idle loops
Old Jun 16, 2018 | 05:29 PM
  #31
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Eman2004
Could my distributor be bad? I picked up one from the junk yard, but I heard you have to do a fuel resync
Did you pull the whole distributor?
Old Jun 16, 2018 | 05:40 PM
  #32
Eman2004's Avatar
Eman2004
No I haven’t pulled the distributer or even lossened it, but (TDC) seems odd to me. I feel it is a couple of degree off of TDC but I don’t know if I’m reading it wrong or the chain is stretched. It has 305k and still kicking, but boy this is kicking my butt
Old Jun 16, 2018 | 08:02 PM
  #33
How old is the timing chain?
Old Jun 16, 2018 | 08:26 PM
  #34
2bit's Avatar
2bit
And is your Cat clogged? Your distributor could be worn out with all those miles. I don't remember if we asked about the plenum gasket. I guess I'd start with testing the circuit and the PCM first though. That and clean all of your ground cables and wires.
Old Jun 16, 2018 | 08:30 PM
  #35
Eman2004's Avatar
Eman2004
I believe the chain is originally, but compression is good. Probably a good time to change it either way. I will check the PCM circuit and report back
Old Jun 16, 2018 | 08:47 PM
  #36
2bit's Avatar
2bit
Put the engine on TDC and have someone watch the distributor rotor. Turn the engine backwards and see how far it moves before the rotor starts moving.
Old Jun 16, 2018 | 09:33 PM
  #37
Eman2004's Avatar
Eman2004
Ok, I will try this tomorrow, thanks for all the help so far guys!
here is a picture of an ignition coil, causing a weak spark! Reset PCM, but still no good
Old Jun 16, 2018 | 10:19 PM
  #38
2bit's Avatar
2bit
Originally Posted by racefan41
i'm not thinking the coil would fix the code, but i'm wondering if you have more than one issue going on. I've heard bad cam/crank sensors can burn up a coil.
He ^^^^ was right about multiple issues. I'm surprised it ran at all with the broken case on the coil.
Old Jun 17, 2018 | 12:26 PM
  #39
racefan41's Avatar
racefan41
Dang, well i guess you don't need to get the ohmmeter out for that one. ^ I'm surprised that was running too, or at least throwing some random misfire code. I would get one from the dealer and be done with it. The part store ones are junk imo. Some guys might have good experiences with other name brands.that are reliable.
Old Jun 18, 2018 | 02:18 AM
  #40
MoparFanatic21
This almost sounds like a fuel problem (you holding the gas). Check fuel pressure and for injector pulse. You can rent the noid lights from your local auto parts store or Harbor Freight sells them for about $50. Then we can take it from there. How does it run when you punch the pedal? Feel any vibrations? When my 360 Durango did they the crank sensor wire got rubbed and was causing a sorry. You said you are in Virginia where at?
