PDA
View Full Version : Dodge Stratus
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28
  1. Spark Plug cleaning?
  2. 1997 Stratus Mirror HELP.....
  3. Fuel Mileage
  4. opinions
  5. headlights
  6. 2000 Dodge Stratus
  7. body kits
  8. Sedan - Fog Lights
  9. '01 BATTERY LOCATION???
  10. motor mount trouble
  11. 03 2.4L bucks, stalls, and rough idle
  12. 2005 Stratus Info
  13. 98 Strat ES rear sway bar
  14. Engine Swap complete...
  15. Timing Cover???
  16. 2.4L timing belts
  17. wiper/washer stuck in ON
  18. Gauge Cluster
  19. O2 Sensor
  20. Stratus Spark Plugs
  21. 2004 stratus stuck in park
  22. NEW Member with questions ...
  23. 2001 R/T Compass/Temp Gauge out
  24. Just got MSD coil and wires...
  25. ROTM Voting!!
  26. Front End Noise
  27. rims in winter
  28. Paint job faiding
  29. Oil Question
  30. CAP?
  31. 18's
  32. Looking for 2.0L SOHC intake manifold.....
  33. whats the biggest pipe size?
  34. 2.4 Timing Tensioner Q'
  35. 95 stratus stalls on startup
  36. 1999 Stratus 2.4L noise.
  37. New 2001 Stratus R/T Driver
  38. 10,000 miles
  39. intake
  40. Ground Wire Kits
  41. Timing Belts
  42. Removing the engine from a 2001 R/T
  43. Key Stuck in Ignition
  44. intake
  45. intake
  46. strut bars
  47. 01 Stratus body work
  48. New Gauges
  49. 1997 Dodge Stratus question...
  50. Looking for Coil Over kit
  51. Check Engine Light
  52. Why'd they kill the stratus in canada?
  53. Knocking noise when driving straight
  54. 2004 Dodge Stratus SXT
  55. speed-o, gas & temp. gauges non-op
  56. Speed Limiter?
  57. turbo capable motor
  58. P1294 Error code
  59. 2nd gen ground effects?
  60. Rebuilt top end...now idle bad...'97 Strat...
  61. need a turbo for a r/t
  62. Fuel Efficient
  63. effeciency/power
  64. Transmiaaion acting up...need help!!
  65. 96 stratus radio,power locks and lights problem.
  66. is my clutch hydralic?
  67. Problem with my 96 Stratus
  68. 1998 Dodge Stratus Engine Wanted
  69. Front suspension creeking ?
  70. Starting problems
  71. 98 Dodge Stratus - Washer Pump Problem
  72. Timing Belt/Chain Change out????
  73. V6/5speed combo reliability
  74. need to know upgrades ofr 03 strat sxt coupe
  75. Hole in Oil Filter engine kills
  76. Looking into cheap suspension options...
  77. 1999 Stratus Opinions Needed
  78. exhaust clips
  79. Clutch?
  80. warranty
  81. Is the Stratus RT availiable with a 5 spd?
  82. wheres the ECU on a 2000 Stratus
  83. After Market TB for 96 2.0L stratus
  84. gas
  85. 1995 Stratus 2.4l reliable cars?
  86. Headers And Exhaust
  87. 99 stratus axle or wheel bearing split in half???
  88. my cold air intake
  89. 2007 Stratus engine and transmission line-up
  90. Crysler/Dodge Stratus 1997 LE 2.0 4Cyl turbo?
  91. Remote Starter
  92. Where is the oil filter located ('98 stratus)
  93. Transmission problems
  94. WOuld it be worth it>?<
  95. 97 2.4l Cooling Problems
  96. Engine Mounts
  97. cooling system prob, stripped bolt
  98. '05 stratus aftermarket front bumper??
  99. 02 stratus mods
  100. I need a head...anyone???
  101. Cracked Head...
  102. FS CAI 04 r/t v6 &fac amp
  103. 2003 R/T wheels
  104. MOVED: Power Inverter
  105. 98 Strat running poor
  106. Power steering Bracket removal
  107. 95 Stratus Coil Pack Resistance
  108. Need desperate help on 98 stratus
  109. Trunk Kill Switch
  110. 97 stratos 2.4 timin belt
  111. Parts
  112. RPM / coil to plug question
  113. 95 Stratus No Start
  114. So today my car got whacked
  115. Are trotlle body spacers and boring out the thottle body worth it?
  116. Remote turn on lead for amp+sub
  117. 04 Stratus SE - Dash & Gauge Lights?
  118. 2004 Stratus SXT sub-amp install questions.
  119. 96 Cirrus Shuts off while driving.
  120. location of stratus r/t fuse boxes
  121. 1st Gen Gas Guage Playing tricks
  122. Gauges
  123. question about future stratus r/t's
  124. why solid motor mounts?
