PDA
View Full Version : Dodge Dakota
Pages : 1 2 3 [4] 5 6 7
  1. 97 DAKOTA HEATER
  2. New here and reading about some front end problems (have concern)
  3. Just joined.. hey gang
  4. Need help with this
  5. Just joined this group and picking mine up tomorrow
  6. Probable wiring issue
  7. Production numbers on Warrior Dakota
  8. 2008 Dodge Dakota MMC
  9. Club cab Dakota
  10. brake question
  11. Buying a Dodge Dakota...One question?
  12. 96 Dakota Sport 2.5 Chugs
  13. fuel injectors
  14. How important is truck color to you!!
  15. HEADUNIT QUESTION
  16. wheels
  17. colored bumpers and grill trim
  18. colored bumpers and grill trim
  19. Looking For dakota R/T
  20. 97 dakota instrument cluster
  21. So what did you pay for you Dakota?
  22. 2000 Dakota NV 3500 tranny needs replacing?
  23. ABS and Brake light on
  24. My new ride, heat doesn't work!
  25. suspenson lifts for 4x4??
  26. HELP-water under the carpet
  27. Towing with 3.7 auto (no tow package)?
  28. Let me Introduce Myself
  29. Dakota
  30. Rebuilt Transmission - Update!
  31. help- won't start!
  32. supercharger
  33. Damn A/C compressor ;(
  34. stereo help.....radio works, cd and tape do not!!!
  35. Help Needed ~2000 Dakota 4.7 Owners
  36. Getting the most power out of my truck
  37. Bedliner Pics Rhino vs. Line X
  38. Evolution of the 231D?
  39. dodge d-50 turbo diesel
  40. 4.7 Misfire
  41. od not working!!!!!
  42. od not working!!!!!
  43. COMPARABLE PARTS
  44. Where is the oil going?
  45. superchip programmer
  46. Looking at used Dakotas....
  47. Tranny fizzled on '97 Dakota Sport (2WD)
  48. 1999 Review on Chrysler's New 4.7
  49. Bad or Good Idea?
  50. Please help with screw assembly torque info
  51. Stereo in 95 Dakota
  52. Hello all my 1998 dodge dakota will not start help!!!
  53. OBD II Connector Pinout Help
  54. superchip & underdrive pulleys
  55. Rough idle at start
  56. TPS on 3.9L
  57. Took some photos
  58. Dakota Rear Tool Box Suggestions?
  59. Please help with a 89 Dodge Dokota....
  60. Supercharger help
  61. Help, please?
  62. Transmission options
  63. Detailed Truck Today
  64. intake question...
  65. more headlight problems
  66. Rack and Pinion
  67. knocking? =S
  68. What is the average age of Dak owners
  69. Dakota in sunburst orange ???
  70. original options on purchase
  71. Ram air setup
  72. Refinishing hazy headlights
  73. Transmission Problem
  74. bed liner??
  75. Size tire poll
  76. 5.9 tuning software or custum tune
  77. superchip!
  78. 3" exhaust system
  79. 3" exhaust system
  80. Anyone with parts for a 96 I need a dash bezel
  81. viper motor swap
  82. engine codes P0508 and P0509
  83. Is changing a AC condensor a DIY project ??
  84. 98 Dakota popping out of 1st gear on take off
  85. Interior Lights Won't Go Out
  86. Interior Lights Won't Go Out
  87. 92 Dakota Starting Problem
  88. OD on or off?
  89. Newbie here
  90. Best sounding muffler on 3.9?
  91. what's a good place online to order R/T parts?
  92. *****Warning*****
  93. REPLACEMENT FRONT DRIVE SHAFT FOR 2001 4X4 MANUAL TRANS
  94. 94 5.2L suggestions
  95. "No Bus "question
  96. 2001 Dakota - Speedometer
  97. AMC Dakota with Chrysler engine?
  98. THANKS Everyone That Posted A Reply To My Turbonator Question !
  99. exhaust
  100. test
  101. Disabling Daytime Running Lights on a '03 Dakota
  102. How to set alarm chirp settings
  103. 3.9L Starter
  104. My son got a 2002 Dak quadcab - questions
  105. Won't Start
  106. Throttle body spacer
  107. hard code p0442 med evap leak, where is my evap canister?
  108. transmission problems
  109. Dak not starting. HELP!!
  110. 91 dakota 5.2l
  111. Looking for a 90ish - 96 Dakota...need some advice....
  112. 01 dakota overheat
  113. 2nd gen dakota custom parts for sale
  114. lower dodge dakota 4x4 98 help!
