View Full Version : 2nd Gen Durango
Pages :
1
2
3
4]
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
- shift control solenoid A
- 02 dodge durango
- looking for answer why the obd2 port doesn't have power to diagnose.
- Backup light switch
- whats wrong with my tranny
- Alpine Sound System with aftermarket head unit
- Rear A/C expansion valve location???
- Dodge Durango 4.7 won't run
- 05 Trans issue
- Stuck In Accessory Mode. Ignition switch or Key Cylinder
- Hello Everyone. Code P2096
- 2005 rear brake junction union
- gas smell inside my car
- Stupid Randomizer Question
- '05 dodge durango head gasket replacement
- This 545RFE Can't take this much fluid can it? (Non Overhaul)
- radio
- Crankshaft sensor wiring issue?
- 2005 SLT AWD Hemi Parasitic Draw. Help!
- 2005 Durango Satellite Radio issues
- 2006 Durango ignition switch problems
- 2005 Durango 5.7l cruise control issue
- 545RFE Solenoid - Reman vs. New
- 2005 Durango Limited Hemi
- Autoshift
- 2005 With Intermittent Sirius Output
- engine fire
- 4 wheel drive slips going around corners
- Stuck in Ca due to a catalytic converter
- Only passenger window works
- 2008 dodge charger rough idle and etc light on
- 2005 Dodge Durango power steering
- Wireless control module -Truck won't start
- Faild MDS Solenoid Circuit
- 2005 Durango Hemi, Radio issues
- o2 sensor bank2
- 2006 Durango Disable Factory Alarm
- 2004 4.7 rattling converter and bad missfire
- Refit heating system and roof light
- 2004 Durango Rear Tire out of place
- p0700 limp mode
- Transfer case swap
- 04 Hemi Durango hit and miss acceleration.
- 2007 Durango HVAC Mode Door
- 2005 4wd options
- 545RFE Upgrades
- Preferred Order Packages
- Instrument Cluster Recall Help
- 2004 Durango Gas Hood Strut Kit
- 2004 durango 2x4 speed sensor axle
- 2005 Dodge Durango 5.7 Hemi multiple misfire
- Possible Transmission Leak - in Front?
- Headlight Switch Removal
- At a loss over P306 Code on '05 3.7L V6
- New member in need of help asap
- Are you having weird electrical issues?
- Oil Pressure Light - possible low oil pressure?
- Help! Solid red light on dash...
- Service 4wd light, erratic 4lock problem - FIXED
- 2006 Durango Interior Light doesn't come on
- 2005 Durango Hemi - play in steering
- Ball joints
- 2006 Limited Electrical? issues again
- Tire change?
- Backup Lights/Brakelights "Working" Together...
- 545RFE Solenoid - Any Major Reasons Against Reman?
- Engine swap 😤
- How to get steering rack out
- Front control bar bump stops on a 2005?
- Front swar bar diameter
- 06 4.7L Durango, is the TCM integrated to PCM?
- Cylinder 7 Misfire, only on Start (well, mostly)
- Electrical issues
- What the heck is going on? P0307,P0750,P0700, Limp Mode
- 05 wheels
- Help!
- Power Seat: where does it plug in?
- Check engine light after header install
- Few issues I could use some insight on
- Interior Light Won't Shut Off
- Rear Drivers side Axel Seal leaking
- Code P1128
- Overheating
- Rear liftgate squeak going of bumps
- 2006 Dodge Durango 4.7 liter cooling problems
- Rear fan resistor location
- What brand and grade are you guys using ?
- Brake issues
- Looking to buy, would I regret getting a 4.7 over the Hemi?
- No heat
- ESP/BSA and traction Control Lights
- 05 Durango noise in front
- 2005 dodge durango 4.7 litre
- Durango not shifting gears
- Help - Blend Door
- bypassing auxiliary pump disables a/c compressor maybe!!
- EVIC acting weird
- Big Brake Kit for '06 Durango
- 07 Durango fuel problems
- 2005 dodge durango hemi crankcase pressure build up.
- Durango 2009 Limited SVC 4WD alarm
- Durango 4.7L shuttin off and hesitate on low rev
- Misfire on cylinder 7
- 07 Durango No Fan Speeds At All
- overheating issue
- Front end noise
- AC line repair
- AC problems - Blower motor
- 05 5.7 durango transmission
- 2004 Dodge Durango 4.7 A/C problems
- key lost. no key at all . best . OPTIONS !!!!!!
- Front Diff removal
- 2004 4.7 intake manifold replacement
- 2005 4.7L Ticking, Milky-white @ oil fill
- Coolant reservoir removal
- Replacing condenser and receiver/dryer question
- 2008 Dodge Durango Brake Bleed Problem
- 07 durango tail light wiring colors?
- 2005 Durango SLT. Please HELP !
- 2005 Durango will start with key then shuts off immediately, but is fine with remote
- no speedometer 0 to 10 but ok after and no cruise
- Loud engine at start
- Will a 6.1 Hemi bolt up to the 04-09 Durango?
