View Full Version : Dodge Stratus
- Front wheel bearing Stratus 2006
- Need Mechanic in Cleveland OH
- 1996 dodge stratus ecm problem
- Cleveland, Strauts 2006, grinding noise
- Strauts 2006, grinding noise
- Turbo 2.4?
- I got pulled over today...
- 2001 Dodge Stratus Fog Light Lamps.
- Which engine do I have?
- Rear Creaking Noise
- Reverse lamps stay on
- 04 Serpentine Belt Tensioner
- stratus p0071 ambient air temp sensor range/performance
- Auto tranny popping into neutral
- Hard start / No acceleration / Fast shutdown
- Need help with Stratus' twin the "Breeze"
- Opinions on buying a used 03 stratus SE 2.4L coupe
- 2005 Stratus Coupe 5 speed Shifting rough
- Little tutorial to change Valve Gasket Stratus 97 2.4 DOHC
- Transmission problem
- 2001 Dodge Stratus sedan: where on earth is the rear defogger/defrost fuse?
- Replacing speakers, Need a little help
- '00 (1g) ES V6 Valve Cover Gasket bad?
- HID questions regarding the Stratus Coupe
- Prototype LED taillights
- Dodge Stratus 97 2.4 ... Transmission Fluid change?
- heater core? maybe?
- 2005 stratus 2.4L spark plugs and wires change
- Oil Light On Sometimes
- 2000 stratus fuel pump?
- P0700 & p0730
- Help! - weird electrical gremlin
- Engine heater block or....
- Problems with my gas mileage on my car
- Start-up noise - 3.0 R/T Coupe - Valves?
- Interior Lighting on Steering Wheel and Shifter??
- Car maintenance
- The Biggest Hooptie Repair Ever?
- New brakes...EBC?
- Homemade or storeway to clean headlights?
- Rack-n-Pinion... what am I in for here?
- Aftermarket?
- 2002 Dodge Stratus smells like it's burning rich
- Loud whine/grind on passenger front when car is moving...help!
- Oxygen Sensor Question
- 01 noisy fan in dash
- HELP!!!!....I'm confuzzled
- 02 Stratus running rough at stop light
- 2002 Dodge Stratus Headlight Questions
- skipping problem
- Should i use a breather? here (PIC)
- 2005 Dodge Stratus timing belt
- Oil inside one of the spark plug
- Car and truck of the year voting NOW
- Code P0725 on a 99 w 2.4 & AT
- 1997 Dodge Stratus
- where is the EGR valve located?
- Idle Speed reset
- 00 Stratus ES radio/dashlights problem
- Crossed wires?
- 2001 R/T Auto Transmission Concerns
- Air Bag Light/Sensor?Belt...
- Brake drums/shoes
- I dont know how to explain this...
- Cel
- what do you think the problem might be?
- need info on wifes dodge
- Electrical/ Circuit breaker question
- Keypads and backseats
- Ongoing steering problems
- Installing aftermarket stereo setup in '04 RT
- link pin
- Where is the ASD relay on a 95 stratus?
- 2005 Stratus Tranny and Front End problems
- head gasket
- 2.4 oil pick up tube question
- !!!!rims will not fit my stratus!!!!
- New R/T Owner
- '05 2.7 Heater
- Power Steering only one Direction
- Transmission problem with my 02 stratus SE
- 03' stratus.. please help!! Heater core??
- '98 stratus problems
- Should I buy a Stratus ??
- Really Stupid But Serious Question
- HVAC noises
- what is the size
- ventilation problem
- How Do I Obtain Error Codes?
- Performance Modules
- Build List
- 98 Stratus Oil Pressure Light HELP PLEASE!
- Fog light relay?
- Factory Cd changer
- 01' RT Serpentine Trouble
- Turboing Stratus
- type of transmission fluid?
- Jumping Starter Relay?
- Questions
- transmission, hard downshift,kickdown problem
- High RPM
- Alternator quit charging, battery dead.
- 95 stratus rpm guage is not working
- Air Bag Light On
- 96 stratus stuttering problem
- gauges
- dodge stratus
- What is this part?
- Oil Pressure Light Problem - 2004 2.4L
- '00 Stratus Door Sensors for the Interior Lights.
- Parking Brake Adjustment
- 05 Stratus Sub install
- Rear Disk Brake Conversion
- Clutch Pedal Makes Popping sound
- Horn blows by itself.
- sputtering when stopped
- Thumping noice in new front rotors on 1997 Plymouth Breeze
- 2001 Dodge Stratus R/T Overcharging - high voltage at Alternator / Battery
- Custom headlight for sale for your 01-02 Stratus Coupe
- New on Stratus. Help Please :)
- Replacing a bushing on a 2004 Dodge Stratus R/T?
