PDA
View Full Version : Dodge Magnum
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. using excessive amount of oil
  2. No starting
  3. help EPS BAS Lite on, car looses power while driving and rattles after 55 mph
  4. 2005 SE Stereo amp wire
  5. BOTH Magnum Rear ABS Sensor codes
  6. Timing Chain
  7. Swapping Instrument Cluster
  8. Front Passenger Window Diagnosis
  9. '05 Magnum won't start. Battery, starter are good.
  10. extended warranty
  11. Serpentine belt tension arm wheel
  12. 07 Magnum 3.5L p0660 p2017 p2078 HELP
  13. Get a Hemi sound
  14. Dim Brake Lights - 2006 Magnum
  15. 2008 SXT Ignition
  16. Billet vs. mesh grille - your opinion is needed!
  17. 2005 dodge magnum
  18. I am stuck, well at least my drivers seat is
  19. 05 Magnum Cluser not working
  20. 2005 Magnum won't start.. code P2098 P
  21. Won't shift out of Park
  22. Showing Your Magnum? Stand Out With This
  23. 2008 SXT 3.5L HVAC Issue
  24. Dads New ride 06 R/T
  25. 06 RT 5.7 Hemi with Electrical Issues
  26. 2005 Dodge Magnum won't start
  27. Cruise Control Issue
  28. Help!! P0335 code
  29. Zero-60 In How Many Seconds
  30. Acceleration Rate for a 2.7 Base '06' Magnum
  31. New mufflers for hemi Magnum
  32. 2007 dodge magnum r/t 5.7 hemi
  33. 05 Magnum RT AWD Hemi Hesitation
  34. magnum "Vortex"
  35. Aftermarket double din won't turn off.
  36. 2008 Magnum power outlet has power but wont charge phone
  37. 2005 Dodge Magnum engine code reset?
  38. Known Issues with 05 Magnum
  39. What did you do to your magnum today?
  40. Dodge Magnum R/T AWD Alberta?
  41. 6.1 or 6.4 what do you think?
  42. Electric issues due to water in the trunk
  43. Electrical draw
  44. 12VDC, but no power to anything.
  45. Steering binding
  46. customer preferred packages
  47. HELP!!! Transmisson won't shift any higher than 2nd.
  48. 2005 magnum 5.7 hemi "misfire" and rough idle
  49. 2005 dodge magnum ac/heater blower wont work.
  50. Any way to disable ABS, BAS, ESP, Etc.?
  51. Electrical problem, B1644 code
  52. functioning viper hood
  53. heater blower motor
  54. Climate control
  55. Winter package
  56. 07 Magnum, 6 cyl, flashing dash lights
  57. AC Not Working and Airbag Light On
  58. 05 Magnum Special Eddition problem
  59. 05 Magnum R/T Stalling at Idle. Won't idle under 1200 RPM's
  60. how to remove my transmissions cap
  61. Engine Tapping
  62. Aux Input Jack
  63. Oil getting into spark plugs
  64. Heater and Warm air question
  65. Magnum tranny question
  66. Steel Wheels
  67. Choices...2007 or 2008
  68. p1790 What does it mean????
  69. Gas fumes
  70. Thermstat replacement in 05 Maggie SXT 3.5L
  71. Grinding noise
  72. 2006 Magnum - Engine Light goes on
  73. Heating Issues.
  74. Vibration when engaged in gear
  75. DTC codes 0520, 0524, and 1521 wtf!
  76. Multiple MIL codes: P0335, P0330, P1411, etc.
  77. howling noise after changing air filter
  78. Weep Hole
  79. Missing Fues in Front power dist cener
  80. 06 Magnum Clicking Noise with A/C On
  81. wiper arm removal
  82. Magnum SE Transmission Question
  83. Squealing Noise
  84. Crank sensor
  85. HUD for 2005 Dodge Magnum RT
  86. Magnum trans?
  87. Overheating
  88. Dodge Magnum Hemi R/T Problem Help Please
  89. Help needed
  90. Shift Interlock Latch (Pink Thingy) 07 Magnum SXT
  91. 2007 Dodge Magnum Hazard Panel Fail.
  92. tuner or exhaust? what should be done first?
  93. AC quit
  94. 07 Magnum SXT 3.5L Knocking
  95. 2005 Dodge Magnum crusing problem
  96. Get it up!
  97. Oxygen / Lambda Sensors: Which one?
  98. Noticeable vibrations that come & go
  99. VTA Flashing 05 Magnum
  100. V6 to V8 swap
  101. cant figure it out
  102. 2006 dodge magnum
  103. brakes
  104. 2005 magnum overheating
  105. 2008 magnum srt8 24k miles
  106. 2005 magnum overheating
  107. p2320
  108. 2005 Magnum R/T cooling fan not working
  109. Dodge Magnum shaking
  110. Driver side under carpet
  111. ac compressor not coming on at all blows hot
  112. Adios amigos! auf wederstein! au reviour! cai chien! Buh-Bye!
  113. Dashboard Issues
  114. rebuild project
  115. 2006 Dodge Magnum MUST READ!
