PDA
View Full Version : Dodge Dakota
Pages : 1 2 [3] 4 5 6 7
  1. Cold Start Problem
  2. NEED HELP! Program 2nd KEYFOB
  3. Seeking Engine Weight
  4. Thermostat
  5. 99' v6 here with some odd idle problems
  6. wrong section, moved it
  7. Projector Adjustment
  8. HID Xenon's
  9. X-mas Light Challange
  10. Solid Axle Swap?
  11. Airbag control module location in a 2nd gen Dakota???
  12. How Long will my truck last?
  13. transmission slipping from stop
  14. Truck wont go more then 2500 rpms
  15. Whats your GEN II engine and tranny setup?
  16. wild graphist wanted $$$
  17. Check Enginie codes
  18. Smashed 1994 Dakota Sport
  19. Back-up Lights not coming on
  20. Dakota Hood
  21. Is 08 Dakota 4th Gen?
  22. VOTE
  23. Dakota newbie needs help
  24. headlight confusion
  25. blower motor
  26. Bad Ebay Vendor: carpartswholesale
  27. new seats wiring diagram
  28. Complete Vortech Supercharger 5.9 For sale
  29. Heater motor resistor?
  30. hi, this is Martha not Ken (aka tevafeet)
  31. Exhaust Schematic
  32. 2001 dakota grinding in 4wd
  33. remote starters
  34. Need rubber boot for transf, case shift lever
  35. Euro Tail Lights
  36. Good Deal?
  37. November ROTM Voting!!
  38. what would you offer?
  39. governor pressure sensor
  40. 2002 Dakota Radio problems
  41. Dakota FI question
  42. installed M1 on my 5.2............. need help/advice please
  43. '91 3.9 V6 revving up & down on its own HELP!!!
  44. Transformers Hitch Cover for my Dakota?
  45. New KC Daylighter Covers.
  46. Pics and Videos wanted for offroad video
  47. what WAS this part i got replaced?
  48. pic request:
  49. 96 Service Manual
  50. tire size..
  51. hey all
  52. Engine Computer needed
  53. Pull on hard braking.
  54. Another ?? Manual window sticking....
  55. Adding an Automatic lock kit?
  56. washerfluid bottle
  57. radiator question
  58. Wilwood All Wheel Disc Brake Kit
  59. Removing Cat.
  60. parts compatable?
  61. arizona meet
  62. Auto start for 07 ???
  63. Running boards
  64. PRODUCT REVIEW: Agri-cover Lite Rider Tonneau Cover
  65. no power/backfire/shake!!!
  66. Scanner not communicating
  67. Radiator tube pressure cap thing.. need help!!
  68. steering pump woes
  69. '03 5.9 QC drinking coolant
  70. More power
  71. Stupid Mistake Leads to Major Problems
  72. 2008 Dakotas?
  73. COLD START FINE--WARM START RANDOM
  74. 00 steering question
  75. This ol'cat has a pretty nice...
  76. 408? what do i need to to this.
  77. 2008 Dodge Dakota: Now With Crate 'N Go
  78. Im NOT having a good week....
  79. grill???
  80. Dakota '97 transmission assembly guide
  81. starting problems
  82. Head Bolts
  83. FS: Powerdyne SC Kit..
  84. Spark plug change
  85. a/c freezing up
  86. rear brakes locking up
  87. Anyone out there with 20" R/T Wheels ?
  88. Intermittent braking problem
  89. What engine to get?
  90. Ahh! I need a new clutch...
  91. Hello everyone...
  92. Replacing Engine (03 5.9L R/T)
  93. quit running//no start
  94. 2001 Dakota 4x4 differential question
  95. Off Roadin Pictures! 8/11
  96. NV3500 to HD or 2WD to 4WD hybrid/combos?
  97. 4.0 - 3.9 - 4.7 Different bellhousing bolt patterns?
  98. 2001 Tranny
  99. 3.9L low milage...
  100. Poor handling over pot-holes?
  101. Vent Problem??
  102. Rusted out oil pan
  103. dakota won't start
  104. 2001 dakota
  105. Shocks
  106. '00 Dakota 4 Wheel Low Problems
  107. 2000 Dakota overhead console readings possibly inaccurate
  108. a/c blows hot air - 95 dakota V6
  109. 05 Dakota 470 miles!
  110. New Here
  111. 88 4WD Dakota questions.
  112. Buying
  113. Bad tranny's?
  114. get out and VOTE!!
  115. Weld Mountain Crushers
  116. Front end noise help
  117. V6 or 4 cylinder???
  118. Dakota Videos
  119. Help Over-torqued Lower Ball Joint
  120. 94 Dakota Cruise Control Problem.
