View Full Version : Dodge Stratus
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15
  1. stratus
  2. 2005 2.7 Dodge Stratus Running problem
  3. fan speeds on climate control-1+2 inop, 3+4 ok
  4. Stratus SWAP NEED HELP
  5. Stratus SWAP NEED HELP
  6. air temp sensor?
  7. 2002 Stratus Tranny Trouble HELP!
  8. TURBO QUESTION.
  9. RIMS
  10. Unusual Problem With 2005 Stratus ... Need Help Please.
  11. Please Help.
  12. Popcorn Noise or Popping Noise from the front drivers side of a 2004 Stratus
  13. HELP WITH CLUTCH
  14. Gas Savers?
  15. Horrible Shaking on Startup, CEL on
  16. Replacing air filter on '04 Stratus 2.7L
  17. small crack in oil pan
  18. 1995 2.0 shudder under load
  19. 2004 sedan front end knocking
  20. Eclipse parts?
  21. Do you have to drop trans to replace differential bearing?
  22. 2000 stratus speed sensor location
  23. muffler
  24. bulb type
  25. Unstable Idle
  26. Stratus 2006 2.0L P1128
  27. Champion 3570 platinum plugs
  28. Is my old catalytic worth anything?
  29. won't idle.....help plz
  30. Help with 2000 Dodge Stratus Camshaft Sensor
  31. Interchangeable?
  32. Who would win?
  33. high output alternator
  34. 6g72 Turbo Interchangeable?
  35. 05 2.4L sensor on stock intake
  36. Stratus 96 problem
  37. Looking for parts.
  38. IAT sensor in the 06 r/t sedan
  39. lowering
  40. HELP MY STRATUS FRIENDS!!!!!!!!
  41. Service engine soon light .....
  42. power windows ????
  43. 06 Stratus w/tire issues
  44. Cruise?
  45. engine rotates but does not start
  46. Parts 04 stratus
  47. cylinder 6 misfire
  48. .
  49. runs rough
  50. Fuel Pres. issue - has anyone heard of this?
  51. 2001 Stratus Rt
  52. intake question....
  53. is it weird to fill up your tank twice a week??
  54. are recalls good for the life of the car?
  55. P0122 TPS Low Input Voltage
  56. Timing Belt For Stratus Coupe 2.4L
  57. 99 Stratus in "Limp Mode:
  58. Tornado Fuel Saver
  59. WTB: '03-'06 stratus r/t
  60. HID conversion kit
  61. 95 Stratus, Idles, but trys to die when pressing accelerator
  62. Stratus Will not start
  63. 03 Mod Questions
  64. What side is bank 2?
  65. A/C not working right
  66. exhaust leak - any help??
  67. strange clunk when taking off
  68. 2000 stratus won't start
  69. Spark plug wire set.
  70. '99 Stratus speedometer not work
  71. changing the oil
  72. lowering springs
  73. 2 questions
  74. 1 or 2 questions
  75. Dead
  76. paint
  77. look please and help please
  78. 03 coupe 2.4 turbo
  79. '00 ES Stratus 2.5Lv6 Not Starting HELP!
  80. Installing OEM disc changer in R/T coupe
  81. JA stratus work log
  82. couple of questions
  83. P0441 code
  84. Removing Stock Radio Help
  85. lower ball joints
  86. A question on random stalling...
  87. 02 Stratus Body Kit question
  88. Instrument Panel Lights
  89. '04 Stratus Electrical problem PLEASE HELP!
  90. 2000 Dodge Stratus ES/ Installing new deck questions
  91. mystery ticking in engine
  92. Seized Subwoofers?
  93. 98 stratus transmission exploded
  94. Stratus 2.4 no start
  95. Headlights audible warning/dome light
  96. How Much Mileage is Too Much Mileage?
  97. 01 ES climate control whacky, not much control with controls
  98. keyless entry question.
  99. Little things needing some info...
  100. Vibration in motor and in steering wheel
  101. Sunroof Install
  102. 95 Stratus 2.5L Check engine codes help?
  103. Hold Odometer Button + Turn Key = ??
  104. '05 Eclipse 3.0/'05 Stratus 3.0
  105. Split-second loss of everything
  106. Radiator Fans and AC Compress do not run
  107. 2003 Stratus jerks when slowing down
  108. Air filter replacement
  109. Best 1st Gen Year to Get (?)
  110. MOVED: battery draining overnight
  111. 2004 Stratus Drivers Window works intermitently
  112. Brake rattle problem....
  113. Kinda stumbles if I try to accelerate
  114. CAR HESITATES THEN SHUTS OFF
  115. Audio Help
  116. What's in your trunk
  117. dash lights
  118. tires for stratus.. need advice
  119. exhaust
  120. Another stalled car
  121. body question
  122. Idler pulley removal and installation
  123. 97 Strat 2.0 catalytic job - straightforward?
