View Full Version : Dodge Neon
Pages :
1
2
3
4]
5
6
7
8
9
10
11
12
13
14
15
- Neon tranny?
- Help please, What year neon?
- Lifting my car back to stock
- 1998 Dodge Neon Electical Problem HELP
- Trans question
- No Fuel to fuel rail
- 1st gen/ 2nd gen.
- Chris Greenhouse does it again, four-time Group 2 Champion!
- 04 Neon Excessive Fuel, P0203
- 2003 neon sxt 2.0
- rearveiw mirror
- Hood latch
- Neon Problems
- wipers not working
- Cam Pos Code
- 2001 neon engine knock during cold start and p0420?
- HELP!!!!engine codesp0243 and p1105
- hey there!
- HELP:Changing a 02 neon transmission
- 1997 neon heat problems
- DF Ride of the month Contest?
- Lost my fire
- 03 neon sxt help
- Trans fluid in my cooling system
- 97 Plymouth breeze/neon questions PLZ HELP
- Customizing Neon
- Coil Busts Open On #2 Cyl.right as car died-WHY?
- Engine oil and Auto. Transmission leak?
- 1996 Neon, chattering and coolant
- Greets From UK - P0700 Issue
- Neon SRT-4 or SRT-4????
- Asking on neon's rpm?
- Bent valves?
- Question about body kits
- Question about body kits.
- 2003 Dodge Neon Battery Cover/heater
- 2003 Dodge Neon Thumping in Front End
- 2003 Dodge Neon Dashboard Rattles(makes noise)
- Code P0340 and car shuts off.
- Do you have to pull the radiator out to replace the fan on dodge neon 97?
- I am in need of a diagram!!
- 2000 Neon- Out of ideas
- Dodge Neon 2002 Engine Turns over, doesn't start -- any thoughts?
- bought 03 neon sxt 5 days ago, now engine light is on
- Car won't start? Battery or Starter?
- Left and right rear turn signals/brake/flashers won't work
- CEL off but i get codes!!
- Barn Find of the Year: 150 Never-Driven Neons For Sale
- Engine Light ON, need help, new here
- 2003 dodge neon se tcm?
- Neon accident-HELP w/starting
- 05 neon p0344 nightmare!!
- 2002 Neon- Bad Vibrations- Mechanic cannot fix!
- 2005 Dodge Neon SXT blinker and horn problems.....
- 05 Neon SXT leaking coolant from evaporator drain hose
- speedo not working
- 2005 SXT neon "ghosting" issue
- getting body kit?
- need help on making my 2.0sohc faster with stock parts.
- 01 neon engine has a slight tilt.
- Bosche Iridium Plugs
- Neon Engines
- 2004 Neon pulling to right
- 2005 Dodge SX auto trans won't go in drive and reverse
- Need Help '03 Neon SXT
- Mustang Killer Side Project
- Need Help 95' Neon
- 2005 Neon Oil Filter
- 2005 dodge neon axt shift problems.... PLEASE HEP
- What speakers are in my neon??
- "CLUNK" After Start
- 05 neon stuttering problem
- Neon motor Mounts
- Neon runs rough on idle
- No Fuel Pressure
- Double Din Radio 2004 Neon SXT
- Please...Need '04 Neon Help!
- My new LED Relay shorted something... turn signals and brake lights don't work.
- 05 Neon SXT Rear humming sounds
- 1996 neon 2001 neon engines
- Ignition lock and immobilizer in Dodge Neon
- different headlights
- 2004 Dodge Neon
- Replacing R and R cables on 2001 Neon 5spd
- A/C pump issue
- 2000 Dodge Neon Camshaft Position Sensor
- 2001 Dodge Neon transmission problems
- Dodge Neon Problem "(Red DOT)" Help Please
- 1999 Dodge Neon surges with air on...
- 96 Neon leaks anti-freeze?
- 05 Neon SXT 19mpg is all ???????
- 2001 plymouth neon problem please help!!!!
- bubbling/gurgling sound in coolant holding tank?
- An answer to my own question 2001 Neon se
- Squealing-Now no start!
- Broken Fog light cable. Please Help!
- neon wing and body kits
- All lights work, no turn signals dont't
- Transmisssion started acting up yesterday
- 2001 Neon problems mounting , Oil light has started coming on today
- Humming sound in 2003 Neon
- My 2001 neon is bogging down badly (almost cutting off at times) while a/c is running
- Owners Maunual
- 96 Neon Transmission, Help!
- 2000 Neon...ac only blows cold when brake is pressed
- 2001 Dodge Neon se
- WTB SXT rims
- Door panel removal/speaker replacement
- Steering Problem
- 2003 Dodge Neon Battery Light
- Dodge SX 2.0
- srt4 rims on a '02
- 98 dodge neon need help!!!
- 04 Neon
- Popping noise
- enging wont turn over
- Ol' School Neon... Fixed for the Road.. Now I need Answers..
- Low MPG
- 2000 neon oil light "ON" and engine shut off after driving about 30 km.
- New guy needing some expert advice please?