  116. 2007 magnum rear hatch
  117. The Crank Pulley Will Not Turn
  118. Replacing the Rear Hatch Top Weather Stripping on an '06 Magnum
  119. Not shifting
  120. 2006 Magnum 2.7l Engine Light On
  121. 2005 Dodge Magnum axel sensor
  122. 2005 Dodge Magnum valve spring removal
  123. 2005 Magnum overheating
  124. Front Left axle joint boot is ripped and leaking!
  125. Possible Cluster F*#k
  126. 05 3.5L Magnum
  127. 07 magnum just stopped running
  128. Please help
  129. Need front bumper / fascia measurements
  130. timing belt
  131. Help with Transmission Input Speed Sensor
  132. 2005 dodge magnum help!!!
  133. American Car Craft scheduled to shoot segment on Motorhead Garage!
  134. P0128 and P0441
  135. 05 magnum 2.7 liter question
  136. 05 SXT ETC & BAS Light
  137. 2005 magnum...Help fixing drivers side door handle latch
  138. Rims for Magnum
  139. Buying a 2006 SXT Magnum with 76000 miles Should I get an extended warrenty?
  140. warm engine tapping noise?
  141. headlight switch
  142. 2006 magnum
  143. HELP ! Thermostat Change and ETC Light
  144. SE Content
  145. 2006 dodge magnum sxt
  146. American Car Craft receives MOPAR Licensing Approval
  147. Oil Change Interval
  148. battery life
  149. Greetings from a newbie
  150. Problems with my 2006 Magnum SXT
  151. West Coast Muscle Car & Truck Show - Pictures
  152. Looking for someone in Port St Lucie Fl. to install camshaft
  153. Magnum enthusiast...........
  154. Magnum Police Car
  155. Dodge Magnum 5.7 Hemi AWD 2007
  156. rain leak
  157. NEW for 2013 - Save 20% at www.AmericanCarCraft.com
  158. ACC Open House & All Car Show - March 9, 2013
  159. Steering problem
  160. iPod via Bluetooth
  161. CAT, or not to CAT?
  162. headlight adjustment
  163. 2007 Dodge Magnum RT 5.7 Hemi AWD
  164. Reverse/drive/park issue...
  165. 2007 Magnum R/T Poor MPG
  166. Help with Odometer on 2006 Magnum RT
  167. EGR or PCM?
  168. magnum has no power after 60 km
  169. Black Friday comes to ACC early with 20% savings!
  170. 2005 Magnum RT Electrical Problem
  171. Temp Gauge going crazy
  172. Will this Battery work?
  173. help please po740 code
  174. Dodge Magnum Vin! Need Help!
  175. HELP!! I can't get my 06 MagnumSXT Going!!
  176. engine work
  177. 06 magnum issues
  178. Exhaust
  179. headlights needed
  180. Check engine light came on again...
  181. 05 magnum 2.7 liter question
  182. No heat on 05 magnum
  183. Idle rpm for v6 3.4L 2007 magnum
  184. Trans went out 92k
  185. 2005 Magnum High Idle on Startup
  186. 2005 navigation system
  187. Changing plugs in 2.7 Magnum
  188. passenger airbag light & check engine light lit after battery replacement.
  189. Halo headlights
  190. water outlet housing on 2.7L
  191. SunRoof Replacement Parts?
  192. Shifting problems
  193. intermitent lagging of power
  194. 2006 rt awd
  195. Lights Pulsing
  196. brake pedal switch relay
  197. Random Engine Hesitation (2005 R/T)
  198. Magnum 2.7l to 3.5l swap
  199. AC problems
  200. 2005 magnum heater core shutoff valve
  201. Rear Shocks
  202. Magnum 5.7L Engine Shroud Dress-Up Kit by American Car Craft
  203. Drivers side window control panel (?)
  204. occasionally wont shift out of park
  205. Magnum RT Sports CATs..?
  206. need help with a broken pulley
  207. Leds
  208. Has any tried this product
  209. picking a rear end
  210. AWD rim
  211. TB/WP 08' Magnum SXT 3.5L
  212. performance chips
  213. Need some BIG help.
  214. Tune-up Help- 2006 Dodge Magnum SXT
  215. Newbie here! 08 SE
  216. New Supporting Vendor - American Car Craft in Hudson, FL.
  217. Transmission problem
  218. Exhaust
  219. whats your take
  220. Thought getting the egr off was difficult.
  221. P0132 P0300 and P0406
  222. Rear Differential Fluid
  223. Broken Drivers Window
  224. engine help please!!!
  225. Caliper, 2006 Magnum RT dual piston
  226. Rear speaker grill resonance trouble....
  227. Engine Swap Help (Info Needed!)
  228. 05 r/t vin # locations
  229. 05 RT - stiff suspension normal
  230. Pull trigger on deal?
  231. lock and unlock fuse ?
  232. 2007 Magnum stuck in Park
  233. I own an all wheel drive 05
  234. Engine noise
  235. synthetic oil & platimun plugs
  236. Interior light problem
  237. 2007 SXT Temperature control light out
  238. Esp/bas ??
  239. Not shifting into high gear, & battery goes dead (randomly)
  240. Help Please! Trans Problem! Codes P0700 P0891
  241. 05 Magnum SXT 3.5L RWD Rear end noisy
  242. Need some exterior upgrades
  243. should I get a magnum
  244. 05 Magnum Issues
  245. 05 magnum newbie questions
  246. Header nightmare please help
  247. Timing Belt 2006 Magnum
  248. chance to get an '06 SRT-8
  249. Brakemotive is having a sale YOU should know about!
  250. autostick gets stuck
