Notices
DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
1st Generation Durango 1998-2003 DIY
Old 01-11-2010, 11:15 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Question 1st Generation Durango 1998-2003 DIY
This thread will be continuously updated.
https://dodgeforum.com/forum/1st-gen...wers-faqs.html
Check back often!
We are not responsible for any mishaps while you are wrenching, knuckle busting, throwing tools, kicking vehicles, stomping, whining, drinking, or possession of you or your rig by any entity....... Always consult a manual before attempting any wrenching and I advise you to stay within your skill set. If you’re expanding your skills, work on the easy stuff 1st to gain skills and the necessary scars on the hands to fall into the "working man/woman" category.
With that said lets open the door.
Starter
Starter Replacement on the 5.9L and 5.2L and Starter Diagnostic Techniques.
https://dodgeforum.com/forum/1st-gen...-and-5-2l.html
https://dodgeforum.com/forum/1st-gen...ng-relays.html
Tires
https://dodgeforum.com/forum/1st-gen...pressures.html
Tire Height
https://dodgeforum.com/forum/1st-gen...8-durango.html
Pressures
Suspension
https://dodgeforum.com/forum/1st-gen...sh-repair.html
4 Wheel Alignments and correct Suspension Height
https://dodgeforum.com/forum/1st-gen...ment-woes.html
Tie Rod Ends
https://dodgeforum.com/forum/1st-gen...ment-help.html
4X4 Suspension Torque specifications
https://dodgeforum.com/forum/1st-gen...durango-2.html
T/S Lift
https://dodgeforum.com/forum/1st-gen...-bar-lift.html
https://dodgeforum.com/forum/1st-gen...-durangos.html
https://dodgeforum.com/forum/1st-gen...-question.html
Exhaust
https://dodgeforum.com/forum/1st-gen...et-exaust.html
2002 Durango Service Manual:
https://dodgeforum.com/forum/1st-gen...ilability.html
Daytime Running Light Module
https://dodgeforum.com/forum/1st-gen...mp-module.html
Custom Cold Air Intake (CIA)
https://dodgeforum.com/forum/1st-gen...m-air-diy.html
https://dodgeforum.com/forum/1st-gen...s-mileage.html
https://dodgeforum.com/forum/1st-gen...ir-intake.html
https://dodgeforum.com/forum/1st-gen...e-ram-air.html
https://dodgeforum.com/forum/1st-gen...-for-5-2s.html
Kegger Intake Mod Thread (2nd Gen Ram Thread)
https://dodgeforum.com/m_1162946/tm.htm
Cleaning Throttle body & IAC
5.2L and 5.9L
https://dodgeforum.com/forum/1st-gen...ttle-body.html
Alternators
Alternators and Alternating Current.
https://dodgeforum.com/forum/1st-gen...questions.html
Direct Link to Download a 2002 Durango Service Manual
http://www.mediafire.com/?2cg2hgim2zz
Seat Fix
Free Heated Seat Fix
https://dodgeforum.com/forum/1st-gen...-seat-fix.html
Sliding Seats
https://dodgeforum.com/forum/1st-gen...eat-issue.html
Power Window Motor Repair
https://dodgeforum.com/forum/1st-gen...ean-green.html
https://dodgeforum.com/forum/diy-do-it-yourself/86079-power-window-motor-repair-durango-1st-gen-by-mean-green.html
Durango Stuck in park(usually in the cold)
https://dodgeforum.com/forum/1st-gen...k-in-park.html
Wiper Conversion Gen 1 to Gen 2
http://www.durangoclub.com/forum/viewtopic.php?t=3593
Emissions 101
https://dodgeforum.com/forum/1st-gen...ode-p0441.html
Fan Motor Blower Resistor Fix
https://dodgeforum.com/forum/1st-gen...er-switch.html
1998-2000
https://dodgeforum.com/forum/1st-gen...istor-fix.html
https://dodgeforum.com/forum/1st-gen...r-problem.html
2001-2003
ATF+3 and ATF+4 Fluid Facts
https://dodgeforum.com/forum/1st-gen...f-4-facts.html
Talk on Oil
https://dodgeforum.com/forum/1st-gen...nions-mmo.html
https://dodgeforum.com/forum/1st-gen...d-battery.html
Speed Sensor/ABS Sensor Replacement
https://dodgeforum.com/forum/1st-gen...ensor-diy.html
Transmission Output Sensors
https://dodgeforum.com/forum/1st-gen...abs-light.html
https://dodgeforum.com/forum/1st-gen...ight-help.html
Replacement of Trans 3-4 Shift Solenoid
Solenoid Replacement and Location:
Transfer Case
Axle bind causing T-case to stay engaged:
https://dodgeforum.com/forum/1st-gen...ow-hi-awd.html
Transfer Case Control Module (TCCM) 2000-2003 only!
https://dodgeforum.com/forum/1st-gen...tion-tccm.html
Rust
https://dodgeforum.com/forum/1st-gen...rust-spot.html
Tune Up
5.2L and 5.9L including Performance (Cap/Rotor and Plugs)
https://dodgeforum.com/forum/1st-gen...-ignition.html
https://dodgeforum.com/forum/1st-gen...hange-out.html
https://dodgeforum.com/forum/1st-gen...-plugs-ok.html
(How to read spark plugs)
https://dodgeforum.com/forum/1st-gen...ml#post2030778
Differential
Rebuild For Trac-Lok Limited Slip Differential
https://dodgeforum.com/forum/1st-gen...c-lok-lsd.html
https://dodgeforum.com/forum/1st-gen...lp-please.html
http://www2.dana.com/pdf/X5001-CVSP.pdf
46RE Transmission Rebuild
https://dodgeforum.com/forum/1st-gen...d-for-now.html
45RFE/545FRE Transmissions
http://www.hotrodlane.cc/New%20HEMI%...mi%20trans.pdf
Tips and Tricks PDF
http://bionicdodge.com/Download/Spee...d%20Tricks.pdf
Thermostat and Cylinder head talk
https://dodgeforum.com/forum/1st-gen...d-dealers.html
Sliding Drivers Seat Fix
Cigarette Socket and Power Outlets
https://dodgeforum.com/forum/1st-gen...er-socket.html
AMBIENT TEMPERATURE SENSOR (Overhead digital read out)
https://dodgeforum.com/forum/1st-gen...d-display.html
Heater Core Removal
https://dodgeforum.com/forum/1st-gen...ater-core.html
Heater Actuators(2002-2003)
https://dodgeforum.com/forum/1st-gen...w-problem.html
Wheel Bearing Rebuild Project (Did not work)
https://dodgeforum.com/forum/1st-gen...l-bearing.html
Towing and Gearing
https://dodgeforum.com/forum/1st-gen...-some-fun.html
http://www.allpar.com/model/durango.html
http://www.allpar.com/model/durango-...fications.html
How to tell your gears:
https://dodgeforum.com/forum/1st-gen...hat-gears.html
Complete loss of oil pressure
https://dodgeforum.com/forum/1st-gen...-pressure.html
Replacement Speakers
https://dodgeforum.com/forum/1st-gen...-problems.html
https://dodgeforum.com/forum/1st-gen...t-speaker.html
https://dodgeforum.com/forum/1st-gen...ty-stereo.html
Quick Reply: 1st Generation Durango 1998-2003 DIY
