Old Aug 7, 2015, 05:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension
Print Wikipost
**FAQ2 ----Modification Ideas: Lifting/Lowering, Performance, Swaps & More**
Old Feb 20, 2010 | 04:14 AM
95_318SLT's Avatar
95_318SLT
Arrow **FAQ2 ----Modification Ideas: Lifting/Lowering, Performance, Swaps & More**
See the FAQ page for general truck Info, common problems, and factory service manuals.
Please post any suggestions, ideas, DIY write-ups, project builds, etc that you would like to see in FAQs in THIS POST
If you need further assistance with any of the issues below, please do not hesitate to make a new thread.
All this info was collected from this site and around the Internet. This info will work for first generation Dakotas (1987-1996).
For more info, DIYs, project ideas, etc. check out the 2nd Generation Dakota FAQ, 3rd Generation Dakota FAQ, 2nd Generation Ram FAQ, 3rd Generation Ram FAQ, 1st Generation Durango FAQ, 2nd Generation Durango DIY, And the general forum FAQ.
________________________________________
Lifting
4wd
Leveling kit: From factory the rear of the truck is higher then the front, so when you put a load in it, it won't sag. A leveling kit lifts up only the front of the truck to make it level with the rear. If you want to make it level just crank up the torsion bars.
Lift kit: A lift kit lifts the front and back of the truck.
Body kit 2in. http://www.summitracing.com/parts/PRA-PA-642/
https://dodgeforum.com/forum/1st-gen...t-install.html
Custom 6in body kit. https://dodgeforum.com/forum/1st-gen-...y-tires-d.html
Full suspension kit 4in. ($1,700) http://www.streetperformance.com/par...9-dd43ssv.html
The kit is no loner made, if you look up the kit on Google by part number lots of sites list it. Call up the places to verify.
This link is just for reference on the part numbers. Click HERE. Here is a great site about installing the kit. http://www.walt-n-ingrid.com/modifications.html
Here is one site with pictures of the kit installed. Click HERE
Lift keys 2 inch. Lots listed on http://www.ebay.com/ 97-up may work!
http://www.totalperformanceonline.co...1321/50/100-14
Or you can just crank your torsion bars and add rear blocks for 1 inch or so. Here is a How to. https://dodgeforum.com/forum/1979009-post2.html
You can tack weld some 1/4 inch steal strips to your keys. Here is a post on it. 1st-gen-dakota/175855-cheep-lift-post1417241.html#post1417241
You can get blocks just about any parts stores. Sizes are available from 1 inch - 6 inches.
You can get Shorter rear spring shackles.
Or flip your shackle hangers. Check out https://dodgeforum.com/forum/1st-gen...with-pics.html
https://dodgeforum.com/forum/1st-gen-...ut-blocks.html
https://dodgeforum.com/forum/1st-gen-...le-hanger.html
If you got a V6 you can get V8 torsion bars to give you an extra inch or so.
Add a leaf too.
http://www.jcwhitney.com
You can get air shocks too. These are not air bags. So you don't need an on-board compressor. http://shop.oreillyauto.com/productd...ype=50&PTSet=A
Or
https://www.shockshopusa.com/thankyou.html
Universal air bags. http://www.airbagit.com/Default.asp?Redirected=Y
http://www.summitracing.com/parts/AIR-59501/
http://www.streetbeatcustoms.com/
You can get coil over rear shocks. It may add an inch of height. http://shop.oreillyauto.com/productd...ype=50&PTSet=A
2wd
You can use the 2in body kit. It says only for 4wd, but It will work for 2wd. All you need to do is cut in a 1 inch spacer for you steering shaft. http://store.summitracing.com/partdetail.asp?autofilter=1&part=PRA%2DPA%2D64 2&N=700+%2D59186+%2D59416+%2D42535+115&a ut oview=sku
For the front you can get coil spacers. Use one on top and one on the bottom for 2in lift. http://store.summitracing.com/partde...p;autoview=sku
http://store.fatbobsgarage.com/share...t=products.asp
If you got a V6 you can get V8 coils to give you an inch or so or custom coil springs. Ebay.com may have some.
