PDA
View Full Version : Dodge Stratus
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28
  1. 2000 Thermostat
  2. need advice on oil pan on97 stratus
  3. 01 Stratus 2.7 DOHC camshaft position sensor location
  4. WHAT IS GOING ON WITH THIS CAR??
  5. woops
  6. Difference between '98 and '00 engines
  7. strange problem
  8. a few more questions....
  9. HELP! 1998 Stratus 2.4 Not Starting??
  10. Help!! '98 Stratus Headgasket Replacement
  11. 98 2.5 external coil modification
  12. 2004 Stratus
  13. no spark 2002 dodge stratus
  14. removing oil pan 1997 stratus
  15. tranny cooler lines
  16. how to test fuel pump
  17. 2000 Dodge Stratus Air Conditioner Problem
  18. 2002 stratus stereo install
  19. pull codes without computer
  20. 2002 dodge stratus 2002 rt 2.4 no gas at when cranked
  21. horrable sound on start up
  22. help!!!!!!
  23. service engine soon light! grrr
  24. Any one with a 2.4L
  25. Homelink help(not programming help)
  26. 2001 stratus rt wont drive when service engine soon light came on
  27. 97 Stratus - need speakers
  28. ahh... the '99 Cirrus
  29. Trans Filter 03 Stratus coupe 4cyl?
  30. Starting problem
  31. Leaking?
  32. '05 Stratus stalling.
  33. speedometer & transmission
  34. "auto" power window won't work
  35. Someone please help a desperate man here!
  36. rough idle and power loss
  37. need directions on how to cange lower ball joints on 97 stratus
  38. first dodge strat.want to unleash its potental
  39. advice
  40. loss of power
  41. Aftermarket front lighting for 2005 Stratus SXT Sedan
  42. Why did they stop making them...
  43. '99 Dodge Stratus
  44. fuel pressure
  45. Dashboard help
  46. Ignition switch
  47. intemittent key fob operation
  48. trans codes
  49. 1999 dodge stratus
  50. Bad Right Brake Light
  51. crank position sensor
  52. Get out and Vote
  53. rear lighting wires
  54. Need help 99 stratus 2.4L Code P0134
  55. Radio wiring question
  56. 1998 2.4L No ground signal on injectors
  57. Waterpump
  58. de badge
  59. Need help with electrical windows
  60. Blinking A/C light
  61. Looking For 01 Stratus Door Panel!
  62. Car/Truck of the Month
  63. 2.0?
  64. '02 Stratus Trans issues - have codes
  65. new stratus owner with some ?'s
  66. Electical issue HELP!
  67. 97 ES fuel Filter location:
  68. Replacing brake light on 04 Sedan
  69. 01 Stratus Stereo Advice Needed
  70. 96 Stratus TCM Padding Material
  71. Turbo KIt
  72. How do I remove a governor on my 2000 Stratus ES?
  73. STS Turbo
  74. Help Don't know where to start 97 Stratus 2.4l
  75. PCM part number
  76. 2003 Stratus anti theft system
  77. Remove door trim around lock/unlock and window switches
  78. HELP!!!
  79. Shifts to 2nd instead of OD
  80. 2001 Stratus Coupe stereo console problem
  81. 2001 Stratus RT Coupe Front Struts
  82. 01 STRATUS RT 20 INCH RIMS
  83. 97 Stratus 2.5L V6: "Normal" oil pressure at idle
  84. Engine Rattle at shift points and idle at 2k rpm
  85. anyone have a dash for sale????
  86. Front end noises
  87. Stratus aftermarket carpeting
  88. paint bubbling
  89. Help: any 41TE rebuild experts here?
  90. water pump 2.4 2000
  91. Floor wet under mat
  92. need help
  93. 97 Stratus stock stereo problem
  94. performance
  95. Any way to test a PCM ?
  96. 95 Stratus PCM/ASD and Battery Hook up Wrong
  97. engine light-non flashing
  98. EGR Problem
  99. 95 Stratus ES Stuck in 2nd Gear
  100. Stratus cuts off
  101. Need Altezza's or Clear Tail lights for 2008 Stratus
  102. Question about placing battery ground wire.
  103. Looking for new headlights
  104. 2001 Stratus Sedan 2.4 for sale
  105. Stratus 2004 Fuel filter/online retailer
  106. Trans in "limp" mode
  107. Quick A/C Question!
  108. 02 Stratus R/T 3.0 Battery problem
  109. A/C recharging
  110. What about 04 R/Ts?
  111. Buying first Stratus and I have Qs
  112. Car loses power when accelerating
  113. 98 Stratus 2.4 radiator fans not coming on
  114. 99 ES Questions from new owner
  115. '01 Stratus questions.
