PDA
View Full Version : Dodge Stratus
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28
  1. 2004 2.4 engine timing belt
  2. R/T Center Caps
  3. no spark / won't start.
  4. will a 2005 bumper fit on my 2001
  5. Noise in dash after evaporator change
  6. IS MY ENGINE BAD
  7. 2000 stratus es v6 auto transmission solenoid leak
  8. 02 R/T ..... Differential Oil
  9. any xtra oil pans layin around
  10. 2.4l head ticking
  11. FOR SALE: Headlights/Billet Grille
  12. Inadvertent alarm disabling my 96 Stratus
  13. Stratus coupe front brake conversion question
  14. post winter start up
  15. I love my '98 Stratus ! Any die-cast of it ?
  16. used Stratus or new Caliber?
  17. Dash lights out 2000 Stratus
  18. hey i got a brain twister for ya
  19. Overheating after oil change.
  20. still problems
  21. Remove engine & cradle?
  22. Best Spots to Apply Sound Deadening
  23. 2001 stratus with front end grinding noise
  24. thanks from a dodge owner in trouble.
  25. The newer Stratus's Mitsubishis? Lottsa questions
  26. floor pedals
  27. 2 questions
  28. need help CODES
  29. '96 V6 no start after engine replaced
  30. 2000 Dodge Stratus Spark Plug Location...
  31. 98 stratus problem still !!!!!!!!!!
  32. 2000 stratus electrical issue
  33. Hey Everyone...weird issue?
  34. Hello all quick question(s)
  35. weird idle
  36. Stratus coupe questions!!
  37. 2004 Dodge Stratus R/T Coupe
  38. Engine Removal Question
  39. Loud Humming Noise help
  40. New noise after replacing power steering rack and pump.
  41. 01 stratus 2.7l replacement
  42. rubbing and squeek on 1999 Dodge Stratus
  43. cigarette lighter / power outlet probs
  44. Spark Plugs?
  45. Where did these come from?
  46. from Russia with love:)))
  47. Car totalled!!
  48. Rear defrost, tinted.......
  49. Front left wheel click????
  50. 150,000 mile tranny?????
  51. Paint
  52. what is the inner and outer spline count
  53. 2004 R/T questions
  54. Performance chip
  55. radiator fans won't turn on
  56. stratus shutting off
  57. Replace spark plugs
  58. Spark plugs
  59. Hazy Headlight covers....
  60. Looking for a Cold Air Intake or Short Ram for your 2.4? Here ya go.
  61. Full Synthetic......
  62. 2000 Stratus Suspension.... Got any?
  63. noise after replacing timing belt
  64. what would u do????
  65. Secondary Air Injection System (Bank 1) ??
  66. Strange Transmission Noise in R/T. Bad or Normal?
  67. engine engine engine
  68. timing belt
  69. Engine Knock
  70. Tire Recommendations
  71. Front Wheel Bearing Replacement
  72. Getting 4 wheel disk brakes on a 03 SXT coupe
  73. '98 Stratus has been good
  74. Compass/Temp not working
  75. Probable electrical / computer issue with 4cyl 98 Stratus. Help??
  76. Anyone rebuilt there A608 (41TE)
  77. evap
  78. '00 Stratus, CRAP electrics
  79. radio problem
  80. Replacing 3.5" speakers on dashboard
  81. Replacing the clock spring
  82. Clunk?
  83. electrical problem?
  84. slipping P/S belt on 97 Strat
  85. 2001 dodge stratus not firing
  86. Power Steering Help!!!!
  87. DODGE STRATUS ALUMINUM WHEEL CENTER CAPS
  88. 02 R/T 3.0 ... 1 or 2 (o2 sensors) ?
  89. Need a little help, please
  90. 01 stratus R/T speaker help
  91. rattling noise
  92. my 2.4 dohc 98 stratus is not firing please help before i burn it to peices..
  93. 98 stratus 2.5L problem
  94. Stratus generations and service manuals
  95. steering column?
  96. Fuel injector connector removal PITA
  97. Anyone Else Have This Issue
  98. flowmaster delta flow 50
  99. Help???
  100. Need some help
  101. IS THERE A DIFFERENCE?
  102. Swap?
  103. Coupe vs Sedan Headlights
  104. COTM
  105. P0420 code now
  106. What size speakers and amp should i use???
  107. Will 20" rims fit on 98 stratus
  108. resistor blew AGAIN
  109. Floor mats
  110. newly installed hi/lo hid's also came with a big problem
  111. '99 Transmission Shift problem
  112. lock cylinder housing ?
  113. 1995 Stratus 2.4l Transmission Problem
  114. Location of Computer 1996 Stratus
  115. 96 stratus vibrating steering wheel
  116. 97 Stratus?
  117. Need Mass Air Flow Sensor
  118. Stratus 2.4 Starting Issues
  119. 2001 Dodge Stratus R/T transmission
  120. changing transmission solenoid ....