For the rear, you can use shorter spring shackles.
https://dodgeforum.com/forum/1st-gen-...ut-blocks.html https://dodgeforum.com/forum/1st-gen-...le-hanger.html
Add a leaf too.
http://www.jcwhitney.com/autoparts/Product/tf-VehicleBrowse/s-10101/Pr-p_Product.CATENTRY_ID:2005974/p-2005974/N-111+1993+200728540+600003409/c-10101
You can also do a spring over axle swap. But this will add around 5 inches of lift just for the back. After a SOA swap, you can use lift blocks. Sizes are available from 1 inch - 6 inches.
http://www.partsamerica.com
Universal air bags. https://airbagit.com/index.php?osCsid=949e8293e36ab275b7beeed6ca3c2580
Lowering
2wd
http://www.belltech.com/
http://www.sporttruckdirect.com/dako...html#oldDakota
http://www.doetsch-shocks.com/34.asp
http://www.stillen.com/product.asp?i...LES&c=SU&m=all
http://airbagit-store.com/default.asp?redir=1
For the rear just use spring blocks, or longer spring shackles.
If you got a v8 you can get v6 coils, you can heat the springs, You can cut the springs.
Or flip your shackle hangers. Check out https://dodgeforum.com/forum/1st-gen-...ut-blocks.html
4wd
http://www.totalperformanceonline.co...ayout_0100.xsl
If you got a v8 you can get v6 torsion bars. You can crank down the torsion bars. For the rear use longer spring shackles or do a spring under axle swap. Some have token out some springs from the spring pack.
Or flip your shackle hangers. Check out https://dodgeforum.com/forum/1st-gen-...ut-blocks.html https://dodgeforum.com/forum/1st-gen-...le-hanger.html
Tire Sizes
How to decipher metric tire sizes
The first number is the section width of the tire in millimeters. This is not the bead width nor the tread width, this is the width of the widest part of the tire.
The second number is the aspect ratio. This is a ratio of the height vs the width. This number as a percentage of the first number gives you the sidewall height.
The third number is the bead diameter (rim diameter) in inches.
*NOTE* 25.4 millimeters = 1 inch
Example) 235/75/15
Width = 235mm = 9.25". Height = 235*(75%) = 176.25mm = 6.94"
Total diameter = (6.94*2) + 15 = 28.88 inches
Converted to standard size, this is a 28.88 x 9.25 x 15 tire.
What can I fit on my 4x4?
Stock...29 -30 inches
1-2 inches... 31s
2-4 inches... 33s
4-5 inches... 35s
Check http://www.4wheeloffroad.com/techart...ide/index.html
What can I fit on my 2wd?
Stock... 235/75r15
1-2 inches... 30s
2-4 inches... 31s
Wheel Info
This information covers what you need to know about offset and backspacing for choosing your aftermarket wheels...
Width
Advertised wheel width is measured bead to bead, not flange to flange. The standard measurement of a wheel flange is a 1/2 inch, and each side has one, so add 1 inch to the advertised wheel width to get the flange to flange measurement.
Offset
Offset is a measurement from the centerline of the wheel to the mounting surface of the wheel. Positive is toward the outside, negative is toward the inside.
Backspacing
Backspacing is a measurement from the mounting surface of a wheel to the inner flange. (Remember that 1/2 inch is added to the wheel width.) So on an 8 inch wide wheel with 0 offset, backspacing is actually 4.5 inches.
If offset is not 0, convert offset from millimeters to inches (1 inch = 25.4 mm) and add or subtract that number from the neutral backspacing (backspacing at 0 offset) of the wheel. For example, an 8 inch wide wheel with a -12 offset (-12mm converts to ~1/2 inch).... The -12 offset would put the wheel mounting surface closer to inside flange, so backspacing would become less (which is why its negative), so a 4.5 inch neutral backspacing minus 1/2 an inch gives a 4 inch backspacing.