- Auxiliary water pump??? need info.
- Transmission upgrade for towing
- 2009 Hybrid
- 2006 heater door? blend door?
- 05 Durango Rear Diff Leaks
- 2002 durango speaker s
- New to the forum
- No cruise???????????????
- Durango 2008
- 04 Durango 4.7 fan clutch problems
- 2004 durango 5.7 hemi misfire
- NHTSA Recall 16V352000
- Electric Issues
- ESP/Traction control
- AC system intermittently working, no freon leak
- 04 durango throttle body
- 2004 Durango w/Hemi need you opinions.
- 2005 Durango AC COndenser Fan replacement
- ESP activates when it shouldn't P0340 present
- 05 Durango pinion seal leak
- Has anyone installed a engine cover from another Hemi car?
- hey !
- Esp
- 2007 Dodge Durango problem, need help
- Replacement Shocks
- p0300 CEL code
- Squeeling AC Compressor
- hey
- New 2nd gen owner
- 2004 Hemi Power steere pump pulley problems
- trouble codes
- Is this brake fluid compatible with my system?
- Maint: What should I look at while it's on the lift?
- 04 Misfire HELP
- Adjustable rear seat brackets
- Plastic piece inside oil refill port?
- 2006 Dodge Durango 4.7 liter A/C Compressor
- 2006 limited: is it possible to add aux cable to 6-disc head unit?
- Emissions problem!!
- knocking noise
- 2005 durango limited 58k miles
- Post ATF change, problems....
- Air Intakes for 2007 3.7 Durango?
- Weird ESP/traction control activation
- Help! Motor questions
- 2009 dodge durango roof basket
- RERear axle seal 12 bolt cover 9.25
- 2005 Durango....Head unit replacement guidance
- ABS and Traction control light
- front end vibration
- Odd transmission random problems 04 Durango
- I think my cat is causing problems
- Upgrades and Modifications - Overhead Console
- no power to factory installed 7 and 4 pin wiring harness
- Splash guard or under car shield
- Alarm system
- NV244 Shift motor replacement
- 2006 Dodge Durango 5.7L Hemi Limited w/ 5spd Automatic Transmission 4x2
- ac compressor w/rear control
- 2004 durango hemi 5.7 L code P0308
- Aftermarket door and dash speaker help.
- After market head unit interfering with ECU
- Warning Lights Flickering
- Cranks wont start
- bumpers
- Moving up to 2nd Gen.
- ABS Issues......
- 2006 dodge durango how to keep running
- Please help identify vacuum line connector *pic*
- Part No. or name: rubber elbow over air intake canister
- Engine Failed...
- air conditioner clutch
- 2005: liftgate lock motor actuator noise
- I'm thinking about installing some front struts on my '07 Dodge Durango
- 2005 Keyless Entry problem (FOB seems fine)
- 2007 Durango drive cycle test
- Interchangeable Heavy Duty Shock Absorbers?
- 2006 Durango p0404 code back after changing EGR valve
- Bank 1 Sensor 2 changing
- WATER in ECU's - where to check and what ecu to look for???
- Engine cranks continuously (won't stop) and no Start
- Durango 4.7 suddenly cranks continuously (then stops) and NO start
- 2004 Duango limited 8 codes
- remove rubber seal from valve cover bolts 4.7 l 2004 durango
- 2005 Durango Limited Caster Trouble
- Acceleration/lag issues
- 2005 Durango 5.7 Hemi - Multiple codes
- Going to look at an 04
- 2006 Hemi Limited overheat/fan clutch install
- Fun in the snow
- Aftermarket back up camera - headlight issue
- Plastic plugs/Screws P/N?
- 07 5.7L U0151 C2200 Dash is a Christmas Tree
- cost to replace valve cover gasket 4.7l
- Rear Middle Seat Belt
- 2005 Durango misfire
- Front Suspension Squeaking
- Windshield wiper motor issue.
- Stuck in park
- 05 Durango grinding noise/vibration
- what ac oil i need
- where pcv valve connect to????????4.7l
- I have an Extra 2004 Durango- That's Right, Extra.
- Lift, Body, Suspension, or Leveling Kits?
- 2007 Dodge Durango 4.7 Map Sensor
- Heat blowing from vents only, cannot change mode
- 2008 Hard Shifting from 2nd to 3rd at low rpm
- A/C compressor problem
- what ac compressor to buy?????
- alarm help
- Camber issue with front passenger tire
- Replace 2004 Hemi with a regular V8 Jasper?
- Starter Running On it's Own?
- IAC Valve Location
- 2004 4x4 Hemi LTD Rear Caliper Replacement -- Issues
- 2005 Durango 5.7 oil usage
- 2007 Dodge Durango 5.7 wont shift.
- Misfiring cylinder
- rear heater hose
- Factory Fog lights???
- External Temperature Reading Stuck
- any engine service manuals for the new 4.7 (2008-2009)?
- 2009 4.7 (corsair) head gasket question
- 2008 durango oil light help