  125. polishing stock 04 rt rims
  126. Stratus 2-4 Short Curcuit
  127. Put a grill on ur 1st gen stratus...
  128. Headlights pointed too low?
  129. Head lights
  130. Time Display with Radio On?
  131. Anyone changed their power steering pressure hose?
  132. backup sensors
  133. Distributor on 96 Strat ES?
  134. Intake install for 2005 Stratus Sedan (How To)
  135. Anyone else got a header on their 4cyl strat?
  136. How to add a new cigarette lighter
  137. My '04 Strat 2.4L
  138. help: stratus/neon PCM infor
  139. Power Steering Whine
  140. HELP!! Service Engine Soon Light
  141. Need power steering resevoir....
  142. V6 Mitsu Turning Over too fast??
  143. Repair Manual VS Service Manual
  144. Need power steering help ASAP!!
  145. auto to manual
  146. Help 95 2.5L Runs great until it warms up
  147. Tire Rotation
  148. I wanna see some lowered Stratus' Post 'em up
  149. Check your ball joints
  150. Cruise Control Problem
  151. engine upgrade?
  152. 2006 Dodge Stratus Sedan Press Kit and Pictures:
  153. Help with a/c compressor install...
  154. 01 Stratus ES, oil pressure lite on while idling
  155. 19's
  156. Transmission Electronics Noise?
  157. Buying a used 01 R/T Coupe in the next week or so
  158. New R/T Driver
  159. Engine Cleaning
  160. Different Models for 2001 r/t?
  161. How much rotation??????
  162. FAQ library
  163. Need feedback about brake system
  164. Whats the diff between 95 and 96 coil pacs?
  165. Gas Guzzler?
  166. HELP me! i need car aligment schematic for dodge stratus coupe 2003
  167. cold air intake for 04sratus 4cyl
  168. ENGINE CODES
  169. '04 Stratus equipment codes
  170. Just bought a 96 Stratus
  171. tire wear
  172. Foglights
  173. Subwoofer Installation
  174. '04 Stratus clicking/ticking
  175. Air Intake
  176. Potential 00 Stratus ES
  177. 98 stratus a/c cold then warm
  178. stereo/tape player/ speaker problems. help!
  179. Radio just shuts off? Also Fog Light ? 2000
  180. 2004 Stratus AIS motor...
  181. Aftermarket Speakers
  182. How can I get more MPG out of my 2.5
  183. dodge stratus brake problem
  184. Got header and high flow exhaust!!!
  185. passenger door unlock
  186. Motor Swap?
  187. ma stratus
  188. Is The Stratus A Pillar The Same As Sebring and Avenger?
  189. Two QUESTIONS!!!!
  190. Another speaker question
  191. R/T parts on an SXT
  192. Rev. limiter on 03 SXT Sedan
  193. fog lights
  194. cat back exhausts
  195. facts on the sludge monster
  196. weapon r?any mods?
  197. engine light on again
  198. Stratus, Intrepid at top of theft-rate list
  199. $500+ wheel for 03 ?!
  200. stratus 01 short shifter
  201. cams
  202. new pics of the car...
  203. xm stratus
  204. back up
  205. BODY KITS
  206. 00-04 MITSUBISHI ECLIPSE COILOVER HI-LOW SPRINGS 01 02
  207. lowerrt
  208. 2004-2005 Stratus Body
  209. 2003 Strat SXT Sedan Exhaust In/Out
  210. Turbo Stratus Wallpaper
  211. Need info about powertrain control modules and prices
  212. Headlights
  213. Intake Air Temp sensor??
  214. disable priority door unlock
  215. MOVED: some info on exhaust systems
  216. Suspension Question
  217. dodge stratus quits when it wants to.
  218. 96 stratus 2.4 water pump
  219. stratus just quits running
  220. 2005 Stratus(NEED HELP WITH FINDIN MODS)
  221. Aftermarket product listing for the Stratus Coupe
  222. Aftermarket product listing for the Stratus Sedan
  223. Cold Air Intake And Exhaust Mods
  224. IAT sensor....?!
  225. Throttle body spacer for a 98 Cirrus 2.5
  226. Cold air filter
  227. 98 stratus/cirrus
  228. Need help w/programming key fob
  229. Factory Speaker Removal - 02 Stratus R/T
  230. need help i relly mesed my car up
  231. HELP Need BODY SHOP IN CHICAGO!
  232. Exhaust system suggestions for 97 stratus
  233. Could you diagnose this problem?
  234. 95 stratus engine compatibililty question
  235. Body Kits
  236. How to replace driver side mirror on 98??
  237. And the Verdict on the stratus is......
  238. stratus egr (code 32) and O2(code 21)
  239. Cam Shaft Postion Sensor
  240. Stratus wont start
  241. Need some information.
  242. uuu oohhh i busted something....... need help
  243. 97 Breeze heater/ac diverter
  244. 02 Stratus: Engine revs when starting
  245. Where'd the power go?
  246. No Power
  247. 2002 stratus headlights
  248. 2-door or 4-door???
  249. ebay intake
  250. fuel pump
