PDA
View Full Version : Dodge Charger
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16
  1. Question about the Transmission Oil ??
  2. Powerful CAI Kit with Donaldson's® PowerCore™ Filter for your Charger
  3. clicking/fluttering noise
  4. clicking/fluttering noise under driver side dash
  5. 07 Charger all warning lights come on while stopped
  6. Rattling noise on my '10 charger
  7. Hemi 5.7 withe Noise..
  8. HID Conversion Kit
  9. Radio Freezes Up!!
  10. Flash to pass issue
  11. has anyone ever had this problem???
  12. Seqential Tail lights
  13. p0420 after full exahust install
  14. Heater clicking?!?
  15. 2011 R/T 5.7 Litre - Headers and exhaust
  16. Buzzing noise in dash.
  17. 2011 MOPAR 11 CHARGER Brake Issues
  18. Help my Daugther put diesel in my gas tank 08 Charger
  19. Blend door actuator replacement
  20. 3.5 V6 swap for 5.7 V8
  21. How to setup Remote Start
  22. Front End Noise
  23. fuse Box
  24. Dynomax dual exhaust system for 08 SXT
  25. just got one! Performance questions
  26. help dodge charger from estonia
  27. ABS Module
  28. Charger r/t misfiring on cylinder#5
  29. cop car
  30. Engine knocking
  31. Recirculation Door Actuator problem
  32. High beam indicator issue
  33. No Audio Music Back Button? Or Am I Stupid??
  34. 2014 charger starting issue.
  35. 2007 Dodge Charger 2.7 to 3.5
  36. Dodge Charger Performance
  37. 2007 Charger Drive Cycle
  38. Weird Code: 2007 Dodge Charger 2.7L
  39. 2011 Charger RT gear shift light bulb?
  40. Dragging/Shaking w 2008 Dodge Charger
  41. 5,7 Hemi Ölpan Gasket
  42. The Insane 2015 Dodge Charger SRT Hellcat on Display at the OC Auto Show! 707 hp Mons
  43. charger wont start
  44. Front Turn Signal Lamp
  45. Are superchips really super?
  46. Can't turn key to the on position on my 2010 Charger
  47. Need AC on to defrost?
  48. Backup camera has become crooked
  49. 07ChargerSE cooling system help please! Fan kicks on, temp gauge drops!
  50. 06 Charger SXT P0300
  51. Power adjust driver's seat not working
  52. 5,7 Hemi makes a (bad) noise ?
  53. body drains\ water leak\ door gaskets?
  54. 13 awd charger question
  55. This Chrysler 300 Puts the "Racing" in SRT
  56. 06 Charger 3.5 better sound
  57. Battery Saving Mode and Battery Light On
  58. after market acc
  59. All Calipers Locked Up on My 2014 Charger
  60. 2014 Dodge Charger Shifting Issue.
  61. 2007 Dodge Charger SXT 3.5 Engine
  62. When the factory style is not enough
  63. stuck
  64. show me how to remove dodge charger headrest 2010
  65. smelling outside exhaust through my AC
  66. Smelling outside exhaust through my AC
  67. fuses
  68. Tire Shredding Tuesday: Dodge Charger Garage Burnout
  69. Code U0103 Lost Comm to gear shift module
  70. Tire Shredding Tuesday: Charger vs Challenger burnout
  71. A Better Way To *Show* Your Charger
  72. Moonroof help!!
  73. Member moving over from 1st Gen Durango
  74. Cat Problems!!!
  75. Intake manifold
  76. Charger/Challenger Manual Swap
  77. Alternator wont charge battery
  78. 2013 SE upgrade question: rear camera
  79. Esp bas ?
  80. Climate control problems
  81. 2008 Dodge Charger Valve Cover Gaskets
  82. P0300 code - Random Misfire
  83. Help please stuck in anti theft
  84. How Dodge Could Become The Most Powerful Sedan In America
  85. Should the new Charger get Challenger's Scat Pack Trimline?
  86. Needing Help
  87. Photo of the Week: lillynda's Charger
  88. Installing amp and subs to stock on a 2013 Charger
  89. dashboard malfunction
  90. Air Intake for 2010 Charger?
  91. Dodge Charger R/T Featured for Photo of the Week
  92. Need Help!!!
  93. Michelin Presents Wallpaper Wednesday: 2013 Dodge Charger Pursuit Police Car
  94. Cool or Creepy ad?
  95. maybe its just me but...
  96. Going to miss my 07 Charger
  97. How to get error codes with push button start?
  98. check engine light "emissions leak"
  99. 2007 Dodge Charger – Bigger Rims and Smaller Tires! How about ET?
  100. key fob not detected please help!!
  101. Rust
  102. How fast should my sedan go???
  103. Buyers guide Charger?
  104. 07 R/T AWD having tranny issues... HELP!
  105. Challenger srt8 or Charger srt8 help me decide!
  106. PO522 check engine code or PO520
  107. 3.8 rocker shaft noise Shaft good?
  108. 2008 Dodge Charger Park Light issues
  109. Tuner in the Louisville, KY / Southern Indiana Area
  110. Rear end rumble
  111. Need some help here
  112. Need Help 2006 Charger
  113. 1970 Plymouth Superbird
  114. 2003 Dodge Caravan - $6,000
  115. 2008 Charger Interior Windows Freeze
  116. 2006 ETC light on and sputtering ride
  117. P0300 Code Detected, PLEASE HELP!
  118. Remote Start questions
  119. No heat in '07 3.5ltr Charger
  120. Low coolant temp gauge.
  121. Need help with Crane Cams valve spring tool
  122. 2014 sxt Dodge Charger - AWD?
