Superchips Questions and Updates
#3291
What's your Rev Limit and WOT shifts set to?
#3294
Ok so it seems the shift schedule didn't take the first time I did it, when I plugged in the tuner all the stock values were there. Did it all over again. The Hemi is happy. REV is at 6200 WOT 1-2 5900 WOT 2-3 5800. I know I can bump them out more, but that's winding out a little far for my taste. I'm VERY pleased with the outcome! She's kickin ***!
#3296
Check out their site. There are a few different options but all will do the same thing.
#3298
need some advice about performance chips.
I have a 2006 dodge ram 4.7L and i was wondering if it was possible to have 2 different performance chips in it. Right now i have a plug and play chip that hooks up to the OBDII port but i was wanting to put another, say jet performance chip in it aswell. Is this possible?
#3299
When you're just starting to learn this program, sometimes missing the save/exit choice can happen.
A tip for everyone else using the program. It's very important you save/exit along the way and re-check your MPH values entered. In every shift module there's a save feature and when you exit the shift schedule program at the end, there's a save feature as well.
This is the same when setting TM values as well.
#3300
