View Full Version : Dodge Stratus
- Stratus SE Engine Swap
- 95 dodge stratus 4 door sedan help
- Will these rims fit?
- 2001 Stratus r/t compass temp display mirrors
- Where does the oil come from?
- New Pics Finally...
- Speed Limiter?
- Wheel and Tire Options?
- Update on Stratus bucking after fuel up
- cigarette lighter dead...no fuse???
- 01 Stratus won't start, dash lights and radio dont light up
- Squeaking in steering on L side; '02 with 70Kmiles Help!
- 2002 resistor please help
- Growling
- rear suspension 2002 dodge stratus sxt shocks or stuts?
- 3.0L engine coolant...
- 2001 Stratus R/T Alternator problems
- heat and oil light issues
- Weird stalling problem
- 2001 Dodge Stratus RT - AIS Motor
- finding what cam on the car
- 04 headlight replacement
- Touble code question
- Coilovers...
- How much power can you get from the 3.0?
- Wheel Info
- Stratus Sedan SE 2.4L
- front end squeeking
- looking to get an 04 sxt coupe...
- Some help please!
- 02 R/T amp wire
- Forced Interior Face lift..
- power steering tensioner removal
- selling my new apexi safc2
- Air horns
- how much abuse?
- WHERE IS THE CRANK POSITION SENSOR??!!!
- Intake Mod Question
- Door Noises on my 98
- Tach ODO and Gages dead after installing aftermarket Stereo
- opinion on wheels
- engine problem
- HAS ANYONE DONE THIS?
- Violent shaking... please help!
- O2 sensors and replacement
- 1999 Stratus NO START - Electrical
- ATF leak
- 18" rims or lowering springs?
- 2000 Stratus Power window issue...Help Please!!!
- eclipse spoiler on '02 r/t
- Engine Swap Help
- annoying sound coming from front tire area
- changing front wheel bearing
- headlight bulb replacement '02 Stratus
- anybody know about this
- Alarm
- HID Kit for a 03 RT
- Please tell me its not the head gasket
- thumping
- Clicking and shaking in front end
- Coolant Light On
- What do you use to jack up the rear using a floor jack?
- 2004 R/T High Miles
- SHIFT
- HELP! 2.4 L
- stratus
- 02 Stratus - Noise and Electrical
- '02 R/T questions
- What the heck gear is this?!?!
- 3.0 or 2.7
- LED Dash Bulbs
- Just installed my new springs
- something doesn't seem right here...
- Possible wheel baring going? Axle? I have no clue!!
- EVERYONE PLEASE DO THIS POLL
- 1998 Dodge Stratus ES V6 hesitating, need help please!
- Heavy vibration
- Rich from Dreamspeed
- Quick! How To Remove Passenger Seat?
- Stratus reaer wheel drive conversion
- Switch under steering wheel
- 01 Stratus R/T 3.0 - changing alternator HELP
- 03 stratus bucks/pulses
- 2.7 MAGNUM EMBLEM
- 05 RT going off
- 96 stratus stalling!
- 04 Stratus rough idle..
- 01 Radiator stop leak questions
- 05 Stratus, Weak horn
- '98 Stratus electric problems..
- Headers
- New Dodge Avenger concept car, Replacing the Stratus, what do yas think?
- engine turns over,but doesn't start.
- is it worth doing it yourself?
- Help Please
- 96 stratus coolant temp sensor.!! help
- MPG worse than my truck
- Cold Air Intake for 06 Stratus
- 2000 stratus radiator drain plug
- Jet Power Control Unit 96 Dodge Stratus
- defroster smells
- 97 Breeze 2.4 Auto Trans quirks
- Noise from tranny?
- 1998 block heater
- 97 Strat - parking brake equalizer?
- Disconnecting battery on '99
- My key is sticking in the ignition
- Fan Not Blowing on #1 Only
- 98 stratus remote starter
- Power Steering system
- go faster?
- Rams for my 97 Dodge Stratus. Winter Tries
- srt swap?
- 1/4 mile with a high stall torque conv.
- '98 Stratus Brakes, Can't figure out what's wrong.
- 96 stratus start issues
- 3.0 R/T running too cold
- spark plugs on my 2004 dodge stratus rt 3.0L V6 engine
- 2004 Dodge Stratus RT 3.0L V6
- map light switch problem
- 97 Breeze 2.4 Auto Trans fluid
- '99 Dodge Stratus Bracket
- Can't find the parts
- Changing the battery
- Attn: 2.0L stratus owners!! turbo package 4 Sale
- 2000 dodge stratus cd player
- 2001 Stratus: Heater blows strong, but not hot
- 01 4 Door sedan rear driver side window...