How to use this info
So when you are looking for aftermarket wheels, you need to pay close attention to backspacing... offset is just going to be what it ends up being! Choose a wheel with the same or as close as possible to the factory wheel's backspacing. The reason backspacing is so important is because there is ample room outside the wheel well, but you need to make sure you clear everything inside the wheel well. So you can't go much higher than the factory wheel's backspacing or you run the risk of rubbing the fender wells, frame, or control arms. However, you don't want to go too much lower either, because the wheel bearings will take a more even load and last longer the closer the mounting pad of the wheel is to the centerline.
Off Road Guide
off-road/173712-off-road-guide.html
U-Bolt flip for additional axle clearance... https://dodgeforum.com/forum/1st-gen-...bolt-flip.html
Brush Guards, Push Bars, Light bars
www.Jcw.com has some light bars.
For a full size guard there is only one. www.ebay.com
A few others said cap-it.com has it and smittybilt.com, Westin.com but I checked I couldn't find anything Or custom make it. I custom made mine. You may also be able to get a 2nd gen and try it. I believe the frame widths are the
same.
One guy said he got it from this site. It doesn't have it listed but give them a call. http://www.armorrex.com/product/prod...eID=9&cateID=4
Go Industries site Knockdown Grille Brush Guards
Tow Hooks
There are no Tow Hooks available as a direct bolt on. So custom fit is your only choice. 1st-gen-dakota/176727-tow-hooks.html#post1424515
http://faq.dakota-truck.net/HOWTO/towhook.html
Front Hitch
There are no Front hitch kits made for the 1st Gen. But I custom made my own.
https://dodgeforum.com/forum/1st-gen-...ont-hitch.html
Or you can try a 2nd Gen. front hitch. I don't know how much more customizing you might need to do to make it work.
http://www.etrailer.com/fmr-2000_Dodge_Dakota.htm
http://www.realtruck.com/product/108...tch_31097.html
http://www.autoanything.com/towing/6...79975&kc=AFFCJ
Make some brackets like these ones, or use a tow bar like this and add a hitch tube to the center.
http://www.aemfg.com/pdfs/BX1919.pdf
Skid Plates
There are 3 factory skid plates. I made 2 others. All can be seen below.
https://dodgeforum.com/forum/1st-gen...id-plates.html
https://dodgeforum.com/forum/1st-gen...tion-pics.html
http://www.walt-n-ingrid.com/modifications.html#Skid
http://www.trailmastersuspension.com...ories.htm#skid
Or you can custom make your own. I custom made mine.
Winch
https://dodgeforum.com/forum/1st-gen-...lbs-winch.html (Front hitch mounted 10,000lb)
https://dodgeforum.com/forum/1st-gen-...1-winches.html (2,000lb front hitch mounted, 3,000 wireless rear hidden winch)
Dual Shock kit
Here are some pics... 1st-gen-dakota/175437-dual-shock-kit.html#post1413366
http://www.trailmastersuspension.com...multishock.htm
https://dodgeforum.com/forum/1st-gen-...al-shocks.html
Custom Bumpers
https://dodgeforum.com/forum/1st-gen-...er-design.html
https://dodgeforum.com/forum/1st-gen...ck-bumper.html
https://dodgeforum.com/forum/1st-gen...t-build-5.html (LA engine into 89 Dakota)
Factory Engine Swaps
3.9L v6 to 5.2 or 5.9 v8 (LA to LA or Magnum to Magnum)
The 3.9L v6 is basically a 5.2L v8 with 2 cylinders missing. The mounting points are the same for the v6 and v8s. To do this swap, you will need a complete v8 with the v8s flexplate (or flywheel), wiring harness (or simply run your own wires for the extra injectors) and computer. The mounts from the v6 can be swapped to the v8. The v6 transmission will either need to be replaced or beefed up to handle the additional torque.
