PDA
View Full Version : Dodge Stratus
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28
  1. Help with decoding codes
  2. cold air intake v.s. short ram intake
  3. tranny problems - please help
  4. New pics!!
  5. 2001 dodge stratus SE
  6. Anybody come across an R/T with a Black Matte finish?
  7. i need help buying HID Xenon Conversion kit!!
  8. Factory Alarm and High Beams (2001 R/T)
  9. Dodge Stratus Front End Noise
  10. Car Trouble-Hard Shift
  11. Car Trouble
  12. ok whats next
  13. my car makes this sound... need help
  14. Low End Engine Noise - Knock
  15. Is This Worth It?
  16. driver door won't close with others-sync problem
  17. brake light trouble
  18. Window Motor - Stratus 99
  19. Dodge Stratus R/T Questions
  20. Radio Bass Treble mid flashing
  21. 1999 Stratus Wont Start
  22. Hi Flow Cat
  23. oil leak
  24. HELP ME PLEASE!!!!
  25. 99Strat airbag/brake lite on...no electrical
  26. obd read code of P1494..Help.....
  27. 2000 Dodge Stratus AC button problem
  28. soft brake
  29. odometer reading
  30. Blower won't stop
  31. Hey everyone
  32. Springs
  33. Help With Turbo Options. Please!
  34. 2000 stratus - steering column problem????
  35. pesty oil leak on 1999 dodge stratus
  36. HELP FAST
  37. Photoshoot 6/29/08
  38. Some night pics of my Stratus
  39. stratus
  40. 2005 2.7 Dodge Stratus Running problem
  41. fan speeds on climate control-1+2 inop, 3+4 ok
  42. Stratus SWAP NEED HELP
  43. Stratus SWAP NEED HELP
  44. air temp sensor?
  45. 2002 Stratus Tranny Trouble HELP!
  46. TURBO QUESTION.
  47. RIMS
  48. Unusual Problem With 2005 Stratus ... Need Help Please.
  49. Please Help.
  50. Popcorn Noise or Popping Noise from the front drivers side of a 2004 Stratus
  51. HELP WITH CLUTCH
  52. Gas Savers?
  53. Horrible Shaking on Startup, CEL on
  54. Replacing air filter on '04 Stratus 2.7L
  55. small crack in oil pan
  56. 1995 2.0 shudder under load
  57. 2004 sedan front end knocking
  58. Eclipse parts?
  59. Do you have to drop trans to replace differential bearing?
  60. 2000 stratus speed sensor location
  61. muffler
  62. bulb type
  63. Unstable Idle
  64. Stratus 2006 2.0L P1128
  65. Champion 3570 platinum plugs
  66. Is my old catalytic worth anything?
  67. won't idle.....help plz
  68. Help with 2000 Dodge Stratus Camshaft Sensor
  69. Interchangeable?
  70. Who would win?
  71. high output alternator
  72. 6g72 Turbo Interchangeable?
  73. 05 2.4L sensor on stock intake
  74. Stratus 96 problem
  75. Looking for parts.
  76. IAT sensor in the 06 r/t sedan
  77. lowering
  78. HELP MY STRATUS FRIENDS!!!!!!!!
  79. Service engine soon light .....
  80. power windows ????
  81. 06 Stratus w/tire issues
  82. Cruise?
  83. engine rotates but does not start
  84. Parts 04 stratus
  85. cylinder 6 misfire
  86. .
  87. runs rough
  88. Fuel Pres. issue - has anyone heard of this?
  89. 2001 Stratus Rt
  90. intake question....
  91. is it weird to fill up your tank twice a week??
  92. are recalls good for the life of the car?
  93. P0122 TPS Low Input Voltage
  94. Timing Belt For Stratus Coupe 2.4L
  95. 99 Stratus in "Limp Mode:
  96. Tornado Fuel Saver
  97. WTB: '03-'06 stratus r/t
  98. HID conversion kit
  99. 95 Stratus, Idles, but trys to die when pressing accelerator
  100. Stratus Will not start
  101. 03 Mod Questions
  102. What side is bank 2?
  103. A/C not working right
  104. exhaust leak - any help??
  105. strange clunk when taking off
  106. 2000 stratus won't start
  107. Spark plug wire set.
  108. '99 Stratus speedometer not work
  109. changing the oil
  110. lowering springs
  111. 2 questions
  112. 1 or 2 questions
  113. Dead
  114. paint
  115. look please and help please
  116. 03 coupe 2.4 turbo
  117. '00 ES Stratus 2.5Lv6 Not Starting HELP!
  118. Installing OEM disc changer in R/T coupe
  119. JA stratus work log
  120. couple of questions
  121. P0441 code
  122. Removing Stock Radio Help
  123. lower ball joints
  124. A question on random stalling...
  125. 02 Stratus Body Kit question
  126. Instrument Panel Lights
  127. '04 Stratus Electrical problem PLEASE HELP!
