PDA
View Full Version : Dodge Magnum
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. chrysler CDA software
  2. 2005 dodge magnum rt (69,000 miles)
  3. 05 Magnum SXT
  4. decent brake upgrade
  5. 2006 Magnum headlight problems
  6. Chrysler navigation questions
  7. 15th. Annual Chrysler Performance Trade Show & Swap Meet
  8. Magnum to Chrysler 300 seats swap???
  9. Superchips Flashpaq instructions??
  10. Should I get an extended warranty
  11. burnt bulbs behind controls
  12. Drivetrain vibration - turning when cold
  13. New '05 SXT owner....
  14. 2007 Magnum DRL Module
  15. OBD II Readers
  16. Need help
  17. Parking Brake Issue
  18. 3.5L Thermostat and PCV valve
  19. Can I take off governor or speed limiter on 06 magnum SE?
  20. Make my magnum rt sound better
  21. Wierd Rev
  22. 2007 Magnum Rear Wiper Arm
  23. Mygig Ren Need Help
  24. engine won't stay running
  25. 2008 Magnum SE Check Engine Light
  26. Malfunctioning back lights
  27. Spark plug change
  28. 2005-2008 Dodge Magnum Station Wagon Retrospective article
  29. Magnum Strut Replacement
  30. New tire change (from 18" to 22")
  31. Switch to full synthetic in 5.7 Hemi
  32. 2008 Dodge Magnum 3.5 oil consumption
  33. WiTech
  34. 05 Magnum hemi speed sensor
  35. Thermaquad Float Setting
  36. Turn Signals
  37. Ok, what's the deal?
  38. Starscan/Mobile... WPBeach Fl...
  39. Front speaker problem, '05 magnum se
  40. Plugs for a Hemi
  41. Rear and fron main seal leak
  42. dumb question regarding odometer
  43. dual exhaust
  44. newbie need help
  45. short runner valve
  46. Replacing brake rotors
  47. Tires, I need some advice
  48. air intake
  49. Speedometer failure
  50. Can't Shift Out of Park
  51. exhaust?
  52. Black 2007 Magnum Anyone?
  53. 2006 Magnum low oil pressure
  54. Radio Harness to uConnect
  55. Stalling
  56. custom speaker box
  57. uconnect not working
  58. Time to replace spark plugs in hemi
  59. We are NOW a FOUR MAGNUM family!!!
  60. interested in 2005 magnum sxt..need opinions + winter driving
  61. Motor oil
  62. 2005 Mangum Speaker Problem
  63. 2005 Mangum Speakers
  64. Code P0406 egr position sensor high
  65. 2,7 not running right
  66. Stupid question
  67. CAI installed the other day...............
  68. Knocking sound
  69. fuel gauge ???
  70. Cooling fan comes on but will not shut off!
  71. strangs noise
  72. whirling noise from tranny?05 rt magnum
  73. 2005 magnum Rt rear windows issue
  74. Tail-lights: bulb replacement
  75. NEED HELP..2.7 or 3.5
  76. How often Magnum needs oil change?
  77. Wierd problem in reverse
  78. Where to buy Lug nuts - Calgary
  79. transmission
  80. A Dodge Magnum by any other name...
  81. 2005 Magnum, lots of clunking noises from front end
  82. Headlight (not bulb) Removal
  83. Sat nav question
  84. Falken tires
  85. Wiper issue
  86. Squeaking Brakes
  87. transmission filter fluid change
  88. Drove with parking break on
  89. code 0520
  90. buying a magnum
  91. start-up
  92. Gas grade (87, 89 or 91) for Magnum
  93. installing electric seats in magnum -05 from chrysler 300c 2008. HEEEEELP!!!!
  94. New chin spoiler concept
  95. Sluggish acceleration
  96. Question on Factory Installed Remote Starter
  97. best repair manual
  98. MOOG tie rod ends
  99. steering column noise
  100. Time Problem
  101. Plugs, coils & shifter handle
  102. 2005 Magnum RT
  103. continental tire settlement
  104. Dodge Magnum = Ram Tough
  105. 2005 E-Brake issues
  106. Just bought an 08
  107. No FM reception
  108. uconnect does not talk any more
  109. Cruise control not working
  110. Differential seal leak
  111. Thinking of getting a Magnum....
  112. NEED Opinions
  113. OBD scanner won't read
  114. Metric in my cluster ?
  115. AWD vers 2WD Hemi..
  116. 05 magnum tail lights
  117. EGR evap sensor low voltage ?????????????
  118. Spark Plugs
  119. Heated Seats
  120. Car and truck of the year voting NOW
  121. headlight adjustment
  122. I have Aliens in my car
  123. Antenna location on 2005 Magnum
  124. Seat belt sign always on even when a have seatbelt on me
  125. Car not running good at all
  126. Odometer milage is it in the Engin computer
  127. Seat belt sign on always??
  128. FM radio died
  129. Error code p1400
  130. plug change
  131. Dodge Magnum radiator drain
  132. NAV Radio REC vs. REJ?
  133. Add on UConnect
  134. Key Fob Programming
  135. Wife's SXT starts; then just turns over??? Help!!!
  136. Part Numbers
  137. Custom CAI
  138. Turn Signal Prob Help Please!
  139. Burning premium gas in a Hemi
  140. are dodge magnums reliable?!
