View Full Version : Dodge Stratus
- 2001 stratus rt speaker problem
- HELP with my 2004 Stratus ES
- Engine steaming but not overheating
- why my car's gas doesnt last long?
- 2000 Gold Dodge Stratus
- Cam gears
- 98 Stratus smokes blue
- Alignment Issues
- engine swap
- Dome Light Replacement
- 03 R/T Coupe Aftermarket Struts
- spoilers
- engine code
- AC Compressor
- brake problem
- Paint? Not 56K Friendly.
- 2000 Stratus Dies
- 2 Questions.
- Removing Door Trim
- a/c compressor
- 2001 stratus water pump
- ANYONE, ANYONE
- 2000 Stratus with issues
- popping noise in 2001 stratus sedan
- 2004 Stratus R/T sedan 2.7 liter engine problems.
- Thanx
- Question about 03 Stratus Sedan SE
- I need answeres if possible
- is this kit worth it? too cheap?
- 1999 Stratus hesitates when going uphill
- 2000 stratus cd changer
- 95 Stratus v6 2.5L SOHC, Oil Pressure Sensor Location, Rough When Warm?
- thoughts on 2000 Stratus
- Stratus R/T engine in Stratus sedan (95-00)
- little problem, intake, k&n
- blinker problems????
- New Rims?
- Tranny Problems or not???
- Project attempt w/ 04 SXT Stratus coupe
- 2000 Stratus front suspension noises
- 99 STRATUS 2.0 TIMING BELT TENSIONER
- Fog Lights
- Fuel Pressure Regulator??
- Can someone please tell me?
- stupid stupid people
- Overheating and Leaking water
- looking to buy an 01-02 r/t
- possibly selling, 01 strat r/t if interested, let me know!
- 2006 Stratus Remote Keyless Entry Programming ANSWER!
- selling my r/t
- Replace cap and rotor
- oil leak 2000 sedan 2.4
- Fuse Pops every time....
- fog light question! help, please
- 99 Stratus 2.4 blowing fuses when open door
- 00 2.4L stratus fuel injectors
- Stuck in 2nd gear
- A/C NOt working
- Pics of Stratus race cars wanted
- grill inserts opinion
- R/T Emblem
- !!!WTS!!! 2003 STRATUS R/T $13,700!!!
- '95 Stratus vibrates at any speed...
- adding HP?
- mounting trans cooler
- Adding a relay for use at night
- installing aftermarket cd player on 01
- stratus misfiring ignition coil problems
- temperature gauge
- turbocharger
- PLUGS/WIRES/K&N FILTER KIT SPECS QUESTION
- LOWERING KITS AND PILLAR GAUGE CLUSTER
- July Ride of the Month Voting!!!
- Check engine light on
- racing with automatic?
- 20" Dropstars on my 04 R/T
- 2001 Dodge Stratus R/T Turbo?
- 04' SOHC 2.4L engine, Stratus SXT coupe....Where's the power hiding?
- Dtc 35, 53, 36
- Tranny cooler?
- Guages for 2005 Sedan
- hello!
- To you engine buffs
- led neons (not underbody)
- K&N Filter
- 95 stratus rear seat removal
- Need help with 2000 Stratus audible warning? signal
- new to forum
- 2 questions
- 2002 Dodge Stratus Sedan rattling
- 1995 DODGE STRATUS STALLS WHEN WARM
- rear drum brakes
- r/t suspension
- removing vibration damper 2.4
- auto trans shift kit?
- where is the spot of the fuel filter?
- Lube Oil
- horn
- horn
- Magnum Wheels
- 1999 startus no start
- idle roughness and CHECK ENGINE
- 2001 stratus bezel removal for stereo
- WANTED: 2.4 DOHC Engine
- 05 Stratus SXT V6 2.7L
- Starter on a 02 Strat R/T
- Upper manifold help
- 2004 Dodge stratus
- Spring install price
- Coolant!
- 6g72 TT
- Code help please
- body kits
- busted pc, new pc , still wont clear battery light.
- 2001 dodge stratus se coupe (mechanical question)
- 2001 Dodge stratus se coupe
- TRANS HELP PLEASE!
- 96' Stratus chugging at take off W engine light on
- 2.7L Rebuild Kit.. Need Some Advice
- Help with Rear Brake Lights
- STRATUS R/T CONV.
- 05 stratus r/t steering wheel radio controls?
- Any Of You???
