuring are odd, the PCM still seems to be getting the correct info....
Old Oct 18, 2021 | 10:40 AM
  #79
Eddy67's Avatar
Eddy67
Is there anything else to try first? It still doesn't make sense I am seeing 5 volts on the signal wire
Old Oct 18, 2021 | 10:51 AM
  #80
I completely agree. That just ain't right. With the scanner plugged in, showing TPS %, slowly press the pedal to the floor, and watch what that number does. It should increase smoothly, no jumping around at all.