  121. Jack Rabbit tonneau cover
  122. Need Help deciding on Dakota
  123. Herc-U-lined Dodge Dakota Truck Bed (My review w/pics + First post)
  124. Dodge Announces Pricing on 2008 Dakota
  125. EXHAUST LEAK???
  126. Hard shifting
  127. Junk Dakota...need suggestions
  128. 2003 quad cab 4x4 with a 5.9
  129. Speedometer does not function any more
  130. altrenator mount & bushings
  131. 93 dodge dakota windshield wipers
  132. drums to rotars?
  133. Need Help with Diagnosis-RPM surging and dropping
  134. Removing the 4x4 stickers
  135. Good Drag racing rear end
  136. Fuel Injection is Overrated
  137. 02 dakota interior light problems
  138. The Dodge 239 and the 318,(3.9l&5.2l)
  139. Brake/Turn Signal Problems After Trailer Use
  140. Having serious problems!!
  141. to buy or not to buy?
  142. PCM Problem??
  143. Upgrading to OEM 16" rims
  144. A LITTLE HELP PLEASE?
  145. Seems to good to be true
  146. Increase performace???
  147. What are my options?
  148. question
  149. Mild tuning 4.7L
  150. Need Suggestion for what to do w/ my broken Dakota!!
  151. 99 4x4 tranny woes
  152. Headlight switch screw
  153. Hey Guys!
  154. 4.7L what version ?
  155. Air Compressor quits?
  156. heater doesn't work
  157. Door Latch help NEEDED
  158. Superchips for 4.7L V8
  159. 3.9 v6 bypass fitting
  160. 2008 Dodge Dakota QC with 3.0L Diesel.
  161. Cat Removal question
  162. 4x4 4.7 gas sucker
  163. Hey ya'll, new member
  164. 89' V6 Noise follows RPM - harsh rattle
  165. Weak Brakes
  166. high idle on a 1991 dakota
  167. Front rotor/hub replacement
  168. Dakota 4X4 (activity indicator light)
  169. motor cuts out
  170. motor cuts out
  171. Just got my DAk, New here
  172. 20" DAKOTA RT WHEELS/TIRES
  173. 87 d50 project
  174. 2001 4.7 overheated and now doesn't start
  175. Reverse glow gauges
  176. overheating
  177. Dodge vs Ford (Video Inside)
  178. center caps
  179. can someone please help me?!?!
  180. 1991 "Lil Red Express" Dakota... Help please!
  181. newbee w/ some Q's
  182. Looking for canopy and parts
  183. Dakota 4.7 Fuel Ping
  184. Headlight problem
  185. Shelby Dakota
  186. Dakota Issues - Need Help & Advice Please!
  187. cargo in bed
  188. Dakota EVAP code 442 & 445
  189. paint and warranty ?'s plz help
  190. NO LIGHTS HELP
  191. LIFTED DAKOTA
  192. Trany promblem. 1st and reverse slipping. Help?
  193. DAKOTA PROBLEM
  194. Axle ratios
  195. water problem
  196. differential
  197. Redesigned Front End?
  198. loss of control?
  199. F/S 2002 DODGE DAKOTA V8 BLIZZARD PLOW
  200. tranny stuck in drive!
  201. What is it about.....
  202. Is it a truck thing?
  203. 1990 3.9 no start
  204. 93Dodge Dakota Squeaking +Staulling-HELP!
  205. Brake Lights Not Working
  206. Camshaft
  207. 6mo Old Dakota
  208. How reliable are 2nd gen dakotas?
  209. help
  210. Bed Dimensions?
  211. Hey Guys! New Dakota ONLY site in the works. Let me know what you think!
  212. Mopar EVS alarm system
  213. 2000 NP 231 Transfer Case
  214. Add cleats to the bed?
  215. 2002 dakota 4.7, automatic, 2-wheel
  216. Check engine light on. Got 2 codes
  217. loose steering---99 Dodge Dakota
  218. The 2001 model is actually a Gen 3 Dak!
  219. '07 Laramie - Auto-Dimming Rearview Mirror?
  220. Cam suggestions?
  221. hope u like
  222. All Wheel Drive
  223. Heater Core For Sale
  224. Shetty gas mileage
  225. New to Dakota - Buying
  226. 2008 Dodge Dakota review
  227. removed negative cable.now wont start
  228. Question for those who know the 4.7L
  229. new water pump... still overheating
  230. Broken Rockers
  231. Looking for a transmission
  232. Thinking of selling/trading...
  233. New Dokota Sounds Sweet!
  234. locker
  235. Shimmy diagnostic help
  236. Dakota HP ?
  237. New to Forum and Dodge
  238. Non Magnum engines
  239. Hi. Question about mirrors
  240. ECM upgrade?
  241. New Member, looking for HID headlights
  242. Check these out! 2006 20" Dodge Ram wheels!
  243. Electric tailgate lock for sale-Used
  244. New Dakota Owner
  245. Need advice
  246. 340 dakota
  247. dakota timing
  248. '94 4x4 Lever Won't Move
  249. Lock me up baby!!!
  250. Computer compatibility.