https://dodgeforum.com/m_1276458/tm.htm
1st-gen-dakota/130068-swap-questions.html
Mopar Action Magazine did a article on it. 1st-gen-dakota/176114-mopar-action-dak-5-9-swap-pics.html
1st-gen-dakota/175439-engine-swap-info.html#post1413374
( Info on motor mounts LA blocks to Magnum Blocks v6 and v8)
https://dodgeforum.com/forum/2nd-gen-...ome-today.html
http://www.engine-swaps.com/
http://chucker54.stores.yahoo.net/192wddakensw.html
https://dodgeforum.com/forum/1st-gen...to-93-4x4.html
5.2L to 5.9L v8 (LA to LA or Magnum to Magnum)
The 5.2L and 5.9L v8s are externally identical engines, meaning they share the same dimensions and mounting locations. They also share the same heads and intake. The easiest way to do this swap is to get a 5.9L from heads down (long block). You will need the flexplate (or flywheel) and harmonic balancer for the 5.9L because the two engines are balanced different. Everything else from the 5.2 will swap over including wiring harnesses, injectors, and the computer.
Click here for a good article on 3.9, 5.2, and 5.9 engine info and year to year changes.
3.9 V6 to 5.9 Magnum. HERE
V6LA to V8 LA https://dodgeforum.com/forum/1st-gen...ert-build.html
Here is a good link for LA and Magnum changes. http://api.viglink.com/api/click?for...us%2Fsort.html
Old Feb 20, 2010 | 04:16 AM
95_318SLT's Avatar
95_318SLT
5.7 Hemi Swap
https://dodgeforum.com/forum/1st-gen...tallation.html
Diesel Engine Swap
http://www.4btswaps.com/forum/showthread.php?t=7949&highlight=dakota (94 Dakota)
http://www.khaoskustoms.ca/aspx/blob2/blobpage.aspx/msgid/443167
http://www.4btswaps.com/forum/index.php
http://www.destroked.com/
jonnymagnum
http://s143.photobucket.com/albums/r152/6BT-Dakota/ (6BT-DAKOTA)
http://www.dakota-durango.com/forum/showthread.php?t=77610
http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=105 516916
http://www.4btswaps.com/forum/showthread.php?7949-94-Dakota-4BT-swap
_______________________________________________
Engine Performance - More Displacement
Big Block Swap
http://www.bigblockdakota.com/gpage5.html
Small Block Stroker kit
http://www.krcperformance.com/krc/in...hk=1&Itemid=26
(408) http://www.moparstyle.net/technical/408stroker.htm
https://dodgeforum.com/forum/2nd-gen-...hlight=stroker
http://www.carcraft.com/techarticles...ker/index.html
http://speedomotive.com/ps-140-13-mo...roker-kit.aspx
This chart will give you an idea of what bore and stroke will give you what size engine.
displacementchart-2.jpg?t=1241471791
Engine Performance: Forced Induction and Nitrous Oxide
https://dodgeforum.com/forum/1st-gen...rbo-build.html
http://www.theturboforums.com/smf/in...topic=131965.0
https://dodgeforum.com/forum/dodge-da...t-options.html
http://www.dakota-durango.com/forum/...0&postcount=11
http://www.theturboforums.com/smf/in...?topic=80720.0
http://www.off-roadweb.com/tech/0902or_nitrous_is_for_anything/index.html
(Nitrous for a 2001 Durango 5.9)
More Engine Performance Options
Lots of info on performance http://web.archive.org/web/200804121...sandtricks.htm
Larger Bore throttle body http://www.thefastman.com/Throttlebodies47.asp,
https://dodgeforum.com/forum/2065702-post1.html
Kegger mod https://dodgeforum.com/forum/2nd-gen-...e-mod-diy.html,
Roller Rockers 1.7:1 Harland Sharp's http://www.summitracing.com/parts/CS...7&autoview=sku
Much cheaper then the Mopar or Crower kits, and much easier to install in my opinion (no lash adjustments, no guide plates, fits under stock valve cover)
Here is my install on them, very good post.