  124. Acceleration Bottlenecks, Misc Performance Mod Questions
  125. no sound from main speakers
  126. Car idles, press on gas it stalls- HELP
  127. Distributor cap and rotor??
  128. PERFORMANCE HEADERS
  129. quick question
  130. Need some help
  131. Projector headlights for 2g and 2.5g
  132. dashboard
  133. Parts Distribution???
  134. Mod Questions for 01 R/T Coupe
  135. Electricity....Friend or Enemy?
  136. Steering wheel vibration while idle..
  137. EGR Valve 98 Stratus 2.4L
  138. Defrost Fan Issue
  139. Stratus diecast/plastic model
  140. body kits
  141. Where is the oil sending unit?
  142. speaker location
  143. Does Any one have any Accessories for sale for a 95 through 2000 strat
  144. Painting door panels
  145. QUESTIONS: Dodge Stratus SXT to SRT PLEASE LOOK!!!
  146. Power Steering trouble
  147. need help
  148. wheel size for 01 Stratus Sedan
  149. 96 dodge stratus 2.4l dohc
  150. 1996 Dodge stratus 2.4l
  151. im new here, and i have problem
  152. Random Questions. '00 ES.
  153. differential bearing bad??
  154. new here
  155. Interesting Smell
  156. Touchscreen console/mount
  157. 18" rims advice HELP
  158. i want power
  159. Radiator fans only work when A/C is on. 2001 2.7 Stratus ES
  160. 1998 Dodge Stratus ES
  161. camshaft position sensor or distributor?
  162. 2002 Dodge Interior Help
  163. I NEED HELP STRATUS 96
  164. transmission kickdown problem
  165. Automatic shift knobs
  166. wierd screeching noise
  167. 2002 RT Transmission Questions: Model and Compatibility?
  168. 18's on my Stratus?
  169. 3.0 Serp Belt Routing?
  170. allseasons put on alloy rim now noise front right!
  171. Show off your interior.
  172. ABS Light & Traction Control Light
  173. 2004 Stratus SE Sedan, Good Value?
  174. 2006 stratus hlp
  175. Auto Locking Doors. How to disable? 00 Stratus ES.
  176. ball joints go every time i put snows on!!!!!
  177. Radio died, disconnected battery, now car is whacked..
  178. 2001 SE Coupe -- Unable to find air intake [[Found]]
  179. 98 2.4L ed714 tran fluid ????????
  180. 02 stratus remote
  181. 2004 2.7 dohc oil leak???
  182. Horn
  183. 99 Stratus 2.4L does this wierd thing...
  184. Location of o2 sensor bank 1 sensor 1 ?? Dodge Stratus 97 2.4
  185. 99 stratus AC problems
  186. How to replace Exhaust Manifold?????
  187. 97 Stratus 3.5L won't start
  188. 2000 ES - Red dot in cluster.
  189. Question about ATF.
  190. Just got an '01 Stratus RT Coupe
  191. Proud new owner of...
  192. 02 Sensor location cause of Check Engine
  193. What to do.
  194. Noisy strut passenger side
  195. possible skip
  196. Air intake for Dodge Srtatus 97 2.4
  197. Alarm System & Keyless Remote Help
  198. DOOR HANDLE
  199. Front Defrost Problems
  200. Need help ASAP
  201. drum brake troubles EERRR! 98 w ABS
  202. Please help with broken hood latch cable
  203. trunk
  204. Coupe owners...timing belt replacement?
  205. Odd electrical problem
  206. I now own a Stratus R/T coupe
  207. 1997 dodge stratus 2.4l auto trans
  208. Blows only cold air
  209. paint job
  210. removing harmonic balancer
  211. compression ratio??
  212. bought a 2000 stratus motor
  213. 2004 2.4 engine timing belt
  214. R/T Center Caps
  215. no spark / won't start.
  216. will a 2005 bumper fit on my 2001
  217. Noise in dash after evaporator change
  218. IS MY ENGINE BAD
  219. 2000 stratus es v6 auto transmission solenoid leak
  220. 02 R/T ..... Differential Oil
  221. any xtra oil pans layin around
  222. 2.4l head ticking
  223. FOR SALE: Headlights/Billet Grille
  224. Inadvertent alarm disabling my 96 Stratus
  225. Stratus coupe front brake conversion question
  226. post winter start up
  227. I love my '98 Stratus ! Any die-cast of it ?
  228. used Stratus or new Caliber?
  229. Dash lights out 2000 Stratus
  230. hey i got a brain twister for ya
  231. Overheating after oil change.
  232. still problems
  233. Remove engine & cradle?
  234. Best Spots to Apply Sound Deadening
  235. 2001 stratus with front end grinding noise
  236. thanks from a dodge owner in trouble.
  237. The newer Stratus's Mitsubishis? Lottsa questions
  238. floor pedals
  239. 2 questions
  240. need help CODES
  241. '96 V6 no start after engine replaced
  242. 2000 Dodge Stratus Spark Plug Location...
  243. 98 stratus problem still !!!!!!!!!!
  244. 2000 stratus electrical issue
  245. Hey Everyone...weird issue?
  246. Hello all quick question(s)
  247. weird idle
  248. Stratus coupe questions!!
  249. 2004 Dodge Stratus R/T Coupe
  250. Engine Removal Question