- 97 2.4L Stratus Rough Idle After Timing Change
- 97 Strat parking brake problem?
- 99 stratus fuel filter?
- 95 starus Ecu question
- speakers
- Clicking ... again
- 3.0 Clicking
- weird engine sound on r/t
- '97 to '96 ECM Swap
- 2000 dodge stratus AC System
- Platinum spark plugs
- Power Steering Issue
- 2002 stratus 4 dr, Ignition question.
- Tranny Fluid
- Squeeking noise from frontend
- Question about the fan in the Dodge Stratus
- 1996 2.4l cirrus codes
- DASHBOARD SPEAKERS
- 2003 Dodge Stratus R/T, slightly moded, FOR SALE - $12,884! PICS!!!
- gauge cluster modding
- No power and wont shift
- 98 Stratus outer tie rod ends.
- '99 stratus
- POPING NOISE WHNE TURNING HARD LEFT
- converting the muffler on the R/T to Infiniti G35
- Stratus Gas Flap
- 96 Dodge Stratus Turbo, and rear disc brakes
- Newbie here with remote starter question.
- spark plug change help please!!
- Do you guys use 87octane?
- 06' Stratus - Running Rough After Gas Fill Up
- project potato chip mopabishi 2.4?
- Stratus sputters after I fill the tank
- Power steering acting weird
- WHEELS NEEDED
- 2004 Dodge Stratus R/T Coupe
- i attempted changing my plugs, this sucks
- checking codes
- ODB2 Recomendation
- 97 Stratus won't start
- MOVED: how to get rid of rust?
- 2.4L clicking...
- engine removal how
- Cruise Control glitch?
- changing engines
- hood question (suggestions or ideas)
- new Stratus/Sebring owner with some questions
- freeze plug blew
- Gravel in Stratus Transmission?
- evo head work on stratus too?
- air intake
- Changing Front Wheel Bearing?
- How long does it take to clear codes on my Breeze
- Online diagnostic and repair ... is itworth it?
- Clutch Plate for '01 Stratus R/T is $850.00 !!
- 1999 speaker replace???
- Cylinder head torque and new tensioner
- Oil light flicker..car sputters, shut down..dealer is clueless
- 01 stratus V6 # 1 spark plug. Wife's car.
- hey everyone
- ATTENTION!!!
- ABS ECU...... I think
- question on pcv value...
- Looking for Racing Struts?
- misfiring
- Strange Noises....
- help with engine diag code
- please help won't run right????
- clear corners
- crankshaft position sensor/ 99 stratus
- 99 stratus crankshaft position sensor
- 2000 2.4 Stratus idle problem
- Need help with check engine codes
- CA: Looking for a 01-02 Stratus sedan for testing, will pay $200.
- Bleeding ABS Brakes - 2000 Cirrus LXI
- Aftermarket Parts
- Looking for a 2001 Stratus AMP
- Oil pressure Issues
- tires for stratus rt 02
- timing belt replaced now throwing engine code?
- Fuel Pressure Test 2000 Cirrus LXI V6
- Stratus Vs. Intrepid
- KNOCKING!!!!
- 01 stratusr/t heater problem
- Timing Belt Visibility - 2000 Cirrus LXI
- heater
- considering a '99 coupe
- Coolant Temp Sensor?
- Timing Belt Change
- Stratus RT front bumper
- muffler ground wire.
- 99 STRATUS RADIATOR PLUG LEAKING AFTER I DRAINED RADIATOR
- 'CHECK ENGINE' ... !!!
- 97 oil light issue...
- Dreamspeed headers?
- 96/98 pistons
- Car won't start
- Stratus milage?
- 97 2.5 v6 question
- need help about about a kit...
- is it tranny?
- lookin a t a pp sedan i need help!!
- Need Help With Mods...
- '97 Stratus Tranny Swap
- 1995 V6 transmission in limp mode
- 98 4cyl longevity
- Dodge 2004 coupe tech info /what engine oil
- guages dont work.
- need some advice or ideas
- I need a little help !!!
- HID convertion kits?
- 2005 Body Kit
- Check Engine light now off after wheel bearings replaced?
- 2.4 DOHC VIN X
- CV joint locations on 2004 Stratus Sedan
- 2004 r/t parts car posted in the classifieds
- 2.0L no spark?-read this
- auto vs 5 speed
- MAF adapter
- 2004 Stratus Service Manual?
- New here, old at 2GSS
- Replacing the stater
