Old Jun 16, 2010 | 12:20 PM
  #4001
Sniperinhisname's Avatar
Sniperinhisname
i need to fix my fan. it only blows on defrost. i got ac and heat. just on defrost though
holy crap! 4000th post!
Old Jun 16, 2010 | 01:46 PM
  #4002
Well, the 3000 pounds of dirt on the last round, wasn't enough.... so, off to the pit again this morning, pick up a load, get weighed..... 5200 pounds in the bed. Ouch. Truck still hauled it without complaint.
I need to pressure wash the bed out now though.....
Old Jun 16, 2010 | 02:04 PM
  #4003
dodgeram07's Avatar
dodgeram07
she sit's in the garge till friday got a 11:00 spot to get the front end alignment!!!!!!!
then the truck well be my daily drive again!!!
Old Jun 16, 2010 | 02:51 PM
  #4004
bigtman07's Avatar
bigtman07
Good deal. Glad to hear ya just about got her done.
I took the truck to get siding supplies today. I get to put on vinyl siding woohoo. ANd stopped by the parts store to check on the AC compressor to get my AC back. They said I need compressor oil?? If so what weight and how much??
Old Jun 16, 2010 | 05:19 PM
  #4005
004x41500's Avatar
004x41500
Per AllData for a 00 1500 p/u 5.2
Should be the exact same for you
I saw that you were asking about how much 134a as well
R134a Refrigerant 0.907 Kg (32 oz.)
Refrigerant Oil Type SP-20 PAG
Total System 210 ml (6.2 oz.)
Accumulator 60 ml (2 oz.)
Condenser 30 ml (1 oz.)
Evaporator 60 ml (2 oz.)
Compressor See Note
Note:
When replacing the A/C compressor, drain and measure the amount of oil from the old compressor. Add the equivalent amount of fresh oil to the new compressor.
Old Jun 17, 2010 | 12:41 AM
  #4006
2k10HemiRam's Avatar
2k10HemiRam
Added some coolant to the rad, something told me to look at the overflow tank before going to work and I'm glad I did, it was almost empty. I don't know why I didn't but something told me to check it after I drove late sunday because I heard the heater core gurgle the first couple seconds after I turned it on. I had no idea these trucks coolant system is that huge, used two bottles to fill it up after I drained it and I didn't pull the blocks plugs. And just in cause, no I don't have any leaks, at least not big enough to do that in 3 days.
And I found out how easy I can light my tires up if I step on it while going about 5mph. Scared the crap out of my friend that was driving his chevy right next to me too, it was funny cause he tried it and couldn't, lol.
Also saw someone lose their front right tire while driving through an intersection today. Sucks it happened to them but I knew something was going to happen to it when they passed me while I was dumping my wallet into the tank. Their car sounded like it has all sorts of problems. Everyone was ok too btw.
Old Jun 17, 2010 | 04:17 AM
  #4007
1997DodgeRam's Avatar
1997DodgeRam
I took the truck to get siding supplies today. I get to put on vinyl siding woohoo. And stopped by the parts store to check on the AC compressor to get my AC back. They said I need compressor oil?? If so what weight and how much??
When I changed mine, the compressor I got from Advance Auto last July came prefilled with oil so watch out you don't double it by adding to a pre-filled compressor. Job was really quick/easy, completely confused how estimates on that job were so high.
Old Jun 17, 2010 | 09:54 AM
  #4008
bigtman07's Avatar
bigtman07
Yea i know lots of places like to double the work load. Take off a bunch of crap that isn't needed. And on top of all that their hourly rate is like $100 an hour. So they make lots of extra cash.
Old Jun 17, 2010 | 03:17 PM
  #4009
redheadhunter21's Avatar
redheadhunter21
took my post O2 sensor off and cleaned it, then checked my pads and went to put my lugs back on and one got stuck and cant get it back off because the stud is f'd too
Old Jun 17, 2010 | 04:36 PM
  #4010
Sheriff420's Avatar
Sheriff420
You need to put a little *** into it. Crank it till it breaks man.
What I did today - I replaced that stupid crossover hose on the fuel rail, bled the cooling system and cranked it for the first time since installing the airgap.
