PDA
View Full Version : 1st Gen Intrepid
Pages : 1 2 [3]
  1. Help please!
  2. 97 intrepid drivers taillight
  3. EGR Valve
  4. Engine Shut down while driving!!
  5. Hood latch problem
  6. 3.5 Overheating Problem
  7. Trunk button
  8. 94 Intrepid intake removal
  9. 94 Intrepid Strut Clunk
  10. Air Conditioner Problem
  11. 97' help! smoking tailpipe
  12. 96' Intrepid
  13. 95 intrepid transmission sensor problem.
  14. Need help changing O2 sensor
  15. 97' w/3.5L engine skips, with code 1391
  16. Car drives in 1st gear, then loses gear and power, have to turn key on and off to go.
  17. 1993 Intrepid ES Transmission
  18. 1993 Intrepid ES Transmission
  19. Low fuel light and gauge issues
  20. need an answer
  21. 1995 Intrepid no start
  22. Dodge Intrepids
  23. What is wrong with the Intrepids?
  24. ANYONE OUT THERE?
  25. code 54 94 intrepid
  26. Connecting OBD to DRB III
  27. Alternator, battery, or some other problems
  28. Gauges quit, won't shift right, check engine
  29. 97 Intrepid trans problems
  30. won't start when cold or wet
  31. Problem with performance
  32. Someone Please Help
  33. Help! - Where is Washer Fluid Pump?
  34. Weird problem with cooling fans. Please help.
  35. MOVED: 96 intrepid for sale!
  36. I quickly need your help(need to identify a part)
  37. any mods?
  38. Problem with Fuel gauge
  39. 96 Intrepid Air Conditioner Problems PLEASE HELP!!
  40. Tranny problem-gets stuck on one gear
  41. Starting problems 94 Intrepid
  42. 95 LH with 3.5 - to buy or not to buy?
  43. Brighter headlamps for '96 Intrepid??
  44. Several question on my 96 with the 3.3 motor
  45. options on a 96 es
  46. help with overheating
  47. 97 Intrepid tranny questions-please help
  48. 97 intrepid no back up lights.need help TIA!!!!
  49. 94 Intrepid Fuel Filter
  50. 96 Intrepid auto door lock disable??
  51. 93 Intrepid blows engine controller fuse
  52. 93 Intrepid won't start hot in 90+ weather
  53. DIY for water pump
  54. Strange problem with my 1994 Intrepid SE....
  55. 95 Intrepid CVC problem
  56. Check Engine light-Can I turn it off?
  57. Will a computer out of a van work in a 96 intrepid???
  58. Coil pack won't fire after engine change, need help!
  59. 95 AC keeps popping fuses
  60. Engine Code
  61. '94 LHS transmission problem
  62. '96 Intrepid - Fuel System
  63. Nothing!
  64. 94 Transmission help
  65. 95 intrepid clattering
  66. 95 with a Fan Problem
  67. Squeaking from AC compressor clutch
  68. 95'concorde 3.5 into 97' intrepid help
  69. ????1995 LHS 3.5 performance parts????
  70. High Idle Problem
  71. RE: Adjusting Wiper Travel
  72. 93 intrepid ES front end problem help
  73. Struts..
  74. Multi Function Switch
  75. Climat Control Center....DEAD
  76. ELectrical diagram someone???
  77. Short circuit
  78. wiper motor in a 96 intrepid? where is it located
  79. Enginge swap 1994 3.5 for 1995 3.5
  80. '95 Intrepid stuttering
  81. ABS system on '96 Intrepid
  82. 96 INTREPID HELP
  83. 96 Intrepid Help!
  84. 96 Intrepid Wheel Joint
  85. 94 Dodge Intrepid Rear Disc Brakes???
  86. Dash Lights
  87. upstream o2 sensor on lhs
  88. HELP!!!
  89. check engine light on. start problem. Need help
  90. '95 Intrepid stumbling/ignition cutting in/out, need help ASAP!!!
  91. 1995 Dodge Intrepid ES Road Trip. Need help!
  92. Drive shaft slipped out
  93. 96 Intrepid died...need help...
  94. 95 Intrepid computer?/thumping
  95. 1993 intrepid
  96. REPAIR HELP
  97. 96 ES Intrepid gone
  98. Falling off the track
  99. Code 43. Please advise!
  100. 96 Dodge Intrepid Trouble Codes
  101. Air Conditioner Problem
  102. No Headlights
  103. Fair price for '94 Intrepid?
  104. 97 Intrepid is sick!
  105. 97 INTREPID 3.5 litre lifespan??
  106. Cruise Control on the blink
  107. 97 intrepid coil pack help
  108. Need Help With '96 Intrepid
  109. Fan blower not working
  110. Too Much Wrong at On
  111. Too Much Wrong at On
  112. STUPID question, where is
  113. should I or shouldn’t I ?
  114. Help dodge Intrepid 95 Starter
  115. 96 intrepid 3.5L radiator fan
  116. 96 Intrepid Wierd Sounds
  117. 96 Intrepid won’t start,
  118. "Free mods" for ’95 Dodges, is
  119. Removing cats on a ’95 In
  120. Rough running when cold and ot
  121. PS Problems, think its the rac
  122. 95 Intrepid Overhead Cons
  123. 97 intrepid fenders are dented
  124. I Need Intrepid Advice! HELP H
  125. 1996 Dodge Intrepid binker hel
