Drove to and from work like normal, went to coach basketball for my kids team and on the way home got a red GEN light. Voltage was down but came up before I got home. Shut it off started fine again and no light. Guess I will be checking around on alternators and studying up on our electrical systems.
Unfortunately, the voltage regulator is part of the PCM, so, if it fails...... you either need to do some creative wiring to install an external regulator, or, replace the PCM....... Not sure which is the best way to go here..... For my part, if one part of my PCM fails, how much further behind can some more of it be?
have the alternator tested.
Good chance that it will indeed have the death flash.... but, a few of the drawbacks to that don't exist in the 96-97 PCMs. (torque management?)
Your best bet is just to get a PCM locally. That way, if there are any issues, you can walk into the store, and talk to a real person. Being yours is a 97, you shouldn't have to worry about having it flashed to the correct VIN, but, that may happen anyway.... (so, have it handy just in case.)
I think the duralast alternators have a lifetime warranty...... and I haven't really heard any truly bad reports on them..... I have used them in the past, and didn't have trouble. Just make sure you replace the correct part the first time.
Check all the wiring, make sure things are clean and tight, it might be just that simple.
![Smile](https://dodgeforum.com/forum/images/smilies/smile.gif)
on
