PDA
View Full Version : Dodge Magnum
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. Changing Steering Wheel
  2. Unusual Dodge Magnum build
  3. Dodge Magnum Fuel Pump Replacement
  4. Front passenger seat heat not working
  5. clearing fault codes
  6. Magnum side windows down measurement?
  7. Replace overflow tank?
  8. When will we get a Hellcat Magnum!!!??
  9. 05 et p0344 code
  10. Heater
  11. 2006 Magnum Thermostat Housing
  12. 2005 Magnum Auto Transmission locks in Park until I mess with the Pink plastic thing.
  13. Bluetooth stop working
  14. 2005 Magnum Transmission Shutter
  15. 2005 dodge magnum wheel spacers
  16. 2005 Dodge Magnum 2.7
  17. Ignition problems
  18. magnum seats
  19. Help. Overheating
  20. Heater will not turn off
  21. decode engine serial number
  22. 2005 Dodge Magnum Transmission Problems
  23. 3.5 2008 crankshaft main bearing torque specs
  24. 05 r/t codes p0032,p0038,p0052,p0058 dying and throttle issues after warm up
  25. 07 r/t slapstick issues
  26. should i buy a 2006 magnum rt with 15000 miles?
  27. Is the 2.7L on a magnum that bad?
  28. 06 Dodge Magnum door lock problems
  29. 2005 Dodge Magnum Transmission Milkshake
  30. Door Switch ? Other electrical issues ?
  31. pulsating feeling when in idle
  32. Check engine light with new cold air intake
  33. severe wheel / tire wobble
  34. 2006 Dodge Magnum SXT
  35. Wheel vibrate after lots of work to fix
  36. Help
  37. 2005 Dodge Magnum AutoStick Transmission Swap
  38. Best place to sell single owner Magnum SRT?
  39. no liftgate or dome light function
  40. Urgent Takata Airbag Recall
  41. Airbag Passenger Seat Occupancy Sensor Module
  42. Front Bumper Damage
  43. New Owner Of 2005 Dodge Magnum RT AWD With All it's Problems.....
  44. 2005 dodge magnum hat information is shown on the odometer display aside from milage
  45. 5.7 Hemi Valve Seat Drop
  46. Does my rwd magnum need cv axels in the front?
  47. 08 Magnum Locks and honks randomly
  48. Looking for a 2008 Dodge Magnum SRT8
  49. Will tires rub on my magnum
  50. New Magnum
  51. Will a 2009 and new 5.7 Hemi with vvt work in a earlier car or track?
  52. 60% OFF Tires & Wheels / Rims
  53. Dodge Magnum 05 A/C not working on full speed. Mechanics help.
  54. Transmission Noises
  55. Parts websites
  56. speedometer doesn't work
  57. So where is the factory amp!!
  58. NAG1 Noise
  59. Transmission Clunking? 05 Magnum RT AWD
  60. New 5.7L Jasper engine, New MOPAR NAG1 trans....trans not down shifting
  61. coil 2 misfire
  62. Sunroof opens on it's own
  63. my AM/FM
  64. coil 2 misfire problems
  65. starting issues magnum 2005
  66. Temperature gauge not working
  67. keyless remote control problem
  68. thermostat temp
  69. Car pulls to the left
  70. Magnum charging problem
  71. Ignition key won't turn
  72. 02 dodge magnum awd 3.5l p0430 code
  73. AWD Magnum grinding sound when turning right and accellerating
  74. 2008 Magnum won’t come out of park, but
  75. Magnum water leak affecting transmission
  76. 2005 Dodge Magnum / front driver’s side brakes
  77. Should I buy a 05 Dodge Magnum SXT 162xxx miles FOR 3000?
  78. Key fob microchip
  79. 05 5.7L need NAG1 trans rebuilt, Marietta,Ga
  80. 05 magnum wagon guy
  81. 2005 Magnum 5.7 shift issue
  82. Sway bar bushing size
  83. Towing
  84. GPS Joystick Fix?
  85. Interior lighting
  86. No heat 3.5 magnum
  87. Updating GPS in 2005 Magnum
  88. 2005 dodge magnum rt trans neutrals out
  89. EGR Issues-2005 Magnum hemi
  90. NA Dodge Magnum Runs a 9.29 Quarter Mile
  91. 06 Magnum 3.5 crossmember
  92. 08 2.7L V6 Magnum reverse light fuse location?
