PDA
View Full Version : Dodge Neon
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15
  1. For Sale
  2. seat belts dont work
  3. new memeber a few ?
  4. spring clamps
  5. MOVED: hi everyone
  6. Auto Trans noise
  7. Knock / tap noise when releasing gas pedal
  8. Compression Test
  9. STOCK TAILS 30SHIPPED OBO 1ST GEN
  10. 2002 Dodge Neon Errors codes/how to repair
  11. 96 neon ac questions
  12. 96 sohc, some blue smoke
  13. 96 neon door button?
  14. Buddy Club 2 Body kits?
  15. 02 neon
  16. passenger side rear wheel won't turn
  17. Idle drops to 500 on 2001 Dodge Neon
  18. 2003 Neon tranny problems!
  19. most powerful engine in dodge neon 05
  20. motor swap
  21. Blue,and Red Turn signal Bulbs,Blue Side Bumper Bulbs,Tails.
  22. Turbo on Dodge Neon 00
  23. HELP !!
  24. turbo neon?.
  25. Srt 4 muffler on a dodge neon 00
  26. ATTN NEON PEOPLE
  27. I can't reply to the thread I started about the 70 mph rpm
  28. What's the rpm at 70 mph for a 2001 Neon?
  29. BodyKit
  30. 2000 neon door lock noise
  31. engine shakes between 50 - 60 mph...
  32. problem with ECU/Dials??
  33. Turbo Help
  34. Engine Knocking
  35. Car won't start Starter Relay????
  36. Neon Problems
  37. Intermittent won't start problems
  38. i want to get my neon tinted
  39. This post could keep you out of jail literally
  40. Headlight trouble. A short perhaps?
  41. '04 Neon SXT conversion to SRT 4
  42. Laser Turbo?
  43. test
  44. engine light
  45. 2004 neon will not start
  46. Code question
  47. HP Rating of 2.4l motor??
  48. My 1st Neon. Body Kit Help
  49. 2000 neon having idling and vibration issues
  50. Timing belt question for those who know
  51. Neon Shakes: Do You Know Why?
  52. Congrats to dtjackten
  53. racing springs
  54. ATX 96 Neon w/mods vs mtx 03 With exhaust and intake.....who would win??
  55. 2002 neon 4 sp.AT 2.0L
  56. 1gen to 2gen exhaust does it swap?
  57. More Nufflers
  58. clutch hydraulic hose
  59. Oil Light turns on and off
  60. plug wire broken HELP
  61. For those of you with oxidized headlights.
  62. 2nd gen auto to 1st gen man
  63. my neon makin a weird sound
  64. Need help with Codes
  65. New Picutres
  66. DIY Turbo
  67. Ricer Post!!!
  68. Power Door Locks
  69. Modified Neon collection
  70. Engine Problems
  71. Neon Oil Light
  72. Could you guys help out someone in my section??
  73. NEED HELP: sxt wont start!!!!
  74. Ready for $10 per gal?
  75. Question bout white smoke
  76. Question about the dohc swap to sohc
  77. sohc to srt conversion
  78. clutch slave & master cylinders
  79. clutch break-in!!
  80. I got banned from org
  81. Instuctions on How To install A Head Gasket?????
  82. so i got a clutch master..
  83. SRT-4 catback trade?
  84. Any people in MN?
  85. I have a neon and my back is freakin' killing me
  86. speed mods
  87. PICS OF YOUR LADIES WITH UR NEONS...
  88. Airbag Light, and Horn
  89. who have you beat?
  90. bogging problems
  91. Rims
  92. suspension kits
  93. P0441 Code--few questions
  94. neon r/t motor
  95. SRT-4 claims, are these true?
  96. What color should a neon be?
  97. transmission fluid
  98. CarDomain Sites
  99. Oil Pressure Light Question
  100. Exhaust???Please Help
  101. Dodge Newb Needing Some help
  102. power side mirrors?
  103. Power Door Locks, Fix?
  104. 2003 Neon SE - Horrible Gas Mileage (14mpg) and Lack of Power
  105. Venom 400 Performance Module Help '98 Dodge Neon
  106. 2004 Dodge Neon Issues FREAKING OUT!
  107. HELP 1995 DODGE NEON
  108. CIG LIGHTER PROBLEM!!!HELP ASAP!!!
  109. what year of neon should i get?
  110. calipers
  111. FS: SRT-4 Spoiler
  112. 2000 neon 5th gear
  113. 2001 es, 140k, should i buy?
  114. should i go with these pistons and rods?????
  115. Neon Noise
  116. EBC Brakes
  117. bellows tube
  118. Brakes Soon
  119. 2000 neon help
  120. SHould i get it?
  121. bad/good oil products
  122. i need cheap and easy proformance
  123. Long time no post. Advice on lifter tick?
  124. Help! with my 96 neon timing belt/ crankshaft pulley
  125. srt rods and pistons FS:
  126. I'm losing my mind!!!
  127. rollcage for sale
  128. brake trouble
  129. Exhaust
  130. AF/X or Mopar?????? PLEASE HELP
  131. hey i need help with my intake
  132. dodge neon problems
  133. Any Albuquerque based Neon tuners?
  134. Any Advice On What I Should Add
  135. 97 neon Trans? Maybe CV?