  141. Is 2006 2.7L Reliable!
  142. gear problem?
  143. Steering Issue
  144. Unexpected Chirp
  145. Rear Disc Brakes
  146. Lug Nuts
  147. whats a reasonable price?
  148. Check Engine Light
  149. The MagWag
  150. Aftermarket Uconnect wiring question
  151. Installing uconnect in 05 magnum
  152. ProCharger is giving away $5,000 CASH
  153. Used Oil not rated MS-6395...Now what?
  154. Hands free phone system
  155. Hot A/C at startup
  156. ESP BAS fault
  157. Brake Pad Rattle
  158. Change Plugs on SXT
  159. Input for Performance Modifications
  160. How to remove side door panel on 2005 RT?
  161. best tires
  162. Considering a Dodge Magnum... Thoughts?
  163. Just purchased a 2007 dodge magnum sxt...
  164. Need Drive Side Side Skirt (2005 Magnum)
  165. Sad Loss - 2005 Dodge Magnum RT
  166. Stereo Install
  167. 20" srt awd wheels on a magnum rwd sxt?
  168. 07 SXT Adding DBL DIN Question
  169. DF Video!
  170. Clunking Noise when turning....
  171. Replacement
  172. Airbag light
  173. Tie rods
  174. Well, I learned something NEW today!
  175. new member-lug nut torque?
  176. 22" rims w/tires for sale
  177. Noise from under car
  178. Is Paul Mitchell hiding in my R/T?
  179. 2005 R/T Magnum compression loss
  180. After Market Suspension 05 RT AWD
  181. Looking at buying a Magnum
  182. Dummy O2 Sensors
  183. magnum for sale
  184. OK Got the R/T - Which Hitch for a 2500lb boat?
  185. 05 Dodge Magnum SE
  186. Cargo Net Anyone
  187. New Here - Tow Package install after purchase??
  188. New to Magnum! MPG Question!
  189. couple questions with regards to aftermarket products
  190. Question about the Magnum's snow driving
  191. Can you tune a magnum?
  192. did i do alright?
  193. roof box
  194. Aircon panel - not working
  195. 2005 DODGE MAGNUM SERVICE MANUAL
  196. navigation got usa - want europe
  197. Upgrading Navigation diss
  198. factory headunit swap
  199. HELP, radio static on hot days
  200. passanger side airbag light
  201. RT 4th gear weirdness
  202. CRANK NO START 1ST TIME START2ND TIME
  203. Panoramic Sunroof System
  204. Factory Warranty for 2005 magnums
  205. Dented 07 Magnum is this for real?
  206. 2006 Magnum SRT8 For Sale
  207. A/C Problems 5.7L
  208. Magnum tire size question
  209. 05 Magnum SXT
  210. Saw this Magnum in San Diego.
  211. Capital Forged Photoshoot: Magnum
  212. 2005 Magnum AWD
  213. 05 Magnum AWD problem
  214. lowered looking for alignment info
  215. Magnum R/T AWD ride height
  216. Brake Failure
  217. intake bolt torque?
  218. egr valve/sensor replacement?
  219. 2005 Magnum AWD v8 questions
  220. Repair Manual?
  221. Map Sensor
  222. Hmmm
  223. Trying to replace the console cupholder
  224. 05 magnum dash lights
  225. '05 RT rear windows issue...
  226. Check out a review of the Nitto Invo [video]
  227. anyone know of a freebie or online service manual for the magnums?
  228. MDS and the A/C system
  229. 2007 Dodge Magnum SXT Headlight Question
  230. Removing Resonators
  231. Cheap plasitc trim fading/turning white
  232. New 2 a Magnum
  233. Body Mods
  234. Tailgate Light Bar
  235. magnum/durango radio
  236. noise in front end
  237. Vortech V3 Supercharger System - Installed!
  238. Brakes
  239. OEM (Alpine) NAV question
  240. Please Help with my 2005 Magnum SE
  241. gas grades
  242. Magnum SRT8 Exhaust Mod in Popular Mechanics
  243. SRT8 Rims and tires for RT
  244. Best Tire and Wheel Size calculator site.
  245. Shifting
  246. tire problem
  247. Lock horn
  248. Lug Nuts
  249. Noobie question
  250. Stock Rim Exchange Website