https://dodgeforum.com/forum/2065727-post3.html
http://www.pavementsucks.com/tech/rollerrocker.php
https://dodgeforum.com/forum/2nd-gen-...r-install.html)
Cams
Mopar Performance computer (V6 http://www.bionicdodge.com/bionic/in...p?topic=8778.0)
High output coil + wires + cap and rotor
Spark plugs (Autolite 3923's is 1 step colder) (Autolite 3922 is 2 step colder, for supercharger/ turbo/ NOS)
Higher flow injectors
Headers (v6 https://dodgeforum.com/forum/1st-gen-...9-headers.html)
Open flowing exhaust systems
High flow cat
Lower (numerically higher) Rear End Gears
Transmission shift kit
Machine work (deck down block, heads) (Bore out cylinders).
Polish and port heads http://www.moparmusclemagazine.com/h...ing/index.html
Electric cooling fan
Electric coolant pump http://www.csr-performance.com/csr_pumps.html
Under Drive pulley's. (be-careful lots are 6ribs. Magnums use 7 ribs)
Lots more....
http://www.hughesengines.com/TechArt...es03012004.php (V6 Performance)
Hurts Competition shifter https://dodgeforum.com/forum/2230368-post6.html
TPS Throttle Postion, CPS Crank Position Sensors modification. Go HERE.
Transmission swap
46rh Automatic to NV3500 Standard... https://dodgeforum.com/forum/1st-gen-...-5-2l-4x4.html
NV4500
https://dodgeforum.com/forum/1st-gen...to-nv4500.html
https://dodgeforum.com/forum/1st-gen-...00-thread.html
https://dodgeforum.com/forum/1st-gen-...-for-swap.html
T-56 6 Speed converion kit for Dakota / Rams http://www.keislerauto.com/mopar-faq.html
http://www.mallcrawlin.com/forum/showthread.php?t=8621 (Converting 2 wheel drive transmission to 4 wheel drive.)
Transfer case swap
NV231D to NV242J Full time 4x4... https://dodgeforum.com/forum/1st-gen-...ew-arts-d.html
Transfer case Upgrades
For the NP231, you can get a SYE (Slip Yoke Eliminator) kit, 4:1 low range swap kit, and wide chain kit.
http://www.4x4wire.com/jeep/tech/xfer/tera4_1/ (4:1 low range NV231)
http://www.pirate4x4.com/forum/showthread.php?t=399755
http://www.4wheeloffroad.com/techart...ild/index.html
http://offroad-review.com/new/index.php?page=106 http://www.webejeepin.com/Glenns_Jeep/transfercase.htm http://www.teraflex.biz/products/
http://www.4wheelerssupply.com/catal...ns/1867660.pdf
http://www.4wheelerssupply.com/catal...ducts_id/71505
http://www.jbconversions.com/index2.php?pc=5
http://www.jpmagazine.com/techarticl...tor/index.html
Performance Computer Upgrades
Engine Stand Alone Engine Management Systems
http://www.fuelairspark.com/Products...er/sb/over.asp
Factory Computer Reflashes
There are very little for Dodge OBD1.
The best would be a Mopar performance computer. You can get them at http://www.mopar.com/performance/index.html or http://www.summitracing.com/
Jet chips has a plug in. It has been cheep quality and not worth it for most. http://www.jetchip.com/
You can get http://www.hypertech.com/Products/Po...uning%20Module (No reviews yet)
Here is one that flashes and can give you a handheld unit. http://www.bgperformancepcm.com/#magnum
At once this site had it listed but the site seems to be down now. http://nrar.com/
You can Also get get a multi-processor-driven signal manipulator that goes in-line between your engine and ECU.
http://www.unichip.us/dodge.asp
Petersen's 4Wheel & Off-Road Magazine did an article on it.
http://www.4wheeloffroad.com/techarticles/drivetrain/131_0707_1994_dodge_4x4_truck_dyno_tuning/index.html
Suspension Swaps
Rear end Swap Corp. 8.25" to Corp. 9.25"
You can upgrade your rear axle to the stronger 9.25" from a 2nd generation Dakota. The 9.25" will be about an inch wider.
