View Full Version : Dodge Stratus
- cat converter
- Brakes squeaking, driving me mad!
- 2006 custom intake question??
- man trans in 95 stratus...
- HELP!! car quits when a/c or defrost is turned on
- FREE GREG SPRADLIN SRT10 PRINT!!!!
- Oil capacity?
- Just got a Stratus!
- Newbie, have quaestions
- how to get better ghas mileage
- Witch of these three tires for my SXT Coupe
- Anyone in orange county/long beach?
- where can I buy good moter mounts for 3.0l
- H.I.D. headlights
- Sunroof opening prob.
- Stratus Coupe Struts - Anyone replaced theirs?
- 2003 Stratus Coupe alignment
- Help - Constant missfires on 97 stratus 4cyl 2.4L
- Stratus R/T body kit on Ebay
- April Ride of the Month Voting!!!!!!
- 2.4 In second gen
- MOVED: FS: 19" Chrome Wheels, New
- Headunit kit?
- Changing spark plugs in the R/T 3.0L
- dimater exhaust?
- Replacing rotors and pads
- noise noise noise
- oil pressure light flickers
- Need a new 3.0 clutch BADLY!
- Lots-O-Questions
- Folding Rears
- Engine Shield
- annoying problem...
- oil filter location...
- 1996 Dodge Stratus won't start
- Turbo headers and down pipe for 02 R/T
- good gas
- need more sound!
- I need help with my Stratus
- hello, should i get one?
- projector lamps
- headlight warning light location?
- Random Question
- Headlights
- haha this is funny
- throttle body
- Spark Plug Wire for my 2.4 liter!!!
- question
- Bad power steering pump? Rack?
- 2001 Sratus has a miss
- keyless entry remote
- gauges and dashboard lights
- Free higher MPG
- rev limiter set a 4000 RPM ????? (fixed now new problem i know some of u know
- chips
- speakers...
- Keyless Entry/Remote Start/Alarm
- 00 stratus ?
- 2002 Dodge Stratus, BAD IDLE HOT
- Wrecked my Stratus
- 2.4L More Torque???
- 2.7L question
- speedo - rpm
- decided..stratus r/t
- 96 2.4 Fans and funny idle
- Cigarette lighter not working
- 2004 stratus r/t suspension
- car making a noise
- Help and Old Dodge dude out?
- Old Dodge Man needs NEW help
- Oil Filter
- Dumb Question
- Buying a 01 Stratus R/T
- No Owners Manual=More dumb questions.
- 1997 STRATUS
- Stratus tuned up?
- Cheapo Enhancements. Good or Bull?
- 01 Tech Articles?
- Internals...Forged or Cast?
- 2001 Stratus R/T Creaking from Front End
- air intake
- 1998 Stratus ES Transmission
- Hello and Questions
- AC/Heater motor only works on high
- Intake Problems
- Wheels - American Racing 17X7.5 CHROME SNIPER
- rotm
- intake
- Stratus owners get your ROTM vote in!!!
- stratus 02 transmission problem
- Ride of the Month
- 97 Stratus won't start
- Struggling to live
- Headlights
- Tints
- Timing belt condition, about R/T, RPM range
- where is the spot to set my floor jack?
- 98 Srat 2.4l problems...help?
- please help me
- Locks frozen
- Trunk release problem
- 2000 stratus inner tie rods - HELP!!!!
- 2001 dodge stratus brake light
- 95 strat tranny troubles
- valve timing - help!
- How do I reinstall crank sprocket??
- Steering wheel removal
- HELP!
- 01 driver side mirror replacement
- Transmission change out/ rear main engine seal
- seat covers??
- 2005 RT or 2006 SXT
- Purple Ice
- Brake line won't bleed?
- Front door speakers dont sound
- '04 STRATUS SXT WITH DUBS!!!
- Brakes
- Mufflers...
- 1997 Stratus turbo?
- Drilled & Slotted Rotors
- Plugs on 2.7
- hid or other
- Question about TCM.
- Stratus Transmission
- best wheel size for 01' dodge stratus ???
