View Full Version : PCM & Fuel Systems
  1. Help with pcm and charging system!!
  2. replaced fuel pump
  3. 05 stratus coupe cluster
  4. 02 RAM 5.9L PCM Problem?
  5. A/C issues with 04 Cummins
  6. Replace PCM on 02 Stratus
  7. Superchips 3815 Now supports the 98-03 3.9L, 5.2L , 5.7L and 5.9L motor
  8. Need Opinons on best chip for a 99 3/4 2500 360
  9. SLR motorsports chip
  10. 2004 electrical gremlins
  11. PCM
  12. Hypertech Max Performance?
  13. Idling high and rough, No Acceleration Power
  14. 1999 V6 ram 1500 fuel pump doubts.
  15. PCM & Alternative fuel
  16. Fuel guage just went south/how to fix it?
  17. 2001 Dodge Ram No Start
  18. code p0171?
  19. Fuel Pump
  20. Fuel Pump
  21. stalling!
  22. fuel probs
  23. O2 Sensor
  24. fuel on start up problems
  25. E85 fuel 'secrets' from Hot Rod magazine
  26. PCM for Dodge Ram 1500
  27. 97 v10 Ram Needs CPR!!!
  28. Which programmer for 2008 Ram 5.7L Hemi
  29. SCT
  30. please help with my ram!!!!!!!
  31. 2008 Ram MDS Info....
  32. Superchips?
  33. chip/module
  34. Dodge Magnum Cluster Fuel Gauge Stuck on Empty
  35. programming new keyless transmitter
  36. SCANTOOL FOR 1995 OBD1 STRATUS?
  37. 95 Intrepid No Start, Interm no "Check Engine Light" at key-on
  38. better gas mileage tips?????
  39. What type of sensor is the crank or the camshaftsensor
  40. fuel problem?
  41. bully dog programmer for hemi.
  42. flashing
  43. not a pcm problem
  44. fuel problem
  45. fuel pressure test ?
  46. '95 Neon Fuel Pump not running
  47. PCM problems
  48. 2001 Durango and flashing
  49. hi
  50. PCM Code 420 Help
  51. 2003 Dodge Ram 1500 5.7Hemi P0340 & P0344 codes
  52. IAT sensor
  53. 2003 Grand Caravan Stalling -- help...
  54. 2005 3.7L V6 Ram 1500 JET chip
  55. Using Diodes to increase power !!!!!!!!!
  56. 99 5.2L bogs out over 60
  57. 2003 Dodge Ram 4.7L Idle problems
  58. real video of burning inside cylinder
  59. Autospeed on many factors of ign timing
  60. Turbo cutout ?
  61. SPEED-O- READING 153 MPH
  62. Help identify carb
  63. 1996 Dodge Ram 1500 Full size van will not run
  64. mopar 4 barrel race throttle body
  65. Wiring of Fuel Pump
  66. Fuel or what Problems
  67. '06 2500 5.9L 4x4 w/p0191 code
  68. how do i test fuel pump
  69. Erratic idiot lights
  70. 1979 dodge 360
  71. computer flash to stage2
  72. Interesting Lack of Fuel Problem
  73. 2004 SRT-10 Removing Immobilizer
  74. PCM 2003 Dodge Caravan
  75. 1995 Jeep ZJ 5.2 v8 PCM
  76. 1993 multipoint FI.....PCM problem ???? or
  77. 1970 dodge superbee-carburetor not getting gas
  78. Tuning software
  79. programmer for 03 ram
  80. PCM Flash?
  81. Superchip's 2007 Hemi truck released!!!
  82. jet experiences?
  83. PCM connectors
  84. computer swap?
  85. Got a tec. question?
  86. HELP!!! fuel problems
  87. PCM Help!
  88. trouble code questions
  89. Power chips
  90. PCM Harness in 2005 Magnum
  91. 5.7 Hemi into a Jeep YJ. Help please.
  92. 98 Ram 360 Fuel Problem
  93. 97 caravan 3.3 auto cel on
  94. Programer for 07????
  95. 318 and 360
  96. Getting more fuel?
  97. 2004 dodge fault code 0341
  98. VAPOR LOCK
  99. My '01 1500 engine light is on!! need help!
  100. Gremlin in my 96 Stratus
  101. 2001 V-10 Running Issue
  102. what's the different?
  103. 545RFE Transmission?
  104. high rev on start up.
  105. Fuel Economy
  106. Authorized mod. sticker on new 2007 radiator
  107. dead gauge
  108. MAF or MAS 3.5l Magnum
  109. PCM Location on 03 Ram 3500 Q.C. ???
  110. pcm for doge 98
  111. engine error code 2004 ram hemi
  112. frustrated
  113. Which programer/chip/or module ?
  114. Code P0455
  115. swapping 97 360 magnum into 1985 crewcab dually
  116. computer tuning Shelby durango
  117. 408 Stroker S.O.S.
  118. In reference to TCM's
  119. computer reset?
  120. Which Chip Should I Go With?
  121. determined to be rich-ramcharger
  122. Changing Vechile from Fuel Injection to a Carburetor
  123. Recall
  124. fuel problems!!!!!
  125. engine swap for drag car
  126. 'Check Engine' Error code help
  127. Electrical problem, Clicking relays,Wont start!!!
  128. Fuel Injector Question
  129. re 96 dodge intripid fuel injection problem help
  130. Just got a hypertech...
  131. 95 neon misfire
  132. looking for flashpaq help
  133. a/f Gauge wiring helppppp me
  134. Air in fuel system on '92 dodge cummins
  135. PO202
  136. Sharing a Superchip Flashpaq?
  137. can I do this to magnum fuel rails
  138. Neon fuel cell sending unit?
  139. MMO.....
  140. Hemi trucks/missing options after update
  141. 06' SC Hemi issue fixed (upload issue)
  142. B&G Flash Or Hypertec III
  143. Superchip no power gains?
  144. Superchips - Flashpaq
  145. ram died- fuel problems
  146. JET STAGE 2 OR MOPAR PCM
  147. Crane Amplifiers and coils for Neon
  148. I need help with cam and other mods
  149. Gas mileage 96 neon
  150. sentry key
  151. Fuel Injector question...
  152. PROBOOST performance chip
  153. 06 Ram Torque Management!
  154. Fuel Pressure Problems
  155. Fuel/starting problems
  156. Good Chip for Magnum
  157. superchip questions
  158. throttle bodies
  159. Tornado Fuel Saver?
  160. HEP ?
  161. PCM for a Neon
  162. Mopar PCM
  163. Mopar Performance PCM - Where to buy?
  164. Module for diesel
  165. Multi-Displacement System on Durango Hemi
  166. SUPERCHIPS Tuner >>>>>>
  167. Diesel chip programmers
  168. Airplane Fuel
  169. MDS? What?
  170. Hypertech II
  171. pcm
