PDA
View Full Version : Dodge Neon
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15
  1. Hey guys new to srt-4's
  2. Help with a 2000 Dodge Neon
  3. Installing a Performance Chip
  4. problem with my 2001 Dodge Neon
  5. 1995 neon problem - oil
  6. Sound of pecking in engine and lack of power
  7. 98 5spd issues
  8. 2011 Official Dodge Calendar competition!
  9. P0340 Trouble Code Help
  10. Rear Main Seal Leak
  11. Full srt-4 part out
  12. Rebuilt neon motor for sale!
  13. Who wants a new motor for the dodge neons?
  14. srt 4 exhaust?????
  15. Wanted: Engines with dohc/ junk neons
  16. 98 Neon 2 Door. DOOR PANELS
  17. Cracking Noise From Sitting on Decline
  18. Neon Torque convertor & trany
  19. codeNeon with PO340
  20. Looking for engine
  21. looking for motor
  22. Transmission
  23. Need some help
  24. Where can I buy Valvoline ATF+4?
  25. need some help?
  26. Will rear struts off an '03 work on a '97?
  27. Sputtering problems
  28. 41TE help - 5 codes pulled
  29. Need help please
  30. early motor in an 03 neon
  31. 95 Neon Engine wiring harness?
  32. HELP!!! more neon trouble
  33. #4 injector not firing on my 98 neon
  34. 2000 speedometer issue
  35. 2004 neon speaker problem
  36. Speedometer Problem 2003 Neon SRT
  37. 03 r/t 2.0 "f" code vs standard "c" code
  38. 97 neon sohc
  39. 04 neon codes
  40. Trans shifter solenoid? Limp mode? NO CEL? Advice for a neon noobie?
  41. 1999 dodge neon over heated! PLEASE HELP!
  42. Body Control Module
  43. 03 sxt body panels?????
  44. 1997 Neon New owner needs help.
  45. ac compressor replacement?
  46. Ambient Temp Sensor OR Intake air temp sensor?
  47. 2001 Dodge Neon
  48. Neon performance upgrades?
  49. 2000 neon sxt auto shaking when I am stoped
  50. 'o3 neon making me SHATTERED PLZ HELP
  51. RPM Fluctuations 2002 Neon R/T
  52. 2001 Magnum question..
  53. Neon 2.0 question
  54. how can i break in an aftermarket muffler?
  55. hesitation.
  56. need a new computer...I guess
  57. loud squealing when started.
  58. problems with stalling when hot outside
  59. There's A USB Type Device Covering My OBD2 Connector
  60. 04 neon intermitant smoke from engine compartment
  61. 2.0s.o.h.c head swap to a 2.4d.o.h.c
  62. Interesting shift problems with Auto tranny...sensor maybe?
  63. interior light not working
  64. problems starting my 2001 neon
  65. mopar lip kit?
  66. 2004 Neon SXT sound issues
  67. Interior dome light stays on when door shut?
  68. Can I put 20 inch rims on a neon 2003?
  69. Blown Intake Manifold Gasket
  70. Mysterious Electrical Deamons prevent Windows from rolling down and AC from blowing..
  71. 00/01 dodge neon no start...HELP
  72. no one can figure this out wtf....
  73. wiring my amp to the battery..
  74. Even a eletric shop is clueless "PLEASE HELP"
  75. help w/ 2003 neon fog lamps
  76. Electrical ghost!
  77. 2001 makes "pop" sound when clutch is pressed, any help??
  78. Dodge Neon Cop Car (I've been waiting for this for so long)
  79. Help, SRT-4 SWAP or TURBO on my SXT.
  80. Slight side to side wheel wiggle
  81. Transmissions to fit a 2003 Neon SE
  82. neon clutch replacement
  83. Manual Trans Grinds with clutch out
  84. 1st gen Transmission issue
  85. 1st gen Transmission issue
  86. no reverse lights
  87. Neon will not move while in gear
  88. need advice. just got done building my 97 2.0 SOHC
  89. I Really need help with my neon
  90. 2002 Neon Timing Belt change procedure
  91. Left rear turn signal / brake llight not working
  92. Looking to buy a NEW srt-4 motor+Tranny
  93. Acceleration Hesitation?
  94. SXT to SRT4 motor swap
  95. What size Torx?
  96. New headlights, LAws, and HIDs?
  97. PCM problem?
  98. How easy is it to change shocks and struts?
  99. Attack of the rattle can?!
  100. Power steering AND radiator sealent fluids?
  101. Trans Question HELP
  102. '03 Neon, hesitates when taking off
  103. Winter Tires: Does brand make a difference?
  104. radio programmed?
  105. replacement dodge badge/emblem
  106. Camshaft position sensor problems
  107. 2003 Neon overheating.
  108. Intakes
  109. 1998 problems
  110. 2004 Neon SXT 2.0 Trans issue
  111. New Lifters
  112. Faulty Alternator or Something else?
  113. 03' SXT Neon horrible gas mileage running rough?
  114. Automatic transmission swap
  115. 98 dodge neon wont start!
  116. need help
  117. 2000 neon will not crank
  118. engine thumping
  119. engine swap
  120. Motor Information...need help!
  121. 41te
  122. Fuel prime Problems
  123. Adding Turbo
  124. Need-online source for OEM parts
  125. automatic shift knobs
  126. '05 sxt motor interchanges??
