View Full Version : 2nd Gen Neon
- Timing belt and water pump replacement
- Serpentine belt tensioner problem
- Signal switch buzzing
- Coolant flush?
- Ugrading rims
- Gasoline White Paper
- Hood switch??
- Neutral without key
- 2005 sx 2.0 - 2k RPM limp mode occasionally..
- 2003 Neon parking light bulb replacement
- 2002 dodge neon turns over but wont start
- 2002 dodge neon fusebox diagram
- Spark Plug Mini Tutorial
- AAA Tests Top Tier & LAC Gasoline Engine Deposits
- 2003 Neon SXT - Throttle Position Sensor
- 2001 Plymouth Neon
- My 2001 Neon has a case of the shakes....
- Need help 2002 dodge neon sxt
- How To Replace 2000 31TH Tranny TCC Solenoid, Filter, Adj Bands, Full Fluid Exchange
- 2005 Neon SXT, new battery, power to all components, won't crank
- Castrol ATF+4 On Sale
- 2000 Dodge Neon Won't turn Over
- 2000 Dodge Neon
- 31TH Transmission Pan Bolt Size
- 2004 dodge neon wiring diagram
- Please help?!?
- 2005 Neon cutting out and runnnig rough
- 2004 SXT overheating
- 2005 Neon, no gauges at all
- 2000 Dodge neon neutral safety switch
- Need advice on ignition problem
- Rear alignment shims (in a pickle)
- I guess no one posts here anymore to help out!
- Clunk noise on drivers side only 2003 Neon SXT
- Neon clutch problem
- 2002 Neon failed smog
- upper & lower
- Fuel mileage
- 04 Dodge Neon won't start
- Steering snaps back and fourth.
- Will start but won't stay running. Please help!!
- Marvinsgenie
- new to me 2005 SXT neon
- 2004 dodge neon motor problem?
- New to me Neon - lost key
- 2005 sxt, manual: Any one know what these are ?
- sohc turbo manifold??
- transmission shift cable
- 2005 neon sxt trans leak question
- 2005 neon 2.0l won't start.
- 2003 SXT no fire, at my ropes end...
- 99-00 neon differences
- Neon help
- neon runs terribly
- Been Awhile...
- 2000 Neon starts, revs itself up & dies...help!
- Lost power plus new whine
- 03 sxt 2.0
- no idea what i did wrong
- 03 Neon- Help me please
- Rear Bumper troubles
- 04 dodge neon speaker stop working
- New to scene. Need some opinions
- 2003 dodge neon help
- Oil bypass-filtration?
- Power Steering Tensioner Pulley
- P1299 Code after replacing starter
- Aftermarket seats???
- 2003 Dodge Neon po480code
- Idle at stop drops to 500 rpm. Car shakes.
- Out of my element, could use some help!
- Vehicle issues
- Issues with my neon...HELP!
- Electrical issue, cluster, chimes and dome are off.
- Please help
- Power steering Trouble??
- Eletrical
- Ignition Lock Replaced - Cannot Remove Key Now!
- ball joint heat shields
- Newbie- Wheel and tire size and front bumper piece
- Gas leak. Fuel pressure regulator?
- Strange behavior of the car
- 2003 Neon timing belt broke - bent valves
- Car wants to die.
- Problems with Acceleration in a 2003 Neon
- Additional remote programming
- transmission ID
- got a few strange issues.
- 2000 Brake noise and engine rumble help needed
- 2005 dodge neon questions
- Step Daughters Car with P0304 code
- Engine rpm drop at idle/oil pressure light comes on
- CE light and Batt light after CAI install
- O2 Sensor wiring
- Cv joint/axle question
- new halo headlights!! installation help
- Neon inner tie rods
- Front end noise - frustrated
- Gas filler neck
- brakes noise and getting water inside car
- 00 Dodge Neon Defroster and Heat Wiring Issue
- Power steering pump pulleys
- 2003 neon instrument cluster bulb part number
- Too many problems, Too little money..
- Power Steering Pump Suppliers
- Loose and sticky PVC hose
- Stall after a few minutes of idle
- Source for PCM replacement
- Re-wiring Passenger Side Headlight & Blinker
- '03 DOOR light always on
- hello everyone!!
- 01 Neon wont start.
- Rear brakes/drums
- Refinishing 15 year old wheels
- Need Elec Part Name & Info
- not auto unlocking just a few quick ?'s
- Where can I buy the HVAC center bezel light bulbs?
- bucking / misfire
- Need advice , need a bushing for clutch cable
- 03 Neon A?C
- Misfire cylinder #2, but only when idling
- Need help understanding Remote Entry Receiver
- P0038 FOR Dodge Neon 2005
- 04 dodge neon rough idle
- Headers Wont fit :(
- New to the Neon
- P0601 Code and Bucking on Freeway
- How much air?????
