Old Oct 26, 2019 | 02:36 PM
  #16321
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Replaced the smog legal Pace Setters gaskets because of the ticking from a leak. I used Remflex header gaskets and new ARP bolts. The gaskets are about 1/4 inch thick and require 20 ft lbs on the bolts. I removed the 4 studs in the center of the manifolds. First getting the corroded nuts off the studs, one flat side of the nut on each turn for 2 of them, #3 and #6. There are a couple of more bolts that required ingenuity to get off the header and reinstall. I also put on a mandrel bent 3" cat back single exhaust with a dual chamber muffler. The cheapies from ebay, $180. Sounds nice.
Old Oct 26, 2019 | 03:04 PM
  #16322
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Have a part# for the ARP bolts?
Old Oct 26, 2019 | 06:52 PM
  #16323
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
ARP # 144-1202 We need 12 bolts and the package comes with 14. These are black with 3/8" 12pt head.
Old Oct 27, 2019 | 11:02 AM
  #16324
MoparFanatic21
Good to know! I'll add it to my book
Old Oct 27, 2019 | 01:24 PM
  #16325
racefan41's Avatar
racefan41
Sanded out the bed and treated with POR-15 getting ready to spray line it. Kinda a PITA and tedious. Probably gonna have to hit it up again with some hand sanding in some spots. Found one rust hole popping through. I know its where the rail sits underneath. Gonna be racing the weather at this point. Taking about snow already.
Old Nov 9, 2019 | 07:21 AM
  #16326
pershingd's Avatar
pershingd
Experienced a first for me last weekend - complete failure of the left front wheel bearings to the point that the bearings are seized to the spindle. I just replaced and repacked the bearings not long after I got the truck so I know how long it's been since they were last serviced. The most perplexing thing about it is that I've been packing wheel bearings for most of my life and, until now, never had one fail like this before. When I popped the dust cover off, it looked as though they was barely any grease in there at all and I'm not cheap with the grease when I do them. A quick inspection of the right side shows everything pretty much as I left it. As much trouble as I had with the "shop" that put the tires on it and messed up the alignment a couple of months ago, I can't help but wonder (and really hate being that suspicious) if the left side didn't get a little help along the way.
After spending a couple of hours trying everything short of a cutting torch to get the rotor off last Sunday, I decided it wasn't worth trying to save the rotor. I ordered new rotors and pads online (needed new ones anyway), picked up new bearings and seals for both sides, and obtained a replacement spindle from a parts yard down the road. I got notification the the rotors will be here today so as soon as the sun is up and things start warming up a little, I'll be out turning wrenches.
Old Nov 9, 2019 | 07:42 PM
  #16327
pershingd's Avatar
pershingd
That there's one heavy chunk of steel...
Old Nov 10, 2019 | 08:46 AM
  #16328
Why yes, yes it is.
They call it a one-ton truck for a reason. Most of the parts weigh a friggin' ton......
Old Nov 10, 2019 | 09:50 AM
  #16329
pershingd's Avatar
pershingd
Ain't that the truth.
I'm back at the parts yard this morning because a stupid rodent ate the intake air temp sensor wiring.
Old Nov 11, 2019 | 07:14 PM
  #16330
1997DodgeRam's Avatar
1997DodgeRam
Changed out the Master Cylinder and got my brakes back and the yellow ABS and red Brake light to go away. Still think I may have a tinny bit of air in there somewhere. Brakes are decent again but I feel they should be better considering a new master cylinder. I bench bled the MC, followed the procedures for the MC connections, ABS lines etc under the hood and now I need to go back around to the four wheels. I'm sure it wont hurt to purge any remaining old fluid left in the lines either.
