View Full Version : 2nd Gen Neon
- 2001 Dodge Neon Blown Cylinder? Need Help.
- 2003 Neon SE Power window/lock conversion help
- Lightning Bolt warning light on Dash
- Help me clean my garage out
- 2003 neon sxt stuck in 2nd gear
- Highbeams wont turn off?
- Door Lock latch/actuator
- LEV Catalytic Converter 02 Neon R/T (PIC)
- 2000 Dodge Neon Vibration
- Power door lock problem 2000 Neon
- 2002 dodge neon accelerator problem
- Dodge Neon 2004 SXT 2.0L - P0700 Code
- headlight wiring harness
- what does this mean?
- Tail lights wont turn on but head lights do..?
- need some help putting sxt back together
- Putting a sound system in 2001 Dodge Neon RT
- Dodge neon door lock conversion plz help
- help please idk if trans or belts
- Pacesetter Header & Exhaust?
- 2003 Rear Brake Issue
- synthetic motor oil?
- 04 SXT CEL code P0733, with no third gear.
- rear defroster
- good bye
- 03 neon wont start
- Water Pump Leaking...
- Oil light...now won't start
- Radiator question.
- Power door locks 2004 Neon RT
- P0441 nvld?
- Adjustable cam gear NA sohc 2.0
- headlights?
- Neon trans/TC concern
- Multiple issues
- replacing trunk lid brackets on a 2005 dodge neon
- 2004 RT with rear end chatter
- Help with Codes 0340 and 0579
- 2004 neon rear door
- 2005 dodge neon se
- Bucking at a stop
- Car wont go into gear
- Transmission Mount repair...
- Replacing Headlights..
- Bad A/C High Pressure Switch Freon Recovery Y/N
- rusted muffler
- P0340 - How to trigger it?
- Input/output sensor 05 neon
- 02 dodge neon sxt idle issues
- Noise coming from front suspension!!?
- 2004 Dodge SX 2.0 - girl with car issues and no clue - help!!!
- i need an electrical genuis!
- New Throttle Body?
- 2000/2001 Neon Starter Motor Replacement . . . help!!
- 2001 Neon front wheels locked up
- 2003 neon transmisson noise
- OEM or After market?(lower arms and engine mounts)
- 02 Neon Help
- 2000 Neon ECM problems
- Where is location of the power steering pressure switch on Neon 2000
- Neon 2004 stalling
- Couple questions
- Not Too Loud
- Exhaust leak or neon engine tick?
- Is my rear wheel bearing going out?
- Where's ground strap go? (left rear)
- Headlight Problem
- Replacing ignition coil+plugs?
- 2005 SXT With starting problems....HELP!
- 01 dodge neon AT Trans problem
- Window Relay?
- Help Neon cluch problem
- 2005 Dodge Neon SXT excessive oil burn and rough running
- 03 neon sxt FRONT FACE
- I am done rebuilding the engine and stuck on a vacuum line!!
- easier way to change headlamps???
- Oil in spark plug tubes
- Rocker panels, Rear quarter panels other misc parts
- HID Installation Questions
- 2003 Dodge neon wont start sometimes
- 2000 Neon Will Not Downshift To Pass (etc)
- coilovers
- clutch issues!?!?!?!?!
- Body valve!?!?!
- Aftermarket tail lights...
- trouble codes 456 and 563?
- 2005 Neon STX Problem help
- replaced ignition rod still no start?
- is it the transmission or the gearbox?????
- Door handle gets stuck open
- Tracking down a transmission issue
- Putting ABS on a non ABS car.
- Canoe/Kayak tie-down points?
- 2000 Neon pdc replace
- '04 - coolant in transmission
- Nitrous question
- just wondering...
- Steering wheel shakes..
- 2003 Neon Rough Idle
- 2000 Neon intermittent p0340
- Official DodgeForum.com decals...
- want to remove the bumper absorber
- neon jsut stopped running... no sounds or anything.
- oil/liquid? in pcm connector
- Will 98 Neon clock spring fit into my 2000?
- Transmission issue
- steering wheel vibrations
- PCV tube?
- Putter at 2500 rpms
- Automatic trunk not working
- 2005 Dodge Neon SXT accelerating really loud.. motor mount?
- 02 Dodge Neon
- 05 neon fog light replacement
- 02 neon tranny compatibility
- AirCon Issue...