- electric supercharger 12-47 horsepower gain
- Thinking about a Turbo
- 04 Stratus Passenger Mirror HELP!
- 2.4L 2001 Stratus help!!
- 1997 stratus, 2.4 l engin
- engine swapping
- a/c problems also
- Popping noise coming from front end
- Sputtering and Bucking
- stratus intermittent electric problem
- start, go, die.....no code?
- I need help with Lemon Laws
- A/C socket not working
- Washer pump not working?
- Hard to start on cold days-96 stratus es
- 2001 dodge stratus SE keyless entry problem
- 01 ES front left corner noise while turning right
- Won't show trouble codes
- Stratus SXT Performance Questions?
- June Ride of the Month Voting!!!!!!!!!
- did i get a good deal on my caR?
- sun/moonroof NOISY!!!
- 2003 stratus rt mechanical help???
- Does any one know anything about this?
- 1995 Stratus ES - Stalling/Stopping - Help!
- '95 Stratus 2.5L Serpentine Belt Replacement
- Spark Plug Change HELP!!!!!!
- Timing Chain Cover Coolant Leak
- Ipod hook-up
- The " rare sports coupe"
- 2005 stratus r/t front grill
- Performance of Stratus 2.4l 150 hp 160 torque
- intake manifold swap
- Fog Lights for 2005 Sedan
- Happy, Happy, Joy, Joy!!!
- Fan blower question
- 2.4L in a 2gen neon?
- what clutch
- tach and odometer problem
- stratus misfires when wet
- 2002 bad fuel filter?
- Cold air Vs V2 intake
- a/c issues
- R/T Muffler Suggestions
- Factory Stereo Amp issues / wiring
- 2002 Dodge Stratus Coupe Body Kit
- my new R/T
- Running crappy at idle
- Turn off Daytime running lights?
- AfterMarket Stereo Instal
- POWER DOOR LOCKS have gone out of control
- HELP!!!!!!
- Hesitation on acceleration - help!
- 2003 stratus running rough
- Cylinder misfire?!
- Coolant rust Help!!
- Replace headlight bulb
- A/C problem
- I NEED SERIOUS HELP SOMBODY
- Looking for complete 04'ish stratus front end
- Help! Bad brakes.
- 97 Stratus with 120k miles?
- autostick conversion
- Dead Battery - now radio dead with blinking lights
- New Shoes and new brakes/rotors
- 98 Stratus -- Horrible Mileage ~12mpg city
- Tranny problems!!
- 12v Socket Not Working
- TURBO TALK
- Check engine code P0455
- 95 stratus not starting
- Trans ?on neutral
- 97 stratus with coolant loss
- CD Changer issue
- 2001 Stratus R/T brake questions
- sun roof issue
- Axle pops out - 2002 Stratus R/T
- Stratus Horn Honking?
- Remove harmonic balancer???
- '96 2.4l oil pan removal
- May Ride of the Month Voting!!!!
- engine noise
- Need help with trunk lift installation
- How much is my car worth?
- Factory head unit and aftermarket amp
- Limited Slip
- Styrofoam?
- Front wheel stud replacement
- help with proflow 62mm throttle body
- Car and Truck of the Month, get involved!!
- Turbo Stratus
- Pays to read the owners manual!
- NEED TAILIGHT
- the mopar nationals...
- pics from the nats last year...
- 2002 Stratus Troubles
- Cold Air Intake Nightmare - 2005 Sedan R/T
- 1/4 mile times Bone stock
- Replacing 2.7 V6 engine Need Help
- Brake Light on Dash
- new member...need sites 4 aftermarket stuff!
- camshaft sensor location 2.7 -01
- Pics
- 2.7 knock sensor not under warranty? $1750
- knock 2.0 liter
- Pics of my 02 Strat R/T (dialup need not apply)
- which intake??
- 96 Stratus
- 2001 Dodge Stratus 4dr SE
- speed gov
- 2000 Stratus 2.4 no start - HELP!
- new here never been a member of a car forum
- transmision
- parts off 3000 gt
- how to get faster accelaration?
- how to increase power?
- Towing
- how to block off egr ????
- 2003 Dodge Stratus ES RKE Programming Procedure
- 2.4 timming belt tensioner
- New rims on Stratus, with pics! Also alarm
- Coolant trouble
- NEW MEMBER (WITH PICS)
- suspension decisions
- Brake lights all not working
- PCV Valve?
- aluminum radiator hi/pro