1st-gen-dakota/177892-9-25-rear-end-swap.html
2wd to 4wd
https://dodgeforum.com/m_961445/tm.htm
Solid Axle Conversion/Swap
The most readily available axles for a good SAS are late 70's F150 and Full Size Bronco dana 44 axles. Or late 80's Jeep Grand Wagoneer Dana 44. They are drivers side drop like our trucks and can be easily found. Some full size Dodge axles will work as well.
http://web.archive.org/web/200712291...urwheeling.htm
http://www.angelfire.com/va2/bobalooey/
http://www.pioneer4wheelers.org/foru...ead.php?t=3433
http://www.4x4wire.com/feature/99dakota/solidaxleswap/
http://www.cardomain.com/ride/834955
7-8 listed http://www.cardomain.com/
https://dodgeforum.com/forum/1st-gen-...-my-truck.html
http://offroad.automotive.com/72727/...uck/index.html
http://www.pirate4x4.com/forum/showthread.php?t=647091
http://www.cardomain.com/ride/255475...ar-cab-chassis
https://dodgeforum.com/forum/1st-gen...ap-thread.html (95_318SLT Discussion)
https://dodgeforum.com/forum/1st-gen...ead-contd.html (95_318SLT Build)
https://dodgeforum.com/forum/1st-gen...questions.html
https://dodgeforum.com/forum/1st-gen...1-my-95-a.html
https://dodgeforum.com/forum/1st-gen...sweat-sas.html
https://dodgeforum.com/forum/1st-gen...ml#post2433694 (Crazy4x4rt Build)
https://dodgeforum.com/forum/1st-gen...on-thread.html (Crazy4x4rt Discussion)
http://www.cardomain.com/ride/209912...ar-cab-chassis
http://ramchargercentral.com/action-...e0d1f4e57akiv4
http://www.cardomain.com/ride/217099...ar-cab-chassis
Old Feb 20, 2010 | 04:32 AM
95_318SLT's Avatar
95_318SLT
Brakes
(proportioning valve install) 1st-gen-dakota/180152-adjustable-proportioning-valve-install.html
Rear Disk Brake info https://dodgeforum.com/forum/1st-gen-dakota/264331-93-4x4-5-2-le-dakota-drum-brake-to-disc.html
https://dodgeforum.com/forum/1st-gen...ml#post2451975
Limited Slip Differentials, Lockers and Spools
http://www.ringpinion.com/PartsList.aspx?
http://www.differentials.com/pdfs/5.pdfSearchMode=Diff&TypeID=2&Type=Chrysler&DiffID =7&DiffName=Chrysler+8.25&CatID=7&CatName=Lockers & CatType=Sub-Differential
Homemade Spool (Welded Spiders) 1st-gen-dakota/178531-home-made-posi-trac.html
http://www.sixstates.com/corporatedocs//file22.pdf
Differential Gears
*NOTE* With the factory 4x4 front axle, 4:10s are as low as you can go
http://www.4lo.com/calc/geartire.htm (Lots of calculators)
Good Engine Articles
400HP on 318 http://web.archive.org/web/20060514133754/http://carcraft.com/howto/116_0401_318/index.html
http://www.popularhotrodding.com/tech/0507phr_mopar_magnum_engine_specs/index.html
http://www.popularhotrodding.com/enginemasters/articles/hardcore/0412em_magnum_cylinder_heads/index.html
Parts sites
http://outboundlink.net/anxo/dr_ta_1...38297_0_15373_ (AC Compressor Eliminator/Delete/ByPass Pulley)
http://www.jegs.com/
http://www.jcwhitney.com/Auto-Parts/101010.jcw
http://www.motors.ebay.com/
http://www.craigslist.org/
http://www.4wheelparts.com/
http://www.rockauto.com/catalog/raframecatalog.php
http://www.hughesengines.com/partsIndex.asp?eTypeID=15
http://www.v8performance.com/
http://www.monicattichrysler.com/com...?idCategory=73