- window noise after replacing speakers
- Neon hesitates when cold, poor starting?
- Electrical??? Stalls after we turn on the headlights.
- Poor gas mileage
- Something grinding
- What else do you drive?
- Starter wont engauge on first try at times
- 2002 R/T valve question
- Major Tune Up List
- Charging System Issue, Need Help
- Injector Sizing
- looking for what this is called and where to find it :)
- would it be possible?
- 05 auto trans issue
- front wheels vibrate while braking
- update to my solenoid issue but new question
- Bad AC High Pressure Switch Connector
- fusebox 2001 neon
- 2001 auto transmission question....
- Problem with my 05 neon code p0700
- A.i.r. pump Leak detection 2002 neon
- waterpump change
- need some tips and advice.
- another stupid wiring question
- Is this car worth it anymore?
- Water in the door.Strange.
- Replacing speakers in 04 SXT
- Help ME!
- HELP! new to the forum 2000 dodge neon
- A/C Condenser and bumper cover removal.
- 2000 Neon computer replace
- Window Tint cost question
- Solenoid Problem
- 2000 Dodge Neon Trans
- Seeking perspective before taking to techs
- died after going through water
- engine codes: 0622, 2503, 0032
- Did a big pothole hurt my suspension?
- Thinking about buy ebay projector fog lights.
- Just bought Texas 02 Neon Sxt. Tranny Help
- 01 Neon starting issues
- Reviving a thermostat?
- flash floood yay...
- oil light
- Will 2005 SRT Design facia fit '03 SXT
- car turn off when i turn on ac
- Still having problems.. HELP PLEASE
- New muffler?
- Can A Trown timing belt mess up a valve ?
- Wheel Bearing- left?
- Possible? or nonsense fake Video game BS??
- No reverse
- race neon
- Overheating
- mjyost
- evap canister 2003 sxt
- SRT-4 Car show Oct. 2011
- cylinder head help with 2002 neon R/T
- 2003 SXT 2.0 Making Grinding during acceleration.
- Paint Code PRH - 1 of 2
- Help with strut fitment!
- Can i put a turbo on my 2002 dodge neon se 2.0?
- Shop says can't do alignment, wtf?
- oil light
- the tortoise and the hair
- Is front end alignment necessary
- Cold Air Intake
- rear drum to disc conversion
- 03 Neon SE Sparkplug wireset??
- First time changing a timing belt.
- Compatible PT parts?
- E-brake problems >:(
- 2.4 head on 2.0 block
- Tie rod end remover
- intake help
- another problem!!!
- Transmission sensor location
- 2004 dodge neon es, advice?
- timing belt question(s)?
- refinishing rims.
- Just crashed need radiator tie bar
- 2002 RT timing belt
- 05 Neon tranny leak
- cv axle replacement
- 2004 SX Warm Rough Idle
- Totaled 04 R/T
- Car won't start not sure if its ignition
- 2003 SXT brakes
- 2002 engine in a 2004 car?
- Hi first of all, 2004 Neon with a new engine wont start!!
- not locking in park
- not shifting gears (help please)
- Question about radiator fan
- 2000 neon 95 engine conversion
- 2nd Gen Neon Head Unit For Sale
- new here. need help
- 2001 neon timing belt issues
- myday
- both front turnsignals flash when turning left or right
- No Spark
- Hard to figure growling noise
- need some advice
- Motor Mount & Exhaust Leak
- HELP! Electrical Issues
- Radiator and Transmission fluid mixing...
- new interior
- The best wiper blades?
- PCV valve grommet question
- Rattle Sound
- cleaning engine bay
- 2004 SXT Cooling Fan/ AC Issues
- Trying to find the brake booster line
- 2000 camshaft postion sensor?
- Needing assistance with backup light switch
- exhaust size?
- 2000 neon bogging, misfire and back fire through intake
- Tie-rod/toe angle question.
- Water leak
- help with cel.
- Is my exhaust leak effecting mpg/performance?
- A/C Recharged Today
- 2nd gen neon system install question
- 2002 Neon Transmission questions
- 2001 dodge neon shifting problem
- My 2000 neon stalls
- lights don't come on when i break! help!
- Fluttering noise , 03 neon
- New!
- Shakes upon shift
- Prob with replacement trans solenoid pack
- AC refrigerant refill
- Omg! Help please
- 03 neon2.0 help!
- problem with code!!!