- 2003 dodge neon sxt transmission?? or motor??
- overheating issues
- 2005 Neon Sensor Question
- Loop whole with underglow
- Need some help
- serpentine belt and alternator belt
- I have an interesting one for you guys. 98 neon
- 2005 having high rpm issues.
- 2002 dodge neon sxt
- 2005 Dodge Neon
- Downshifted into 1st going 100km/hr :(
- 02 Neon code issues
- noise
- Pwr Steering & Brakes stopped for 1 min
- Transmission leak near Torque converter
- 2003 neon flasher problem
- Can't find corrent dash LED lights.
- Problems with my 1995 Dodge Neon Highline?
- 2005 Dodge Neon Speedometer Not Working
- Check Engine ON Check Engine OFF Check Engine ON
- 2005 Neon Running Rough at Idle
- Help!!!!
- 1998 dodge neon
- 2002 Dodge Neon help please
- 95 sohc mt to 98 dohc mt swap provlems????
- FS: Garrett, JMB, DSP
- Need Help need parts for 2008 Dodge Neon SXT
- train horn
- 2001 dodge neon es 5 spd really sluggish please help
- Sick SRT-4 fireball video
- 02 Dodge Neon Check Engine Codes
- good low compression pistons?
- 2003 Neon wont start and no codes errors
- need help with my 03 neon
- Alternator connector
- Mopar midget block
- 05 neon wont shift into gear in morning
- parting 96 neon il
- 98 dodge neon
- ? about computer id#
- Won't shift out of 1st until 4000 rpms
- Transmission Slip After Pressure Loss
- 2.4 swap 1st gen
- This big plastic thing fell off
- Looking for a CAI fo rmy 03 sxt
- 98 DOHC Neon Whistling and code #3 misfire
- 2005 dodge neon- shifting 1st/2nd/neutral-light knocking issues in trans
- Dodge Neon in Rally America
- keyless entry problem
- Malfunction Indicator Light
- High idle concern w/ 1998 2.0
- 04 neon fuse issue
- 2000 neon slipping out of first stopped. (loud)
- Issues with radio flashing
- 2004 neon r/t
- A few Questions
- 2002 Dodge Neon Transmission Problems!
- Replacing Alternator belt on 95 Neon
- 1995 Neon won't start . HELP
- 03 dodge sx (neon) R/T motor swap from 2000
- FS/FT: New Garrett Turbocharger
- p0172 engine code 98 r/t
- Sound Like Breaking Ice When Starting.
- Starting troubles
- is it possible and if so is it worth it
- neon club in sacramento????
- Do Second Gen Neon's Come in White?
- dodge neon front speaker help?
- FOR SALE: 1995-1999 Dodge Neon Wheel Hub
- FOR SALE: Hawk Performance Brake Pads for Dodge Neon
- FOR SALE: Brembo Brake Pads for Dodge Neon
- one quick question
- FOR SALE: 2001 Dodge Neon ACR
- Whining noise
- 2000 ES,automatic to 5 speed?
- 2001 dodge neon add another lighter port
- 2002 neon le power steering pump
- Beating My Head Against the Wall, Input Needed
- Help!!
- no start situation 97 neon
- Remote starter
- 2003 Dodge Neon 2.0 SXT washer pump not functioning
- Compressor engaging when on defrost???
- lowering kit help
- air leak
- parts for sale
- Sunroof weatherstrip needed
- Replacement Mirror question
- Automatic shift issue
- Fuel pump works but my car isnt sending power to it
- 95 Neon Headlights Switch
- Sneaky trunk leak???
- Dodge Neon 1996, heater is on but no heat
- What size Battery for 2000 Dodge Neon?
- Replace '95 Neon side view mirror
- tires
- Glowshift Gauges
- 98 Plymouth Neon
- Camshaft position sensor issue
- 2003 Neon SXT - Check engine light issues
- 98 neon cranks but will not start
- -25% fuel trim
- Squeeking noise under hood with blower on...help!!!
- 01 Neon mechanical issues
- 1998 Neon Leaking Water from hose on Firewall
- Remake of the Dodge Neon models like SXT
- Neon Won't Shift out of Park
- Neon Lambo door
- shift solenoid? 98 Neon
- Camshaft misaligned
- 04 Neon multiple cylinder misfire!!!!!!!!!!
- '95 Neon - Error Code 37 (torque converter)
- 95 Neon Basic
- Looking to get back into a Neon should I go SXT or SRT ?
- Windshield wipers acting up
- timing belt
- Kaiserslautern Auto Show 2010 Pictures
- Trip/Mileage
- neon not starting p0340 cam sensor?, help a amateur out please!
- heater core on 2002 neon
- Wind pops sunroof open... need help.
- looking to buy SRT-4 hood!
- turn signal and brake light problems on 2003 neon (please help)
- Electrical issues with the 95 dodge neon sport?
- 2005 SXT Wont shift gears, wont idle... ??
- 2005 Neon SXT- Stalling
- Im new here
- 1998 Dodge NEON Mechanical Problem
- intake manifold
- how do i remove the hormonic balancer