  123. 08 Charger rearend oil type
  124. 1973 Dodge Charger Fender Vin decoded
  125. 2006 dodge charger turn signal, horn, and wipers dont work
  126. 08 Dodge Charger Driving Lights Problem
  127. 07 charger 3.5 se transmission problems
  128. Knocking in motor when cold???
  129. 2012 Dodge Charger will not start
  130. Detach filler neck from tank on 2008 Charger
  131. New (to me) Charger
  132. tpms problem after new tires
  133. Thinking Charger
  134. 2008 Dodge Charger 3.5 Throttle Issues
  135. 2006 Charger R/T T-stat swap
  136. 2011 5.7 in a 2006 RT
  137. Engine Replacement
  138. I am a new member. Just saying hello to the community.
  139. Charger All Wheel Drive System
  140. Holiday Coupon Code from American Car Craft - SAVE 20%
  141. Can't get lug nuts off 2008 Charger
  142. 2006 charger RT 5.7 replacement
  143. 2008 Charger Police Car Pro's or Con's
  144. Dodge Charger makes howling sound
  145. 08 Dodge charger evap seal leak
  146. help.....my baby ('08 Charger) is really sick
  147. ESP/BAS light not turning on at startup 2006 charger rt
  148. Charger 2007 reverse light wiring
  149. Bluetooth problems, super bee
  150. Seat covers
  151. Cleaning Induction Hose / Fuel System
  152. 07 Charger ETC Light On /Wont start
  153. Several issues on Dodge charger RT road and track 2011
  154. whats the best programmer
  155. plz help
  156. 2007 Dodge Charger H 6874 code??
  157. Wanting to Make the transition
  158. Anyone leasing a 13/14 Charger RT Black Top
  159. Charger meet
  160. Engine swap
  161. 2013 Charger SXT Rally going into limp mode
  162. speed and seatbelt alarms
  163. 2012 SRT8 Mufflers
  164. speed and seatbelt alarms
  165. Throttle Body
  166. Police bumper for charger?
  167. AWD ^ cyl. or hemi and car in winter weather
  168. front end shake
  169. Overheated rear power distribution center
  170. Dion's Car
  171. New addition to the family! Pics inside!
  172. 2009 dodge charger sxt
  173. ProCharger Rewards - It Pays to Choose ProCharger!
  174. NEW: Charger / Chrysler 300 5.7L HEMI Engine Bay Dress-Up from American Car Craft
  175. 2013 SXT Plus Outside Temp stuck at 75 Degrees
  176. switching ac climate control to dual climate control on 2010 dodge charger
  177. 2010 dodge charger sxt 3.5
  178. Frustrated gas gauge problems
  179. '09 in accident, Need opinion on something! Please read!
  180. A/C makes weird noise and doesnt put out cold air
  181. Overheating Issue
  182. 07 won't start
  183. Rough idling Charger
  184. Name that Dodge Charger
  185. Radio randomally switches to and from "AUX"
  186. 2013 dodge charger exhaust
  187. New guy
  188. Switching Dodge Charger Engines
  189. Savini Wheels SV34's Dodge Charger
  190. 08 Charger Headlight Issue
  191. Thinking about it!!
  192. 2010 Charger
  193. Pulling engine need help
  194. Explanation please??!!!
  195. Uconnect favorite's issue
  196. front end rattle 07 3.5 charger
  197. 2010 Dodge Charger
  198. Noobie
  199. 2008 Charger Alarm/Eletric Issues
  200. best oil
  201. RWD performance in slippery conditions?
  202. My headlights keep turning off
  203. Bad, bad squirrel
  204. serious question, possible to replace my V6 with the V8 hemi?
  205. Introducing Myself New Pursuit Charger :)
  206. Is the 2008 Charger hard to diagnose codes?
  207. 2008 starting issues
  208. Top Speed
  209. Drone
  210. common problems
  211. 09 Daytona Top end tick/knock
  212. 3.6L Pentastar CHARGER SUPERCHARGER SYSTEM?
  213. 2006 Charger -- Clicking in Driver's Door
  214. need help please.!!!!!!!!!
  215. 3rd stoplight on 08 charger
  216. rims
  217. Trouble with uconnect
  218. HID OEM headlight malfunction
  219. Dead Spot
  220. 06 charger r/t shifter locked..getting irritated
  221. Down shift hint
  222. better performance
  223. ves questions
  224. up grade performance
  225. better performance
  226. Programmers
  227. Center roof console map light rattle
  228. Disable Auto heated seats?
  229. 2007 Charger AWD R/T RIM INFO NEEDED
  230. Can some help..
  231. Cheap Cold Air Intakes
  232. blower not working at all and airbaglight is on
  233. Alternator connector and wires to the connector
  234. Charger Alternator, Which is Which and How Do You Know??
  235. 2008 Charger With Similar Shifting Problems
  236. Spoiler diy
  237. need help
  238. 2012 Charger SXT SPEAKERS!!!
  239. any help would be appreciated 2007 charger 3.5
  240. Popcorn noise
  241. American Car Craft scheduled to shoot segment on Motorhead Garage!
  242. My 2007 dodge shakes alot
  243. 2007 chager 3.5 won't turn off.
  244. help! 2007 3.5 charger no heat at times and sprays out overflow tank
  245. exahaust on 11 charger se
  246. Orange indicator on dashboard
  247. 2.7 liter water in oil
  248. 2013 Uconnect voice commands
  249. Front End Rattle Over Small Bumps
  250. Rearend "wobble" on '09 SXT
