PDA
View Full Version : Dodge Stratus
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28
  1. Display panel
  2. Mufflers-Pullys
  3. Timing
  4. Headers and performance chips
  5. wheel fitment question?
  6. aluminum strut mount deterioration
  7. Air Filter
  8. R/T coupe headlights
  9. replys please
  10. VIPER EMBLEM
  11. Car seems to be running hot?
  12. Radio circuit short
  13. custom grills
  14. Headers!!
  15. Gas Gauge!!
  16. keyless transmitter
  17. exhaust!!!
  18. stratus wheel base
  19. Torque settings for oil pan screws?
  20. system
  21. badging
  22. Backup Lights
  23. SRT-4 foot pedals on a 2004 Stratus R/T Coupe?
  24. 95 stratus headers?
  25. Need stuff & Ideas
  26. Supercharger or Turbocharger
  27. Timing Belt Q
  28. Need help with horn
  29. bolt on
  30. Air intake temp. sensor
  31. 20 Inches on my 95
  32. Trunk lid
  33. o2 sensors
  34. 2.4l dohc 1995 manual??
  35. 2.4l dohc 1995 manual??
  36. Performance question?
  37. 1999 Stratus Dash lights will not illuminate
  38. New on here..Need Help ASAP...Stratus question
  39. WANTED-Stratus cd player
  40. 1995 2.5 A/C Specs
  41. 2.4 DOHC HELP
  42. LED 3rd Brake Light Kit
  43. tach in stratus
  44. 02 Stratus SXT 2.4 SOHC Oil Pressure?
  45. How to r/r rack & pinion 97 Stratus 2.4
  46. Tricked out Stratus RT
  47. 99 breeze
  48. 99 breeze
  49. 99 Dodge Stratus ES Help
  50. check engine light
  51. '04 Stratus Sedan
  52. 98 Stratus oil leak - not head gasket
  53. need help with thermostat
  54. bore and stroke 95
  55. '04 Stratus sedan engine probs
  56. New higher compression pistons??
  57. Srt-4 into a 98 stratus?
  58. stratus paint codes HELP!!
  59. Re: 2001 stratus-bad batt. and radio issues
  60. Finally a magazine for the Stratus!
  61. Help-Burn fuse
  62. windshield banner
  63. Stratus Turbo
  64. FS Set of stratus Pistons
  65. battery light
  66. 04 strat sxt
  67. New Member
  68. Stratus AC Compressor
  69. 01 r/t performance mods
  70. Fuel gauge and light
  71. Radio/CD issue
  72. replacing timing belt
  73. Back bumper of 2002 rt?
  74. air intake 4 2.4L
  75. 96 2.4l engone govener
  76. 96 Dodge Stratus 2.4l Thermostate
  77. Rear speaker installation - getting to rear deck help
  78. Sub Installation
  79. Can't shift into park - 1998 ES - V6 - auto
  80. Stratus "S" Package arrived today.
  81. fuel pump relay switch
  82. 1997 stratus for sale
  83. installing cd player in 2000 stratus
  84. 2000 starter stays engaged
  85. car wont start. oil level relay????
  86. bad coil, had to replace distributor
  87. '06 Stratus Arrival??
  88. No more Stratus coupe.
  89. Cold Air Intake for 04 R/T Coupe
  90. starts,but wants to die when cold
  91. 2004 stratus sxt with a turbo?
  92. Wiring Trailer Lights for 2001 Stratus
  93. 2001 RT Sound System Questions
  94. Anyone else having these troubles? (2001 RT)
  95. Wiring schematics?
  96. Power Steering woes
  97. dash speakers?
  98. CAI for my strat?
  99. CD Changer Options for 2005 R/T
  100. In need of help
  101. Dreamspeed cold air intake questions
  102. superchargers
  103. '97 Stratus ES
  104. 2004 Dodge Status engine light on
  105. MOVED: No Bus?
  106. 2004 stratus coupe R/T - Experiences
  107. Any Ideas!!!!
  108. Here's my plan
  109. gurgling sound?
  110. ABS light
  111. hi flow cat converter
  112. help!!!
  113. Wheel offset question
  114. brake warning light
  115. Stratus 2000 Strut Replacement
  116. Purchasing a Stratus/ 2 to choose from
  117. 97 transmission problem
  118. brakes for stratus r/t
  119. Noise coming from timing belt cover
  120. 1999 Status Timing Belt ?
  121. stratus computer
  122. Cold Air Intake for 2004 stratus 2.4Liter
  123. Just bought 2004 2.4 4cyl stratus
  124. 2000 dodge stratus problem
  125. 2005 Stratus SXT
  126. HELP ME! Stratus R/T Insurance is terrible!
  127. 97 Dodge Stratus
  128. 96 dodge stratus problems "please help"
  129. 20+hp speedchip
  130. cold air intake?