  136. Rear Disc Brakes
  137. rear lateral / locating arms
  138. Driver Side Door handle
  139. does any one know if im able to put lowering coilover on stock suspension like KYB OR GABRIEL shocks
  140. i want to buy 2.0 block or m/t
  141. srt4 motor swap
  142. new member here! nascar ftw!
  143. how do you know your neon is DOHC or SOHC
  144. Looking for neon around 500
  145. hidden treasure
  146. Please help!!!
  147. srt4 engine in 00 neon
  148. performance vs. stock clutch
  149. Intake manifold probs
  150. MOVED: 1999 DOHC in to 1995 SOHC
  151. Any Neon clubs in E.Central Tennessee?
  152. MOVED: Mass Air Flow or O2 Sensor ?
  153. MOVED: timing belt
  154. MOVED: I need help from someone who is really NEON car smart!!
  155. Help ??
  156. Royal Purple
  157. MOVED: Control arm
  158. WTF
  159. MOVED: 98 Dodge Neon_Fuel Pump & Blowing Fuse
  160. MOVED: SOHC performance cylinder head
  161. MOVED: rear control arm bushings
  162. MOVED: Frontend
  163. For sale: 2nd-gen neon OEM stereo
  164. COTM
  165. MOVED: Neon stalls when turning right
  166. keylock repair
  167. 2 questions.. help plzz?
  168. Instrument Cluster
  169. MOVED: Custom Alternator Bracket in 02 Neon HELP!!!
  170. Reputable online auto parts stores?
  171. How much ATF?
  172. sohc head problem
  173. NY State exhaust laws?
  174. 99 dodge neon stops running too
  175. spark plugs
  176. dropped
  177. new proj. help
  178. 2005 Dodge neon 2.0 auto HELP
  179. Clutch problem?
  180. My car keeps cutting off, HELP!!!
  181. not firing on 2 and 3 plug
  182. Factory injectors
  183. blown head gasket or oil pan gasket?
  184. ???
  185. necessary to do when replacing clutch?
  186. Glasspack?
  187. 2004 Neon SOHC 2.0
  188. check engine light is still on
  189. manual transmissions
  190. clutch brands
  191. Staling and hard starting 97 dohc neon
  192. Replacing Clutch
  193. How to tow a 95 neon
  194. any1 wants 2 buy a neon
  195. Cardone
  196. SPEAKER BOX FOR SALE!!
  197. Im' new
  198. Tranny problems
  199. no crank
  200. engine knocking
  201. engine knocking
  202. Dodge Neon 2000 Transmission Issue
  203. noob
  204. Performance Calipers upgrade
  205. cv axles in auto manual swap
  206. where is the door fuse
  207. Performance Calipers
  208. I WANT TO BUY A NEON
  209. Trouble brewing?
  210. Neon R/T 2001 Turbo?
  211. MOVED: 1995 neon no power to coil pack
  212. need to install a tach.. help?
  213. just an average canadian hopinnf to find out ideas
  214. auto to manual swap, what do i need...?
  215. MOVED: wheel hub assembly
  216. where does tach hook up to?
  217. MOVED: Dual Exhaust
  218. MOVED: Won't Shut Down - 2000 Neon
  219. Dodge Neon obc code P0172
  220. MOVED: Saturn Muffler on Neon
  221. FS: Sparco pedals & SRT-4 shift boot.
  222. MOVED: Steering Gear change?
  223. MOVED: Lower control arms
  224. MOVED: Brand new battery isn't getting a charge from the brand new alternator
  225. QUESTION
  226. MOVED: NEED SOME HELP!!!!
  227. MOVED: 2003 Neon - Lukewarm Air (Freezing!)
  228. MOVED: Need Help! Neon speedo/tach failure
  229. MOVED: What is the torque specification on a transmission pan?
  230. MOVED: Water in the trunk and on floor.. sxt 2004
  231. 97 neon what happened?
  232. Needing help on finding a part?
  233. CAN SOME TELL ME WHAT I NEED TO FIX THESE PROBLEMS!!!!
  234. P 0441
  235. gears,fuel, and 2.4 swap
  236. Wow, I screwed up.
  237. 96 neon turbo question
  238. HELP here! Car Owners!
  239. Advice for next mods....
  240. Any Neon Clubs in the Mid/East TN. area?
  241. wild graphist wanted $$$
  242. Other dodge neon forums
  243. How many of you changed your timing belt due to manufactures recommendations?
  244. 03 SRT-4 for sale
  245. FS: Mopar Short Throw Shifter Neon/SRT-4
  246. Headlights no more?
  247. Exhaust/Muffler Question I NEED IT ANSWERED FAST
  248. manifold
  249. 98 Dodge Neon i need some help
  250. 97 plymouth neon spits gas back at me