  116. CD Player connections.
  117. What Do You Recomend?
  118. Newbie Stratus 1996 Help Request
  119. Decreased Shift Time (standard)
  120. CMTC temp problems
  121. What spark plugs to run
  122. 98 transmission
  123. Leaking R134 air cond
  124. 01 Dodge Stratus recalls
  125. Shift Solenoid
  126. Accessory signal not received by radio
  127. 2000 stratus
  128. turbo kit
  129. appearance
  130. Sirius Re-Install from Ram to Stratus
  131. locking gas caps?
  132. Stratus 1998 Immobilizer
  133. Help 2002 Stratus 2.4L
  134. I think it died....
  135. Changing speed sensor on 2000 Stratus
  136. Problem with the battery or could it be something else?
  137. Is there anyway this could be true?
  138. chirping noise in transmission
  139. nos question
  140. gas mileage?
  141. Adding aux input to '01 factory radio
  142. Bleeding brakes
  143. Could a faulty speed sensor cause 3 other codes?
  144. Manual Transmission Fluid
  145. Corrosion Warrenty
  146. I have an 04 Stratus SE editon
  147. SE/RT
  148. Electrial Problems Need serious help
  149. 98 radiator reservoir boils
  150. Replacing hood emblem
  151. Stratus from the future!!!
  152. Just bought a 97 Stratus, have a few ?'s
  153. where is my fuel filter?
  154. 2005 Stratus Cruise Control
  155. Mechanic replaced rear oil seal now leaking transmission fluid. Need to troubleshoot.
  156. Need to bleed clutch on my '02 stratus rt
  157. Suddenly the motor stops! (Electrical?)
  158. Black 02 R/T Paint Peeling on Roof
  159. Tranny Coolers?
  160. 02 r/t coupe antenna
  161. 99 Stratus - persistent brake noise
  162. seatbelts
  163. '99 AC issue
  164. 97 2.0L engine bog/loss and noise
  165. Question about touch-up paint..(PX8 vs PX9)
  166. stratus drag race
  167. New to forum/Stratus's
  168. Is the sludge monster coming?
  169. Timing belt tension pully
  170. CamShaft Position sensor location
  171. help
  172. Engine replacement
  173. Fuel Economy
  174. 98 Stratus
  175. 04 headers
  176. reset computer
  177. fuses
  178. IGNITION REMOVAL
  179. 1999 stratus struts
  180. cv joint, axle, or struts??? or other
  181. Need Help ASAP!
  182. How to mount front license plate???
  183. stratus shift hard
  184. dodge daytona?
  185. 1997 Stratus HELP PLEASE
  186. 02 Gauges
  187. My Stratus R/T
  188. 97 Breeze Air Conditioning turns off after engine warms up
  189. Problem?
  190. New problem, where does Neutral Conductor Cable get plugged in?
  191. I can't find my paint code
  192. 1998 stratus wont start
  193. Any mechanics here?
  194. General A/C Question
  195. wont start
  196. how do i get power
  197. 99 abs computer location
  198. '06 Stratus R/T (4 door) production numbers
  199. 2004 idling problems help!!
  200. rear disk Brakes
  201. huge A/C problem...
  202. engine swap
  203. 97 strat - strange clunking noise suddenly
  204. Hey everyone im trying to sell my Stratus.. its a 1995 full work around it re-done engine..
  205. got in an accident.;(
  206. Parts for mt 05 sxt coupe needed
  207. '02 Air Conditioning
  208. Blower Settings
  209. Is it worth fixing rear engine seal with car that has 205,000 miles?
  210. Water Pump
  211. Check angine light
  212. Cigarette lighter Problems (2004 Stratus)
  213. blower only running on high
  214. 99 stratus abs fuse keeps blowing
  215. 02 Stratus Noise ..PLEASE HELP..
  216. Instrument Panel Backlights
  217. 99 stratus O2 Sensor Location
  218. Help with rear brakes
  219. Odometer and Tach not working???
  220. Arizona Residents Unofficial Meeting 5/26/07
  221. '01 Stratus R/T - 5 different codes given!
  222. Help with 2001 R/T Code P0403
  223. Plastic under car behind bumper
  224. Rear Speaker deck access help
  225. P0451 CEL Problem
  226. Pwr locks, radio, and int light not working
  227. Tighten belt tension
  228. 97 Strat - Upstream O2 sensor location
  229. 98 stratus A/C issue
  230. Wiper Blade Problem
  231. is this thing really works ? help please
  232. 6 speaker system needed for stratus
  233. performance chip help!!!!
  234. The Noob Questions
  235. tires and rims for 02 stratus 2.7L SE
  236. Parting out Stratus
  237. anti-rattle clip
  238. 01 CoupeTranny Issue Please Help!!
  239. interior neon lights
  240. Musty Smell
  241. will these tires fit OK
  242. Rear Wheel Bearing nightmare!!!!????
  243. 98 stratus 2.5 stalls, bad idle, no codes
  244. 1999 Stratus A/C Problems
  245. A reliable car?
  246. Several "electrical" issues
  247. twisted rack boot, should I worrry?
  248. 2005 Stratus noise coming from the front end
  249. 02 stratus
  250. faster