- My new 2005, weee
- CB radio question
- 04 STRATUS R/T
- antifreeze question
- Pictures
- timing loop idler wheel replacement?
- 2.4 w/manual trans??
- no spark no 2 and 3
- 98 strat help
- Good Site for Spoiler for 2001 Stratus
- 2001 SE Coupe - Adding Keyless Entry
- power window problem
- Emblems Needed
- Strange Noise
- Passenger side door panel removal
- Interior Long-shot
- replacing starter in 99 stratus 2.0
- 95 stratus shaking....
- Need to adjust headlights/headlights too bright
- System Install Help and Fog Lights
- How to?
- 00 dodge Stratus SE 2.4L
- Far fetched idea
- Engine swap
- '01 Stratus ES, Tranny 'thunk' during down-shift
- Worth the upgrade?
- lighting question
- Droped Valve today
- spark plugs and wires
- Stratus Customization Parts of similar Builds?
- 2000 stratus
- 99 Stratus sensor identification/oil leak
- I have some intake problems..help
- 98 Stratus - underhood Fuse #8 Blowing
- Reading error codes...
- Which is better...?
- how do i remove speed governor from 97 Stratus
- Please help.
- 1999 Stratus Turbine Speed Sensor
- 2004 Sedan & 2005 Sedan Same Body Style??
- Just in General, specifically cosmetic changes
- All I want is an answer!!!!
- 97 Strat engine mount bracket
- 2.4L DOHC internal balancer?
- Battery Problems
- transmission problems help!!
- 2001 Stratus Sedan SE - Several Issues
- Head Unit Question
- Lowering Springs
- 3.0L from a stratus in a 03 neon
- Removing the Air Conditioning systen...
- Possible new Stratus convert
- 98 stratus rear o2 sensor code
- [HELP]need suggestions on tires, rim, and launch problems!!!
- 1998 Brake Lock Up
- 2001 Dodge Stratus Maintenance
- check engine light
- Intakes
- FS: Built 5spd V6 Transmission!!!
- Stratus lowering springs....
- 2002 DOHC Removal
- 98 stratus temporarily stalls while driving/foot on gas!
- Projects for the spring
- Stratus question
- Stratus question
- HELP!!! Cd Lights Blinking, Doesnt Work 02 strat r/t
- body kit
- STR4 to 1st gen strat swap....
- cool or tacky
- Electrical Problem-Stratus 1995
- Wireing diagram for a radio
- cooling fans
- Can I just change the amplifier to an aftermarket one without the head unit?
- check engine light came on
- srt-4 motor swap
- Sponsors?
- Turbo Stratus R/T
- ball joint
- vr4 motor
- 2.4L stratus cp performance parts/ eclipse
- spoiler
- what up people
- Headlights Clarity
- clock spring removal ???
- 03 4door Instructions for Programming key fob
- No Heat HELP!
- AC/ Heater Acting Weird!!!
- Putting 18s on my 04' R/T, what size tire to use?
- half shaft (CV axle) problem on 96 Stratus
- 2002 Stratus SXT Heat Problem
- 99 stratus won't start
- 2004 SXT Cpe, Fog lights.....?
- Massive oil leak - 97 Strat
- 2001 Stratus R/T wont idle after it warms up
- Leaking valve cover gasket
- how many cats?
- 2003 2.4 Air Bag Light
- re-wireing
- Air Pressure
- Gas Light
- light size
- Underdrive Pulleys and Exterior Mods
- REMOTE DOOR LOCKS
- engine hickups at idle in gear?
- keyless entry programing...
- '99 Stratus electronics problem
- Check Engine Light
- bodykits
- i need help
- 98 stratus upgrades
- Stratus ignition fuel starter
- Best Light Bulbs.....
- I am so confused
- need new clutch
- 2001 R/T Heater
- valve cover gasket ....
- cat question
- sunroof
- Bigger engine in the sedan
- Mass airflow sensor
- Help Me Out
- Best Spark Plugs......
- Gas Mileage
- Engine swap
- Aftermarket Headlights / Taillights