  93. Magnum Turbine/Input Shaft Issues
  94. Valve seat drop
  95. Gear selector moves fine but the transmission will not engage.
  96. 05 Magnum SXT starting problem
  97. 2005 Magnum R/T check engine light
  98. Lost communication with gear shift control module
  99. Overheating
  100. Dodge Magnum PCM, ECM, ECU, TCM - Plug and Play - Well Below Dealer Pricing
  101. Misfire
  102. 5.7 RT - weird miss
  103. Locked Steering Wheel
  104. 5.7 dodge magnum awd surge?
  105. W5a580 interchangeable?? 05 Dodge Magnum Rt AWD
  106. Removing A/C compressor
  107. Transmission won't shift out of 2nd!
  108. Dodge Magnum PCM, ECM, ECU, TCM - Plug and Play - Well Below Dealer Pricing
  109. '06 5.7 engine cuts out
  110. Dodge Magnum PCM, ECM, ECU, TCM - Plug and Play - Well Below Dealer Pricing
  111. Magnum R/T Brake Upgrade: SRT..? What needs to be changed if so?
  112. Magnum R/T Rear Diff: Parts or Replacement suggestions?
  113. Engine Heeeelp
  114. Need help...
  115. My car locks me out!
  116. 2006 Magnum car starts when cold but wont start after been running awhile
  117. Dash tweeters and center sub inop
  118. No power on aftermarket radio install
  119. wheel bearings
  120. 5.7 Hemi electrical issue
  121. driveline vibration
  122. outside temp
  123. vents seeping heat
  124. 2007 Dodge Magnum Sxt 3.5 liter v6 with a hemi. Passenger side window doesnt go up
  125. 2007 Magnum Windshield Wipes
  126. Gauge Cluster Light Out and Strange Noise
  127. Front end clunking
  128. P0604 OBD-II Trouble Code: Internal Control RAM Error
  129. Emergency Brake Issues
  130. 07 magnum 5.7l electrical issue
  131. My Temperature gauge is not working
  132. Change Front Control Module?
  133. Only on fill up
  134. front calipers not fully retracting when in operation, easily retracted with c clamp
  135. A/C Fan speed switch melted
  136. 05 hemi misfire cyl 2
  137. Pcm
  138. Instrument Cluster Lights Flash On And Off While Driving
  139. No start , Red light blinking under fuel gauge ....
  140. -4-04 Code Help
  141. 2008 dodge magnum
  142. 2.7 oil light on at idle
  143. ETC light comes on and then stalls
  144. new to the site
  145. Dodge Magnum 2.7 Spark Plug removal
  146. Alternator hell
  147. Car won't start cause system lock.
  148. engine vibration
  149. Does it make sense to buy a Magnum with a blown engine?
  150. Magnum Radio/Navigation and Dash Light Problem
  151. Complete Suspension Refresh?
  152. Fuses
  153. Hellcat
  154. How can I test the fuel pump?
  155. Exterior lighting: Error codes: Which cause them..? Fog lights: 45w to 55w ok..?
  156. Magnum Racer: Alex “The Car Girl” Rogeo
  157. 2.7 stalling at idle, no codes
  158. Trans rumble when starting to lug
  159. Rear suspensiion knuckle bush: who sells these?
  160. Any safe mildew treatment for interiors?
  161. R/T Throttle body upgrade: which one, how and are they worth it?
  162. Orange sealant indicative of anything?
  163. 06 Magnum no gauge lighting
  164. 1978 Magnum XE starting engine problem
  165. 2006 magnum 3.5 abs breaking problem mystery
  166. Please help me identify this part for my tail light
  167. Rotors warping from "moisture?"
  168. Dodge magnum vibration
  169. Burning Rubber Smell
  170. My timing
  171. 2005 Magnum R/T Shakes at 45mph when Braking
  172. Rear fuse and relay box
  173. Adding resonators
  174. 5.7 Hemi thrown rod, timing tensioner?
