View Full Version : 2nd Gen Neon
- 02 stuttering/sputtering/hesitating; never stalling
- What did I do???
- Transmission Cooling Lines
- thrmostat
- 2001 neon 0340
- 2000 dodge neon .. idles fine ... bogs apone acceleration
- 03 Neon blinking lights and cold heater
- main motor mount bolt doesn't thread properly
- Neon died. codes 0390 0391
- Why is water (?) coming from my muffler (?)
- Any tutorials somewhere to learn the maintenance tasks?
- tranny cooler
- Loosing my mind and walet.
- Is my transmission blown?
- Climate control
- OEM Part # for Molded Splash Guards
- broke a hose connector??
- 02 dodge neon
- 03 Neon sxt Fuel pump help
- 2001 dodge neon
- 2001 dodge neon problems
- Dimming and brightening lights: Bad alternator or something else?
- Question about engine alignment procedure after installing new motor mounts
- 05 SXT Neon Sputtering/ worse in iddle or A/C ON
- Just changed the right side lower torque strut and 2 days it's already toast?
- 02 Neon auto wont' shift to 2nd
- 2000 Dodge Neon Rev Limiter Problem
- Dirty power window switch fix
- lights not working - '01 Neon
- Bought a second neon for parts, unsure which car to fix up.
- '05 Neon SE runs rough
- not a normal overheating issue what could it be
- Power windows only operate with engine running
- 31 th trans ratios
- 2005 SXT Fog Light Wiring Harness
- Whisping noise on acceleration 02 Neon
- side repeater light does not work
- 03 SXT Transmission problems?
- Washer fluid pump comes on w/ lights
- 2005 sxt sputters
- Where does this wire go
- 2003 Neon Overheating
- 2005 Sxt Stuttering Problem
- '04 Neon 2L Rev's High & then Idles Rough After Valve Job
- WEIRD Neon Issues
- 2004 SE cranks no start no codes
- 03 Problems - Laundry List - Need Help
- Power lock problem while car is off
- thermostat torque spec?
- 2000 a/c
- a604 41TE 2003 dodge neon transmission rebuild
- radiator fan?
- Hood and Pass Fender needed
- Urgent help needed for No spark after all sensors and ECU replaced.
- Looking for good, cheap, projection headlamps.
- how to inspect middle/rear motor mount.
- Odd noises... Please help, so tired of this
- 2005 problem that I am at a loss with.
- Finally almost fixed... one last problem (creaks/rusty door hinge sound)
- When do you call it a "junker"? How many repairs/cost?
- 2004 SXT AC not working...
- Car alarm goes off everytime I try to start my car
- 04 neon no throttle control
- front end noise info
- Requesting Assistance Diagnosing Noise
- Can't find ac leak!
- Factory 4-disc changer to aftermarket head unit
- 2001 R/T low idle and lagging
- 2002/Auto/2.0L Back-up lights don't work
- Harness Compatibility
- 5 spd 2000 neon wont go into reverse
- Window Regulator 02 Neon
- 05 Neon SXT, HELP! No Buss, cluster ights on
- bubbling noise
- Watch this Dodge Neon tear it up offroad.
- Why will a 2003 cylinder head not work on a 2002 neon
- neon not starting
- Dodge Neon 2004- no Reverse light
- Dodge Neon 2004- Error Code P2026
- Missing License Plate Light
- power window problem
- Pcm?
- 2000 Neon Tachometer and Cruise Control Problems
- 2004 Neon engine whine when idle
- Underhood Button
- Injector problem please help P0204!
- 2004 Neon - no reverse
- coolant temp sensor location
- 2004 SXT Dashlights, Taillights, Stereo went out
- Ticking in motor!
- Sway Bar End-Links Noise, money-pit of parts, in-depth...
- 2005 Neon, dies when warm, won't start
- Problems with P0344 code always coming up
- Brakes Hissing After Pumping Them
- 2004 o2 sensor
- What mods would YOU make with a 3-4k budget
- 02 - 05 Dodge Neon SXT Body Kits
- 05 Neon Manual transmission questions
- Head gasket may be blown, Your thoughts?
- MTX install.
- Adding a Fuel Filter?
- Valve Gasket
- need help..my 01 neon suts down when temp gets closed too 200..
- wheels/ tires
- Oil Leak
- 2004 SX 2.0 starting issue
- Upper and Lower Strut Mounts
- magnum head swap
- Replacing Lower Control Arm Bushings
- struts
- Help granny with a tranny
- 05 Neon Mopar lip kit!?
- Part Number for the "Engine trimming/billet"
- 2nd Gen Carpets?
- leaking tranny fluid
- key fob/receiver swap?
- 2004 dodge neon no heat or air
- Dodge Neon / SX2.0 Halo lights installation
- trouble with my ladyfriends 3 neon se tranny
- how do you reset cam after timing belt slipped
- 00 neon help please anyone
- Problems with a 2001 Dodge Neon
- Front-end clunks (all the basics seemingly check out fine)
- clutch sensor problem please help CEL 0833
- Front crank seal installation help... a couple questions.