  131. IAT (Intake Air Temp.) sensor
  132. hoods for a 97 strat
  133. R/T symbol
  134. 1995 stratus no start
  135. throttle body on 97 strat
  136. srt 4 motor
  137. Tail light and body mods
  138. Where is the Idle Air Control?
  139. Got My Lower Control Arm Replace For Free. AGAIN!!
  140. BEST WAYS TO ADD POWER/SPEED
  141. 95 Stratus wont start HELP!
  142. how to remove governor
  143. Turbonator
  144. do i have keyless entry ? ?
  145. Fuel Filter and Other Mods
  146. Considering Stratus R/T purchase.
  147. How much to replace the timing belt?
  148. 96 stratus 2.4 l dohc trans type
  149. engine stats
  150. newbie
  151. a
  152. rear disc brakes?
  153. How to check codes on a 99 stratus
  154. 99 Stratus ES 6 Disk Changer problem
  155. 96 w/ epilepsy
  156. Maint questions.
  157. 2.4l I4 interference or no?
  158. exhaust leak
  159. engine swap
  160. seat belt help
  161. 99 stratus, common problems?
  162. 98 Breeze radiator drain?
  163. looking into buying a stratus
  164. Disconnecting the battery problems?
  165. stratus
  166. New 2005 Dodge Stratus R/T Sedan Options:
  167. Serpentine Belt Replacement! HELP!!
  168. Electrical Problem - 2000 Stratus
  169. Stratus R/T performance chip
  170. were is a good place to find upgrades for my 97 stratus
  171. question!
  172. Crankshaft vibration damper pulley fo 2.4L
  173. which one is it??
  174. Question about the Stratus R/t 3.0 L
  175. 1995 dodge stratus no start
  176. Code P0401
  177. code p1294
  178. SORRY, DUPLICATED BY MISTAKE
  179. Stratus 96 Remote
  180. damn water pump
  181. 96 Dodge Stratus
  182. 96 Cirus w/remote start has elec woes (long)
  183. 2003 Startus R/T Sedan - a few questions
  184. tire recommendations for 2003 Stratus SXT?
  185. badging?
  186. just bought a 2004 Dodge Stratus
  187. 99 Startus rough idling ... help
  188. hidden buzzing/motor sound
  189. 2002 and 2004 Starus use the same cd Housing
  190. Model # for 02 cd player
  191. throttle body
  192. 2001 windshield washer leaks
  193. 3.0
  194. Brakes & washer fluid shooter on a 99
  195. I bought a 2003 stratus R/T
  196. 98 stratus ES needs cold air intake
  197. 97 Stratus - Sat a while...what to expect?
  198. i need some more power.....
  199. 2003 Dodge Stratus SXT Sedan Problems
  200. 97 Stratus - how do I turn off "check engine" light??
  201. turbo
  202. What size muffler for 3.0L
  203. 2002 dodge stratus r/t coupe performance stats???
  204. 2002 dodge stratus r/t coupe performance stats???
  205. 1997 Dodge stratus misfiring? Poor acceleration.
  206. Custum Paint/ Graphics
  207. 2002 dodge stratus code p0018 p1684
  208. 2001 Turbo?
  209. just bought a 97 Stratus looking for more HP
  210. '96 Stratus 2.4 Tranny in limp mode
  211. Blower selector
  212. 95 Stratus not running after timing belt and head gasket repair..pls help
  213. Can I Get $12,000 for a 03 Stratus SXT
  214. '96 Stratus 2.4 Head Gasket major help wanted
  215. 95 Stratus wont start, need help ASAP
  216. how do i check codes?
  217. 02 stratus se. Please help
  218. another question
  219. 97 stratus questions
  220. Supercharger on an R/T
  221. O2 Sensor?
  222. 99 Stratus - Vibrates when Idling
  223. 20 HP "Chip" on Ebay
  224. Exhaust: 03 2.4 Coupe
  225. Heater blows cold air
  226. Newbie needs help
  227. Checking the Timing on '98 Stratus(4cyl)?
  228. OK DODGE GUYS, HELP!
  229. Speaker/Preamp Problem
  230. Searching for aftermarket parts..??
  231. Alarm Problem!
  232. 98 stratus engine coolent problems
  233. Spark Plug Wires
  234. Speaker install
  235. 96 Cirrus Instrument Cluster Problems
  236. HD struts
  237. 2001+ Stratus 2.7L sedan HD struts
  238. Check Engine: What the Dealer said...
  239. I have A new 2005 stratus coupe
  240. Check engine light and bucking.
  241. DF, my last hope for unknown problem.
  242. You think your fuel pump is fine.. Check this out
  243. 97' stratus rear speaker removal
  244. Eibach Lowering Springs
  245. PO 171 Code
  246. Ignition problems
  247. type and weight of oil; OCI
  248. (SORRY TO INFORM EVERYBODY BUT MY CAR WAS STOLEN LAST NIGHT. THEREFORE NOMORE STRATUS FOR ME AND FOR
  249. SES: Multiple Cylinder Misfire?
  250. 2000 Stratus Crankshaft Position Sensor Question