  115. i need help
  116. Camper top
  117. Online Repair Manual?
  118. Help Setting Up GTech Pro RR on `05 Dakota 4.7l
  119. 02 dakota
  120. quad cab tool box
  121. ac compressor pulley
  122. hey new guy here! got a question
  123. Air Intake
  124. Engine Bogging down, barely reveves V6
  125. MOVED: Wiring diagram
  126. MOVED: 89 Dakota Wiper Switch
  127. MOVED: 2005/2006 poor braking!
  128. MOVED: "01 Dakota 4x4 lower balljoint replacement
  129. MOVED: Painting interior & new headliner questions...
  130. MOVED: INFORMATION NEEDED PLEASE!!!!
  131. MOVED: Cowl Trim Cover
  132. Powers Door Lock Problems
  133. msd coil
  134. MOVED: I was wondering???
  135. MOVED: High nitrogen count during MD emission test
  136. MOVED: bought used 04 QC 4X4 3.7v6. how to tell if it has limited slip or not.
  137. Would you Join a Dak Club?
  138. MOVED: Important!! Brake Service Advisor
  139. MOVED: New Tires HELP!!!
  140. MOVED: Disable automatic locks
  141. MOVED: What is this?
  142. MOVED: removing windshield wiper
  143. Help Please!!!
  144. MOVED: mods
  145. MOVED: rear leve springs
  146. MOVED: truck needs a lift
  147. MOVED: newbie needs trasmission help
  148. MOVED: looking at '03 4.7L quad cab...
  149. MOVED: '01 3.9 Dakota Couple Problems
  150. MOVED: Will not Idle
  151. MOVED: speaker help
  152. May Ride of the Month Voting!!!!
  153. MOVED: Turbocharging a Dakota
  154. MOVED: Jumping to get Codes
  155. MOVED: need help with issue
  156. MOVED: Dodge Dakota 99
  157. MOVED: No Heat on Passenger Side of Dakota
  158. MOVED: check engine codes p0132 p0135
  159. rear differential
  160. Brake Lights
  161. MOVED: throttle body help please
  162. MOVED: Need Opinions: Headers
  163. MOVED: quick body lift question
  164. MOVED: new radio
  165. FREE GREG SPRADLIN SRT10 PRINT!!!
  166. MOVED: tune up questions
  167. MOVED: stalling issues on a 98 V6
  168. Shifting into 2nd gear
  169. MOVED: transmission problems
  170. MOVED: Flowmaster super 40 (qustion)
  171. MOVED: towing
  172. lights???
  173. MOVED: temperature sender 1990 dakota
  174. NASCAR Forum!
  175. MOVED: Windshield facia, hard seats, vibration.
  176. What can be done with the 4.7
  177. Super Daks
  178. coil packs
  179. MOVED: 2000 problem starting
  180. MOVED: In the dark, No 4x4: Electrical Help Please!
  181. Need help deciding on accessories
  182. MOVED: Lookin to do a few basic mods
  183. went to dealership finally got response
  184. My Dakota Pics
  185. Still Lookin
  186. MOVED: dodgy AWD system
  187. MOVED: tow hooks?
  188. MOVED: Tonneau (3rd Gen)
  189. MOVED: Chrome Shifter
  190. New Pics
  191. MOVED: Dakota Wont Start
  192. New to site
  193. MOVED: tranny shift kit help!!!!
  194. Turbo 360
  195. CD Changer
  196. MOVED: 3" lift kit installation question???
  197. drunk drivers and MPG
  198. MOVED: I've got a few questions????
  199. MOVED: voltage problem in 93 Dak
  200. MOVED: 99 Dak has serious vibration @ speed
  201. MOVED: Quiet-ing the Transmission.
  202. MOVED: 1989 Dodge Raider help
  203. MOVED: 2.5L Dodge dakota
  204. MOVED: Door Panels
  205. someone hit my truck!!!
  206. MOVED: Head Rests
  207. new pics of my dak
  208. MOVED: Whats that DINGING sound?
  209. aftermarket wheels
  210. stock wheels and aftermarket
  211. MOVED: muffler/exhaust shops
  212. Ultra short boxes on quad cabs. Does anyone else wish they made 6' ones for them?
  213. MOVED: headlight wire??
  214. Need to se pics of lowerd Dakotas ex cab with 20's please.
  215. MOVED: 05 Dakota
  216. i got a new exhaust for my dak
  217. MOVED: 2006 Dakota R/T
  218. MOVED: Poor MPG STLL, STILL, STILL
  219. Dakota Wallpaper
  220. Fiberglass Cover
  221. MOVED: Reving at constant speed
  222. MOVED: Tires
  223. MOVED: fuel filter question??
  224. MOVED: wheres the ignition harness
  225. MOVED: Shift kit ...
  226. **---> NOTHING GETS POSTED HERE!!! Please read this thread first! <---**
  227. Anyone found a good deal on R/T Fender flares?
  228. MOVED: 96 5 speed
  229. MOVED: FOR SALE: 1998 Dakota 4x4
  230. MOVED: Blower Motor Resistor
  231. MOVED: tires rubbing
  232. MOVED: 1993 Dakota Sport...no rear brakes...
  233. MOVED: Speed Sensor?
  234. MOVED: whats going on???
  235. MOVED: Pinging and Oil Consumption
  236. Graphics
  237. SRT Dakota?
  238. MOVED: 2005 Dakota - Spark Plugs Bad ????
  239. Dakota gas mileage
  240. MOVED: Coolant Leak - then no leak
  241. Mitsu Raider = Dakota
  242. Tow Package
  243. MOVED: Roof Leak
  244. MOVED: 2004 vehicle speed sensor wire help?
  245. MOVED: 98 dakota parts..........
  246. MOVED: "new" 03 Dak R/T
  247. MOVED: tracking
  248. MOVED: Which MSD ignition to use?
  249. MOVED: '92,V8,318 CU.
  250. need sites that have parts and accessories for 05 dakota