- 04 Stratus R/T manual transmission remote starter
- Intermitent Charge Light
- 2002 2.7L Stratus Sedan Spark Plug Change and Fuel Filter Change Question
- 1998 Stratus wont start, NEED HELP!!
- belts grrrr.
- Power Seat Problem
- someone please help!!!!!!
- Autostick conversion
- 2000 front end squeaks like an angry pig
- Bright lights turn off headlights
- shocks/struts
- No warm air at idle
- 97 Stratus, morning start up.. constant Stalling
- Stratus 2.7 vs Intrepid 2.7 (among others)
- 04 Stratus 2.4L
- 2004 Stratus V6 - Won't Start
- Headlights and tail light questions
- Question about: Fuel pump on stratus 96 2.4L
- will this fit
- new owner 2005 need antenna and user manual
- Noise behind or in dash
- EGR Valve On 97 Stratus
- Odometer Light OUT, and RPM neddle in 0
- 2004 Dodge Stratus Help
- Camshaft sprocket notches
- cleaning my airfilter
- Where's cig lighter/horn fuse?
- Rear Crankshaft Oil Seal Replacement
- trunk
- newbee
- pic request
- Brake fluid
- Air flow sensor "Clock" position ?
- Engine studders at ~4k rpm
- Rear Brake Seize
- 2002 dodge stratus heating until 3/4 the fans start
- 96 2.4 timing belt tensioner same as 2.0
- Trunk Release not working
- Questions
- Knocking noise (96 Strat)
- new spark plugs and wires
- Which Hub Is It
- gas fumes
- Brake Releasing Issues
- Brake Job
- Smoke from transmission dipstick!!
- '06 Sedan PCM flash and Performance Upgrades?
- 2001 stratus ecu questions
- What to do...
- Car Idles At High RPMS...
- 05 SXT Cooling fan turns on and off
- Dtc p0304 ??
- stuck e-brake
- New pics
- 05 Stratus Gas Gauge Problem
- Starts then won't start
- 03-05 Coupe owners with OEM chrome wheels
- Power steering fluid
- Sustained high speed - 90Mph or more
- fuel pressure test adapter?
- 02 dodge stratus boiling over??? Help!!!
- Poor idle and codes
- 98 2.4l are the valves knockin or
- 01 R/t Coupe 2 door 3.0 ltr, rear suspeneions help
- Anyone running on Water/Hydrogen??
- Dash Problems
- "Auto Lock" activation
- Help! Brakes start locking when hot!
- rpm
- Radio wiring schematic
- Steering judder
- 02 stratus hard to shift into 1st gear
- EGR Valve
- rim specs
- Stratus 96 questions
- 2004 stratus speed relay
- 98 Stratus - VSS
- 2000 ES V6 Security Key???
- 04 R/T problems
- Removing Stratus R/T 3.0 Transmission - help?
- Unknown Hose Name
- Which Headlight Bulb Lasts Longer
- Replacing A/C Comp....Special Tools?
- Roof Rack Questions
- 97 stratus tranny problems
- DF Video!
- Idler Pulley Bolt
- Stratus making rattling sound and gas pedal shaking????
- Master Cylinder change out
- 2003 Tansmission Stuck In Limp
- 02 stratus idler shock
- Keyless entry Q
- 2001 Stratus quits randomly
- Random question...
- Help Finding Parts
- P0203 and Engine Control Module problem
- can anyone help???
- 99 Rough Idle w/ Air on
- Major car problem and leak
- 2003 Rough Idle/Jerky acceleration
- What The &%$#!!!!!
- Flashing Check Engine Light on 2004 Dodge Stratus
- serpentine belt
- 02 Stratus Coupe 3.0 V6 not stalling out not starting
- 2004 Dodge Stratus SXT 2dr 78k $7200 OBO
- car acts as if it wants to shut off....
- 2005 dodge stratus - problems
- 99 2.4 high idle
- 1st gen 2nd gen
- Engine Control Computer (For Sale)
- Dodge Stratus DF Group! Join!
- Headlights????
- Help
- For Sale - 2003 Dodge Stratus 2dr Coupe Body Kit
- was in a fender bender now wont start
- Possibly Elec Probs? Pwr Windows & Locks
- Should I or shouldn't I
- rim diameter
- Dodge stratus help
- help! How to pressure test fuel line on a 2001 stratus r/t ?
- new ecu
- adjusting head lights
- The stratus is getting some new paint..
- Stratus engine schematic
- clicking noise &
- A/C clutch fried, can I still drive it? or do I have to replace the compressor
- A call to stratus R/T GURUS
- Ign/Fuel/Sater Fuse keeps blowing 99 Stratus