  121. axles
  122. Fuel pump priming
  123. FREE Stratus Repair Manual (JA - PDF format)
  124. Cruise Control on at Start-up
  125. make me fast!
  126. Programmers???
  127. starting problem
  128. Sqealing in Exhaust System of 02' when cranked
  129. What To Do???
  130. 1995 STRATUS SCANTOOL HELP PLEASE
  131. fuel door
  132. Freeze plug replacement
  133. Need a pully.... help please...
  134. Wanna buy an r/t
  135. My '03, 2 door Stratus R/t 3.0Liter
  136. HELP - Red light goes on sometimes in dash/instrument console
  137. 1996 Stratus 2.4L wont stay running
  138. ASD relay ?
  139. Steering screeching noise when turned left or right
  140. Defroster Switch
  141. 2002 Stratus Trans temp sensor
  142. Dodge Stratus PO601
  143. Turbo Project
  144. Blacked out Headlights
  145. BIIIIIIG Problem With my Guage Bezel!! Help please!!
  146. 98 stratus no bus
  147. window tint
  148. 96 stratus transmission cooler
  149. 99 stratus speaker problem
  150. 98 stratus timing belt kit
  151. Electrical issue
  152. '99 Stratus Upgrades
  153. 98 stratus problem?
  154. weird thing!!!
  155. replacing upper oxygen sensor 96 stratus
  156. Tranny Shift Solenoid
  157. 2004 stratus P301 code (cyl 1 misfire detected"
  158. R/t sedan manual transmission
  159. 2002 dodge sedan stratus r/t
  160. Cheapest way to replace bumper?
  161. 2002 stratus problems?
  162. 2000 Stratus stock alarm
  163. 01 R/T heat issue
  164. '04 Stratus Low Oil Pressure
  165. Stratus/3000gt exhaust manifold
  166. Electric Door Lock switch
  167. Voting is going on now!!
  168. Heater problem
  169. power lots of it
  170. 01 Stratus Accessory Belt
  171. crankshaft positioning sensor
  172. Front End Clicking Sound
  173. location of oil pressure sending sensor
  174. P0172
  175. Crazy mess of rough idle and random misfires - flashing CEL?
  176. General Stratus Questions
  177. Regional Sections!!
  178. Radio bezel removal
  179. 98 Stratus intermittant stalling problem
  180. V6 timing belt timed, but I've got contact
  181. Little/No Heat & stiff steering
  182. where to buy Mopar Power Steering Fluid (MS-9602)?
  183. wiring a amp
  184. Ticking/Rattling Through Timing Belt Cover - 2.4L
  185. Weird starting problem with my Stratus
  186. ecu
  187. Re: Chrysler Stratus Plasma Door Sills
  188. Need a cold air intake. Help!
  189. Stratus Alternator Belt
  190. 2.4l timing belt tensioner wtb
  191. 2001 Dodge Stratus R/T Coupe
  192. where is crankshaft position sensor ?
  193. PLEASE HELP!!!
  194. car wont start
  195. Please help to check VIN Dodge Stratus 2005
  196. Strange noises under my hood
  197. Same services, different prices, why?
  198. high temp and a hard hose
  199. bout to do my brakes....
  200. oil pressure light on.... then off
  201. Thinking about buying an '01 Stratus
  202. Transmission problem!
  203. Which grade of motor oil do you use
  204. How do I correct code P0703 ?
  205. Crank Pulley Stuck
  206. 97 Stratus - steering wheel shimmy
  207. mods?
  208. Trunk Leaking
  209. Body kit and CAI???
  210. Help!?
  211. Gurgling sound on startup, only when it's cold.
  212. engine hesistant
  213. Stratus Sedan power door lock actuator
  214. 30 Amp Heater fuse melted hole in fuse block?
  215. Any problems using Xenon lights?
  216. Brake Bulb in Trunk Lid-2002 Stratus
  217. TRANSMISSION ?
  218. keyless entry
  219. Re: Sill Plate Protectors
  220. Gauge Cluster
  221. Stratus UDP?
  222. idler or tensioner pulley
  223. How to install the windshiled washer nozzle
  224. 05 Shifter Sticking!
  225. Rear window de froster
  226. fog lights
  227. Heater issues
  228. check engine light is on and Transmission is messing up.
  229. Speaker Issues.
  230. Paint Color Question from Dealer.
  231. Need help with codes
  232. Stratus Exhaust
  233. **HELP ME ASAP**
  234. Power steering pressure line
  235. mirror help !!!!
  236. alternator confusion
  237. 99 Dodge Stratus
  238. Good Deal?
  239. Speaker size for 99 stratus
  240. Stereo Cuts Out When I Brake
  241. broke down on highway!!!!!!!!
  242. oil drain plug location?
  243. 98 Status OverHeat Problem
  244. turbo my stratus
  245. Same body style?
  246. Re: Heated Seats & Uconnect
  247. burn fuel and suck ass cuz my intake?
  248. Water pump
  249. Charching problems
  250. Should I stay away from 2G sedans with the V6 b/c of sludging?