http://www.trailmastersuspension.com/
(Fan clutch, water pump pulley tool, spanner wrench)
http://www.napaonline.com/NOLPPSE/(S...530_0006544226
(Upper ball joint socket/ wrench/ tool)
http://www.handsontools.com/Miller-T...-_p_18008.html
http://www.stockinteriors.com/ (Carpet)
http://www.newark-auto.com/https://dodgeforum.com/forum/2211477-post3.html (Carpet)
http://www.rustrepair.com/ (Body)
http://www.diffsonly.com/catalog/product_info.php?cPath=1161&products_id=167753 (Chrysler 8.25, Trac Lok Clutch, LSD rebuild kit)
2nd Gen. Dakota Seats into 1st Gen Dakota
https://dodgeforum.com/forum/1653356-post14.html
Custom Hoods, Fenders, Graphics, Bumpers
http://www.glassworksunlimited.com/shop/home.php?cat=13 (Wide Fenders, Baja, Pre-runner)
http://www.dakota-durango.com/parts_hoods.php#AAR2 (Cowl induction hoods)
http://www.carhoods.com/(Hoods, ect)
http://www.andysautosport.com/dodge/1991_1996_dakota/
(Hoods, ect)
http://www.carid.com/1995-dodge-dakota-grill-guards/westin-bumper-104681.html (Aftermarket Bumper)
http://www.andysautosport.com/dodge/1991_1996_dakota/exterior/roll_pans/ (Roll Pans)
http://www.autopartswarehouse.com/sku/Dodge/Dakota/IPCW/Roll_Pan/1996/I11CWR8796 (Roll Pans)
http://www.aarqualityfiberglass.com/ (Hoods, ect)
http://ecat.crosscanadaparts.com/php...DAKO&year=1996
http://ecat.crosscanadaparts.com/php...=0&body=0&view= (Body parts)
http://www.millsupply.com/ (body)
http://www.totacc.com/user/glenzoni/index.html (Graphics)
http://www.phoenixgraphix.com/ (Graphics)
https://dodgeforum.com/forum/1st-gen-dakota/193634-custom-bumper-design.html (Bumpers)
http://www.razzi.com/results-product.php?make_id=11&model_id=0&year=1993&type_i d=0&Submit.x=68&Submit.y=6 Body Kits
http://grantkustoms.com/catalog/prod...4c119bb77be0af (Tailgate ect)
Convertible kit
Instructions http://airbagit.com/techzone/raticalhard.pdf
Kit http://airbagit.com/product_info.php?products_id=5998
Clear lights / Euro Lights
All over www.ebay.com
http://www.memoimports.com/mi/index.php?fa=prt.subcategory_aft&cat=Dodge%20Truck s&subcategory=Dodge%20Dakota%20signoand%20Dakota %2 0Sport%20Yrs.%2088%20-%2096
www.ebay.com
http://www.procarparts.com/index.php...ducts_id=29973 (White Gauges)
Here is a post on tinting your tails with VHT 1st-gen-dakota/180165-vht-nightshades-for-tailights.html
Light covers http://spideraccessories.stores.yahoo.net/headblac.html
Info sites
http://www.allpar.com/trucks/dakota-1987.html
http://www.dakota-truck.net/infosheet.html (all dakota info)
http://www.allpar.com/ (all mopars)
http://dodgeram.org/tech/gas/specs/index.html(all engine specs)
http://www.okoffroad.com/editorial-boltpattern.htm (Wheel Bolt patterns)
https://dodgeforum.com/forum/2nd-gen...ur-trucks.html (Fuel Injectors)
2nd-gen-ram/171765-injectors.html?highlight=fuel+rate (fuel Injectors, fuel rates)
https://dodgeforum.com/forum/1st-gen-...agnostics.html (Transmission Diagnostic Chart)
http://www.generalspringkc.com/index...arent=117&pg=1 (Leaf Spring info)
http://www.sdtrucksprings.com/index....FZdM5Qod_CVlZw (Leaf Spring info)