- 2005 Neon SXT SKIM/ VTSS trouble, Help!
- How do I bypass a neutral safety switch on a 03 neon?
- P2074 Vacuum leak after radiator replacement
- 03 Neon Dashboard Disassembly
- 01 Neon base engine misfire, rough run cold, worse hot
- 2004 SXT CPS and oil leak/head gasket?
- No park lights or guage lights help
- P0340 and P0420 Codes After Blowout
- 03 SXT Overheating - Again...
- 2000 Dodge Neon SE, Parking Brake problems
- Stock Sway bar MM size
- code po517
- possible to over torque engine mounts? crazy vibrations at idle+steering wheel
- Help I can't figure it out
- Few noises (thuds hitting bumps) under ~15mph + growling/whirring at >35mph.
- strange rumbling noise in forward motion (only) and increases upon accelaration
- Surge on Acceleration
- 04 Neon brake issues
- 01 neon trouble help!!
- P 0522 code and oil light
- 03 Sway/Drift
- has a mind of its own, help me
- 2001 Neon K4 Subframe Question
- motor in limp mode 5spd tranny please help :)?
- who's running what struts?
- 2003 SXT - lots of front suspension noise
- 2004 Dodge Neon hard to start in cold temp
- Surging at 40-60 mph
- Water Pump
- Burning that midnight oil...
- 2000 Plymouth Neon loud suspension Noise
- neon pulling to the right
- I'm Back
- Did 01-02 ACR come with speakers?
- Farewell Dodge Forum
- Help!!
- Defroster not working. Blower fan OK
- 2002 Neon transmission trouble
- Number of drive belts 2001 Neon
- 02 Neon partially submerged...
- book hours
- '04 Neon SXT starter issues
- start up troubles and vibrations
- 2004 SXT Trans Problem!
- Electric motor vents question
- 2005 dodge neon sxt leaking oil around targe magnet
- 05 SXT possible tranny issue
- 2003 dodge neon sxt
- 2005 Neon died
- 2nd Gen Front end Damage
- Power steering Hose
- 2002 Dodge Neon Transmission Issues
- 2005 SXT Poor Gas Mileage...I'm stumped!
- No Crank No Start
- Mopar Engine Mount Numbers
- need help! cold start/subzero weather
- can u bypass the speed censor
- What broke on my neon?
- Low Oil Pressure???
- 00 ATX differential
- How do you make vertical/horizontal adjustments to trunk lid?
- Lights dim/flicker
- can you pls check on your radio/clocl
- '05 Neon SXT front wheel bearings
- help ignition problem
- power steering
- 03 neon - trying to pull out radiator
- 02' Neon Tranny Issues
- IOD fuse
- help rattle when starting
- is the coolant bubble test the final word
- 2001 transmission question
- Help finding a Cable 2000 Dodge neon
- Help finding missing hose on this pic please!
- Headlight only running on high beam?
- 05 base model grille replacement
- Slight issue after cleaning IAC valve
- Buy or dont buy
- has anyone did a rear disc break conversion using srt4 setup?
- Pt gt 2006 is 3500 a good price?
- ignition key comes out at any position
- 2005 sx 2.0 power pulsing
- 2005 dodge neon rough shifts from 1st to 2nd
- ebay quick struts
- Limited RPMs
- TERRIBLE gas mileage, 2003 SE Auto
- Lights Fix
- No reverse
- neon transmission trouble
- 02 transmission interchange
- throttle body questions
- Neon 2.0 Lifter Clatter
- Back again. '05 Neon idling rough even after lots of repairs.
- 01 Radiator Replacement
- brake issues
- 2003 neon handles awful on bumps.
- 2003 Dodge Neon
- o2 sensors
- best brand oil for my neon with 150000 miles
- Grinding in my 03 neon SE
- Clutch Pedal Position Switch
- When To Change a Battery?
- So my car finally runs but doesn't move
- 2004 dodge neon tranny problems
- fuel injector issues - 2001
- 2005 Dodge Neon SXT Humming Noise
- 2000 neon bad bearing in pulley
- musty smell
- lowering kit question
- Need help with knock sensor
- HELP NEON 2005 Check Engine
- trans shift solenoid replacement
- P0441 - Please help - need to get e-tested
- 2000 Neon Idle adjustment
- Windows Fogging Inside ?
- 2005 Neon door ajar
- I need technical information!! please!
- oil
- Fog/Daytime Lights
- 2005 neon sxt making weird noises
- Noise while coasting from front wheels not a bearing
- New to here,own a 2005 Dodge Neon sxt
- New to forum - Many Dodge Questions
- just bought a 05 neon sxt
- Automatic trans wont shift in reverse, no drive
