End-all Be-all plenum thread
Old Sep 2, 2020 | 04:28 PM
  #1121
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Aubrey Leech
these links are no longer active does anyone know where to look for the proper parts now days?
When you buy the aluminum plate from Hughes they give you everything. You can get the gasket kit from RockAuto
Old Sep 2, 2020 | 06:11 PM
  #1122
Hughes Kit.
Old Sep 7, 2020 | 08:04 PM
  #1123
tdvs38's Avatar
tdvs38
Default Plentum
I had my plentum replaced and still have the oil consumption. Is it possible the gaskets were misaligned while they put it back together ? Getting tired of pouring money in this truck to no avail. 2001 dodge ram 5.9 4x4. I used the hues kit.
Old Sep 7, 2020 | 08:09 PM
  #1124
Check manifold vacuum at idle, see what ya get. Should be around 20" hg.
Old Sep 7, 2020 | 09:44 PM
  #1125
dog dodge's Avatar
dog dodge
im no mechanic but had the oil burning issue and did plenum to no avail . the next oil burning possibility im looking into is some rings got carboned up and are stuck . so they say remove plugs and pour like an ounce , dont quote me on amount , of marvs mystery oil into each cylinder and let it sit like 12 / 24 hours to get down into rings in effort to free them . then you pump out the oil fromeach cylinder .
Old Nov 23, 2020 | 12:35 PM
  #1126
Mick M's Avatar
Mick M
Default Plenum/intake???
This is the first time I have used a forum, so if I break protocol or such please let me know. That being said I have a 2001 Ram 1500 4x4 5.9 Magnum. Runs terrible,carbon fouls plugs. Removed precat 02 sensor no change. Keeps throwing random injector open circuit faults. It actually runs better with all vacumn lines unhooked. I put a new PCM in and no change. Checked all the grounds, did the spray around the intake trick to see if it was leaking and no change. I'm lost and at a loss. I would appreciate any kind of help.
Thanks
Mick M
Old Nov 23, 2020 | 06:16 PM
  #1127
Thanks
Mick M
Need to start your own thread. You are in the right spot at least, just the wrong thread. Just click the "New Thread" button, fill in the fields, and we can go from there.
Old Nov 28, 2020 | 12:13 PM
  #1128
kfd518's Avatar
kfd518
Default Lake of oil.
Well I have my new water pump, fan clutch, cloyes double roller set, timing cover gasket set coming.
I also ordered the Hughes felpro plenum Kit. I also got the stuff for a tuneup including 3923 plugs while I’m at it. Mileage is around 11.3 no load combined in town and highway. 10.6 with travel trailer mostly highway in direct drive OD off.
I have a lake of oil in my intake, it has certainly gotten much worse than it was. Currently 188k on it.
I will update here after repairs are done
Phone camera doesn’t catch it well but there is much more oil than it appears in the photo.
Old Nov 29, 2020 | 09:38 AM
  #1129
Yeah, that one is blown. May wanna consider replacing the O2 sensor as well.
Old Nov 29, 2020 | 10:19 AM
  #1130
kfd518's Avatar
kfd518
with all I’ve spent already including getting as many discounts as I can it’s not in the budget at the moment. $427 on parts.(bought a few more than what are mentioned above.) $325 on tires.
I have a feeling cat and O2 sensors are in the near future as well, and I KNOW a new heater core is in the near future.