http://www.off-roadweb.com/tech/0907...ody/index.html (Performance Throttle Body)
http://www.4wheeloffroad.com/techart...ech/index.html (Performance Throttle Body)
http://www.popularhotrodding.com/tec...ecs/index.html (Engine)
http://www.sporttruck.com/techarticl...cks/index.html (Engine)
http://www.hotrod.com/techarticles/e...ine/index.html (Engine)
http://www.moparmusclemagazine.com/h...ing/index.html (Cylinder Head porting)
http://www.off-roadweb.com/tech/0902...ing/index.html (Nitrous for a 2001 Durango 5.9)
http://www.off-roadweb.com/tech/1005...ade/index.html (NP231 4:1 low gear install, SYE kit)
http://www.4wheeloffroad.com/howto/3103/index.html (NP231 HD build)
Billet Grill
Lots all over www.ebay.com
http://www.cwgrilles.com/Merchant2/m...ry_Code=Dakota These look like this http://i31.tinypic.com/2vl1yeb.jpg
Electric Fans
There is not a direct bolt in kit. The best choices are 90-95 Ford Taurus and Lincoln Mark VIII with the 3.8 litre engine. It has 2 settings, Low 2500CFM Hight 4500CFM. Or Get a dual fan unit from a Ford Contour/Mercury Mystique. or the dual fan from a 98-03 Intrepid. I think you can also use a dual fan unit out of an early/mid 90s Camaro. You may need to make custom mounts. You can also go to most parts stores or www.summitracing.com and buy universal fans, check www.ebay.com too.
Here is a good post with a good fan shroud built in. https://dodgeforum.com/forum/1st-gen...om-shroud.html
Here are a few articles
http://www.customclassictrucks.com/t...ods/index.html
http://www.chevyhiperformance.com/howto/4572/index.html
http://www.customclassictrucks.com/t...all/index.html
http://www.mustangmonthly.com/howto/11879/index.html
Flatbed on 1st generation Dakota
https://dodgeforum.com/forum/1st-gen-...e-finally.html
https://dodgeforum.com/forum/1st-gen-...atbed-pix.html
Snow Plow
https://dodgeforum.com/forum/1st-gen-...nter-pics.html
Wheel spacers
http://www.ezaccessory.com/category_s/178.htm
www.ebay.com
Check ebay lots to choose. Some to convert bolt pattern size too.
DIY
2nd-gen-ram/117182-diy-links.html
https://dodgeforum.com/forum/1st-gen-...9-mirrors.html (How to tighten up 6x9 mirrors)
https://dodgeforum.com/forum/1st-gen...up-holder.html (Tighten up loose cup holder)
https://dodgeforum.com/forum/1st-gen-dakota/194143-official-diy-body-work-thread.html (Body work)
https://dodgeforum.com/forum/1st-gen-dakota/192351-diy-multi-meter-101-a.html (How to use a Multimeter)
https://dodgeforum.com/forum/1st-gen-...-part-1-a.html (Custom LED guage lights)
https://dodgeforum.com/forum/1st-gen-...ess-entry.html (Wireless door locks)
https://dodgeforum.com/forum/1st-gen-...an-clutch.html (Tips on removing fan clutch)
https://dodgeforum.com/forum/1st-gen-...-por-15-a.html (DIY Rust Proofing with POR-15on a engine block.)
http://www.4x4wire.com/toyota/minutemods/seatbelt/ (Retention seatbelt spring)
https://dodgeforum.com/forum/1st-gen...t-install.html (Halogen Headlight High Wattage Output Install)
http://www.stolenandrecovered.com/howto/hsg04a.php (Ignition Lock Repair)
https://dodgeforum.com/forum/1st-gen...cam-specs.html (Dakota 5.2 V8/46RH/8.25 swap into 99 Intrepid )