  128. 2000 Dodge Stratus ES/ Installing new deck questions
  129. mystery ticking in engine
  130. Seized Subwoofers?
  131. 98 stratus transmission exploded
  132. Stratus 2.4 no start
  133. Headlights audible warning/dome light
  134. How Much Mileage is Too Much Mileage?
  135. 01 ES climate control whacky, not much control with controls
  136. keyless entry question.
  137. Little things needing some info...
  138. Vibration in motor and in steering wheel
  139. Sunroof Install
  140. 95 Stratus 2.5L Check engine codes help?
  141. Hold Odometer Button + Turn Key = ??
  142. '05 Eclipse 3.0/'05 Stratus 3.0
  143. Split-second loss of everything
  144. Radiator Fans and AC Compress do not run
  145. 2003 Stratus jerks when slowing down
  146. Air filter replacement
  147. Best 1st Gen Year to Get (?)
  148. MOVED: battery draining overnight
  149. 2004 Stratus Drivers Window works intermitently
  150. Brake rattle problem....
  151. Kinda stumbles if I try to accelerate
  152. CAR HESITATES THEN SHUTS OFF
  153. Audio Help
  154. What's in your trunk
  155. dash lights
  156. tires for stratus.. need advice
  157. exhaust
  158. Another stalled car
  159. body question
  160. Idler pulley removal and installation
  161. 97 Strat 2.0 catalytic job - straightforward?
  162. Acceleration Bottlenecks, Misc Performance Mod Questions
  163. no sound from main speakers
  164. Car idles, press on gas it stalls- HELP
  165. Distributor cap and rotor??
  166. PERFORMANCE HEADERS
  167. quick question
  168. Need some help
  169. Projector headlights for 2g and 2.5g
  170. dashboard
  171. Parts Distribution???
  172. Mod Questions for 01 R/T Coupe
  173. Electricity....Friend or Enemy?
  174. Steering wheel vibration while idle..
  175. EGR Valve 98 Stratus 2.4L
  176. Defrost Fan Issue
  177. Stratus diecast/plastic model
  178. body kits
  179. Where is the oil sending unit?
  180. speaker location
  181. Does Any one have any Accessories for sale for a 95 through 2000 strat
  182. Painting door panels
  183. QUESTIONS: Dodge Stratus SXT to SRT PLEASE LOOK!!!
  184. Power Steering trouble
  185. need help
  186. wheel size for 01 Stratus Sedan
  187. 96 dodge stratus 2.4l dohc
  188. 1996 Dodge stratus 2.4l
  189. im new here, and i have problem
  190. Random Questions. '00 ES.
  191. differential bearing bad??
  192. new here
  193. Interesting Smell
  194. Touchscreen console/mount
  195. 18" rims advice HELP
  196. i want power
  197. Radiator fans only work when A/C is on. 2001 2.7 Stratus ES
  198. 1998 Dodge Stratus ES
  199. camshaft position sensor or distributor?
  200. 2002 Dodge Interior Help
  201. I NEED HELP STRATUS 96
  202. transmission kickdown problem
  203. Automatic shift knobs
  204. wierd screeching noise
  205. 2002 RT Transmission Questions: Model and Compatibility?
  206. 18's on my Stratus?
  207. 3.0 Serp Belt Routing?
  208. allseasons put on alloy rim now noise front right!
  209. Show off your interior.
  210. ABS Light & Traction Control Light
  211. 2004 Stratus SE Sedan, Good Value?
  212. 2006 stratus hlp
  213. Auto Locking Doors. How to disable? 00 Stratus ES.
  214. ball joints go every time i put snows on!!!!!
  215. Radio died, disconnected battery, now car is whacked..
  216. 2001 SE Coupe -- Unable to find air intake [[Found]]
  217. 98 2.4L ed714 tran fluid ????????
  218. 02 stratus remote
  219. 2004 2.7 dohc oil leak???
  220. Horn
  221. 99 Stratus 2.4L does this wierd thing...
  222. Location of o2 sensor bank 1 sensor 1 ?? Dodge Stratus 97 2.4
  223. 99 stratus AC problems
  224. How to replace Exhaust Manifold?????
  225. 97 Stratus 3.5L won't start
  226. 2000 ES - Red dot in cluster.
  227. Question about ATF.
  228. Just got an '01 Stratus RT Coupe
  229. Proud new owner of...
  230. 02 Sensor location cause of Check Engine
  231. What to do.
  232. Noisy strut passenger side
  233. possible skip
  234. Air intake for Dodge Srtatus 97 2.4
  235. Alarm System & Keyless Remote Help
  236. DOOR HANDLE
  237. Front Defrost Problems
  238. Need help ASAP
  239. drum brake troubles EERRR! 98 w ABS
  240. Please help with broken hood latch cable
  241. trunk
  242. Coupe owners...timing belt replacement?
  243. Odd electrical problem
  244. I now own a Stratus R/T coupe
  245. 1997 dodge stratus 2.4l auto trans
  246. Blows only cold air
  247. paint job
  248. removing harmonic balancer
  249. compression ratio??
  250. bought a 2000 stratus motor