  127. p0300 and p0301 on 2004 dodge neon sxt
  128. Car wont start error code P0340
  129. How much is me Neon worth?
  130. Bought New magnaflow exhaust
  131. Trans Cooler anyone?
  132. Windshield wipers WON't turn off on 2000 Neon!
  133. Neon Sputters
  134. 2004 Neon SXT has a flashing oil light
  135. belt tensioner install
  136. Help car wont start! (alarm troubles)
  137. where is the power steering belt?
  138. 2001 Neon Radio and clock won't work
  139. sxt 2 srt4
  140. Fogs lights but no switch to turn them on.
  141. someone help with transmission swap questions please
  142. Help! 1998 neon revs to 2200 rpm when fan on
  143. Plugs???
  144. Neon Misfires codes ???
  145. 2004 Neon will not start
  146. Car dies while being driven
  147. 1995 dodge neon
  148. Battery Troubles in a 2005
  149. where is the tach line on my 02 neon?
  150. Need help asap!!!!!!!!
  151. I need advise which Neon to buy.
  152. about 2.4 engines
  153. 2004 neon rear shocks
  154. Funny prank phone call
  155. I need help trying to find the promblem to my back tail light
  156. new gauges;
  157. Help Please
  158. If you can help me.....
  159. dashboard on 2000 neon
  160. I need a quick answer to a simple question
  161. FUSE error in the P D N R 3 2 area
  162. wanted: a670 trans 3 speed.
  163. Emergency Brake Frozen
  164. How to get 10% or more off ebay
  165. my car alarm kept going off!
  166. reset button on 1998 dodge neon
  167. 1998 dodge neon reset button
  168. How high can I rev my 95 2.0 sohc
  169. 2005 Dodge neon sxt will not start. Lights and everything work good, but when the key
  170. Neon manual
  171. Bad Mileage on an 04 SXT Neon !!!15-17 mpgs!!!
  172. Looking for torque specs?
  173. dodge
  174. gauges for a 2003 neon
  175. Bad miss
  176. new user
  177. 2004 neon p0481 code
  178. no fire
  179. Neon studdering problem
  180. I just got my car back from the shop, tell me what you think.
  181. how do i hook up narrowband a/fr gauge
  182. Im trying to find out what is wrong with my neon can any one help out.
  183. 2000 Dodge Neon Pinging
  184. 1996 Plymouth Neon
  185. 99' to 00' or newer swap
  186. Need Help
  187. A/C low pressure switch
  188. pullin a motor
  189. Neon 1996 , A/C Problems.
  190. Neon Motors
  191. Automatic Transmission Downshifts
  192. Overheating issue?
  193. str-4 swap with a 2nd gen
  194. Catylitic Converter and P2097 Code, Need Help
  195. is it wise to replace the ecm
  196. 96 neon 2.0 sohc help... please!!!
  197. Engine Problems Need Assistance- Tried Everything I can think of
  198. neon interchange question
  199. bigger size rims for my dodge neon se
  200. Can you turbo charger a sxt neon
  201. Springs plz
  202. Need lowering springs for a dodge neon sxt 2005
  203. real cheap shoes
  204. Kicker Surround Sound
  205. A weird noise on the front of the car... might be close to the engine
  206. 97 neon flooding prob
  207. Factory Fitted Alarm / Immobilizer fault - How to Fix - Need HELP!
  208. transmission fluid in 97 dodge
  209. Please Help
  210. MSD Ignition
  211. CarPart4u Test Fitment: Cars Needed!
  212. Crap load of 04 Neon and 04 SRT4 parts!!
  213. RIP 2005 Neon SE
  214. lowerin neons
  215. My girlfriends oil light is coming on please help
  216. Shakes like crazy!
  217. My 98 NEON: What generation is this???
  218. looking for wheels
  219. 2003 dodge neon r/t performance parts
  220. srt4 swap in to a 96 dodge neon ?????? need help asap!!!
  221. lukewarm heat
  222. Neon safety
  223. my fuel pump fuse keeps blowing i need help
  224. are dodge magnums reliable?!
  225. My friends
  226. single or dual overhead cam??
  227. Any Murdered Neons Here?
  228. what stage car
  229. 1996 neon takes a couple sec after the key is pulled to shut off
  230. will these rims fit ??
  231. Hours labor 4 a timing belt 2004 neon SXT?
  232. New Neon Buyers
  233. Megasquirt v2.2 neon mod?
  234. Clutch issues with 1996 neon 2000 engine
  235. question about eibach pro kits please help!
  236. Considering Parting 99 r/t
  237. Input Headers for 05 neon sxt
  238. 5 trans codes
  239. HVAC mod- I'm stuck.
  240. Looking For SRT exhaust
  241. Guage Problems
  242. No A/C...2001 Neon R/T
  243. Info on Legality of cat removal/relocation, tranny swaps, and engine swaps
  244. manual transmission noise
  245. Neon Paint Codes & all their Glory
  246. my neon has "no bus"
  247. 05 SXT > SRT4 hood
  248. RATTLING!!!
  249. I Have a noise when i accelarate
  250. Belt on AC Unit??? Guy Stealing from me??