- 05 2.0L SOHC diesel turbo
- P1391 and P0340 will not start
- 2001 and 2004 Neon
- Air System (HVAC/AC) randomly blows less air
- New member with a tranny problem
- new front lower motor mount replacement question.
- Rough Idle When Stopped
- Air Filter Box Cover Screws - 2005 Neon SXT
- Factory Subwoofer
- 00 Neon Fan Controls not working(HVAC)
- Selling some stuff...
- Neon engine problems
- Compressor venting during charge; still have 10oz to go
- Over $200 for a spare key!!!!!!!
- Make up filter
- Looking for some R/T skirts
- Stumped 3 mechanics so far
- 2004 neon won't crank when hot out
- PCV Question
- 200 Neon help Please
- Need Transmission Las Vegas Work Swap or Rebuild
- 04 neon wire id
- 2004 Automatic transmission shift cable.
- 04 sxt electrical problem
- I need to replace my left front fender.
- Hi Pitched Chattering when in reverse at idle
- Motor Mounts, Mushy Brakes & Vacuum - One Big Crazy Connected Mess
- Possible purchase
- Question HELP NEEDED PLEASE-- 2001 Dodge Neon Problems ????????????????
- Rear Wheel Locking Up *********
- Will not start
- 2002 Neon SE with 2005 Transmission How to replace TCM
- 2003...Head Gasket or Head?
- Rear struts for 01 R/T
- Transmission Oil
- manually engage comressor clutch
- 2004 Neon Bucking in Overdrive, but okay in 3rd Gear
- 2003 Neon SXT exhaust replacement
- need help also
- windshield washer pump problems
- Dashboard Paint ?????
- Steering Wheel Locking !!!!
- Radiator
- Wheel size..
- r/t to sxt tranny
- brake light problem
- 2005 Neon, No Crank, No Start
- P0443 2004 Neon SXT
- head gasket?
- neon fan blower making a noise
- Mopar lip kit for dodge neon
- 2000 neon completely dead . Please HELP!
- Fuse error but no code?
- Cam sprocket bolt
- 2003 Dodge Neon
- 2004 Neon SXT has little to no compression
- 2005 sxt dies randomly, please help
- 2003 SXT Idling problem
- 2005 dodge neon clunking HELP?!
- bigger map senor???????
- 2005 Neon
- Accelerating Problems on 2000 LX
- Where the heck this sound is coming from?
- Trans Fluid affected by WaterPump/TimingBelt change?????
- Compatible Manual Trans for Neons ?
- Engine missing
- Cyl head ?
- single fan vs dual fan radiator
- Please Help!!!
- suspension work
- Shaking while driving
- 2005 SX 2.0 Transmission issue.
- 2000 Dodge Neon high pitch whiny noise
- 2003 neon rt , having starting problems
- 2004 Dodge neon PLEASE HELP??
- sticking lifters?
- 2004 Neon SXT 2.0 Oil Pressure Sensor
- Transmission Problems?
- 2004 Neon Motor Mount Question
- Horrific banging/knocking noise coming from the rear
- 00 neon binding and popping when turning
- Help Please! - 2003 Neon Latch System Weight Ratings and Restricitons?
- How to tell if Knock sensor is talking to the ECU?
- Can't find what is causing my 05 SXT to knock
- what are the best motor mounts for a 2004 sxt neon
- 00-01 Fuel Injector Cover bolts ?
- tail lights stay on 05 neon
- courtesy lights
- Cylinder #1 Misfire Scanner Code - car is hard to start in cold weather
- 6 CD changer Install question
- Fairwell my 2nd Gen friends.....
- 02 Neon Flutter idle in park and neutral Codes p1684, p0171, p0422, p0455, p0456
- Vibration Problem - Help Plz ! / Neon 2000
- Instrument cluster swaping
- Extreme Dimensions Duraflex Good or bad?
- Momentary speed/RPM drop and smoke
- '05 broken 4 days after purchasing
- lights issue
- Dirty Brake Fluid???
- Headlamp/Interior Fuse Box Issue
- throttle leak
- P0016 and P0344 codes 3 days after repairs
- Starting issues 2000 Chrysler Neon LE (No Crank, No Start)
- Engine alignment issues, please help
- Engine NOISE?
- No Power
- Skim key issues and questions
- 2005 Dodge Neon Sxt Jolts while Deaccelerating
- 04 neon - trans won't shift
- Help!!!!!!!!!!!!!!
- clutch cable popping out
- How to make lights blink on car?
- Car wont accelerate manual car
- No Heat
- 2003 Dodge Neon Sxt 2.0 L po340
- What could it be??
- 2003 Neon not starting, no spark, 12V on coil input for only a second
- Strange No Start Problem
- p/s tensioner
- Can't pinpoint engine problem.
- 2004 neon sxt vibration