  175. Electrical - weird turn signal issue
  176. Nivomat compatibility
  177. Suspension upgrades for towing: Nivomats, airbags or both..?
  178. Rear suspension sub-frame bushing replacement: Any advice, please..?
  179. 2008 Dodge Magnum 2.7 No Crank/No Start
  180. help with parts
  181. Dodge Magnum Sxt 2005 Transfer case
  182. ESP and BAS light on after dealership
  183. '05 Magnum Tranny issue
  184. Magnum charging issues
  185. magnum tailgate
  186. looking to install LED head lights
  187. No start u0100 runs for 1 minute than cut die
  188. Instrument panel stops and starts again
  189. RT overheating
  190. Shift points?
  191. Rare color for a Magnum?
  192. torque converter/tranny
  193. 05 magnum o2 inspection prob
  194. Best Programmer for '05 Magnum RT
  195. 06 Mag SXT rear hub specs
  196. Help please
  197. ABS Issue, Please Help!
  198. Need help replacing front axle 2005 Magnum
  199. fog light assy
  200. Wiring up additional gauges: Where to tap into?
  201. Engine Stumbles Cuts Out while driving
  202. Strange Vibrations: Help!
  203. SRT-specific Nivomat: Part Number..?
  204. Magnum Shaker Upgrade: Any ideas?
  205. HHP/BES Stage 1 260 Custom Cam: Worth the effort to install..?
  206. brakes on magnum worn down to 4 mm
  207. WIN Module repair
  208. 2008 Magnum Starting Issue
  209. Haven't driven in almost a year
  210. 05 Magnum power steering leak
  211. controle module, help
  212. Head lights
  213. EGR Valve
  214. Dash Reads that key is in, when it isn't??
  215. Dodge Magnum screw cover
  216. Interrupted crank then PCM resets
  217. bluetooth not working (uconnect) told bad radio?
  218. penny in cigeratte lighter now car wont start!!
  219. bas/lightning bolt light and goes into dummy mode
  220. 06 magnum se v6 2.7 want to do a v8 swap
  221. Hi guys new here I have a 06 dodge magnum won't start
  222. Nivomat installation to R/T: Easy or a pain..?
  223. ESP / Traction Control: How to Test?
  224. 07 magnum R/t
  225. 2008 Magnum SRT8 Steel Blue car 29 of 29
  226. replace door panels
  227. Magnum SRT-8 2008
  228. 05 Magnum3.5L
  229. Alternator Problem SXT 3.5L
  230. 2005 Hemi Magnum, 62k, Emergency Brake Shoes
  231. I'm looking
  232. Chrysler 300: Radiator Magnum compatibility
  233. Severe Duty Radiator: Any help..?
  234. Help Me Please
  235. Stock Magnum rear coil springs: air bag compatibility?
  236. 3.5L SXT with P0016 Code
  237. Projector Headlights & HID kit: Any recommendations..?
  238. 2008 SXT 3.5L Repair Questions
  239. 2008 SXT 3.5L Radio Question
  240. "Heavy duty" radiator: no trans cooler..?
  241. Cooling Upgrade for Towing
  242. 2008 Magnum - shifter moves back and forth
  243. sway bar links
  244. Upgraded my stock non nav cd changer to REC nav unit 06 Magnum R/T
  245. Dodge Magnum / Charger Stepper Motor
  246. New member first time Dodge owner with an 06 Magnum R/T
  247. 2005 DODGE MAGNUM R/T OBD II Communication
  248. Magnum won't downshift
  249. Takata airbags in 2006 Magnum?
  250. water pump 5.7 hemi 2005
