PDA
View Full Version : 2nd Gen Durango
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. 2005 Dodge Durango washer fluid?
  2. 06 4.7 Durango slt revving on its own
  3. '04 towed by car dolly - Rear Drive line removal
  4. Spark Plug 3.7L Durango?
  5. bad belt because A/C doesn't work?
  6. 2004 Durango 5.7L Hemi - Terrible Loud Clicking (not Hemi tick)
  7. Unusual error codes !
  8. 04 Dodge Durango Block Lifts
  9. Hemi Froze, now fine? Worried...
  10. Computer-based scan and tuning tool for Dodge?
  11. HID's
  12. Quick Chrysler Factory Plan Question
  13. Oil Light Flickering sometimes....
  14. exhaust
  15. Power window won't go up
  16. gas milage
  17. Throttle control sensor warning light flashing
  18. MSD Ignition Coils - 2008 HEMI 5.7
  19. Leaky cowl panel
  20. Solution: Key Fob failure and car wouldn't crank
  21. Car not overheating
  22. Weird problem?
  23. 08 Nerf Bar Options
  24. Durango Engine Issue??
  25. grille dimmentions
  26. [Q] How Replace Overhead Map Lamp?
  27. 2004 SXT Blower Swith issue?
  28. ignition switch
  29. My own build thread
  30. blown hemi engine swap
  31. 2004 durango shift cable problem
  32. no fuel pump
  33. Creaking noise in front
  34. Need a part # for transmission?
  35. New forum sponsor (///MoparAmerica) - Hey guys and gals!
  36. check engine light
  37. new to me Durango
  38. new member
  39. stumped
  40. Oil Sending Unit and Rear Main possible leak
  41. Durango Transmission/Transfer case problems
  42. Doesn't idle down when coasting
  43. 2004 Durango Hemi rear axle?
  44. Would this fix my stalling problem?
  45. New Guy Here
  46. looking to buy a Durango
  47. Sudden power loss while towing
  48. Aftermarket Radio in a VES OE equipped 06 Durango
  49. rear quarter rust reapair
  50. Help, please, with p3440 and 3444 codes
  51. Cylinder 3 misfire
  52. Can anyone confirm if this is a 2004 Headrest?
  53. Code
  54. Durango 4,7 2006 spark plug gap.
  55. Fuel Gage staying at full?
  56. Mopar oil filter 5281090
  57. 8= o2 sensor codes same time?
  58. Seats
  59. Tow wiring harness
  60. Shutoff during driving?
  61. Need Advice
  62. MDS to NON-MDS Help
  63. spark plug change interval
  64. Hemi knock
  65. 2004 hemi knock
  66. Timing chain
  67. timing?
  68. Really starting to hate this truck!
  69. Help Electrical gremlins
  70. cigarette lighter issues
  71. shop manuals
  72. Hybrid Durango
  73. P0307 (M) Cylinder #7 Mis-Fire Misfire detected in cylinder #7.
  74. 04 Durango Problems and Im baffled..Help please!!
  75. Crazy turn signal/ lighting issue 05 Durango
  76. Spark plug swap
  77. Electrical Issue / Battery Drain/ Radio Staying on
  78. Alternator Replacement in 5.7L Hemi
  79. loud hum while in 4 lock
  80. Automatic Door Locks
  81. Weird! 2008 Durango won't stat with Remote Sometimes
  82. 2003 Dodge Durango
  83. Durango fix windshield water leak under cowl
  84. Need to replace Idler Pulley
  85. Lug Nuts
  86. replace ignition cylinder in 07 Durango
  87. OBDII Code and trouble shoot question
  88. 04 w/infinity Stereo Replace Questions
  89. 07 Durango ETC, MDS issues
  90. leaking coolant-don't know name of component
  91. 06 Durango grinding noise
  92. Ignition Cylinder to be replaced
  93. 05 Durango Wipers turn on with ignition
  94. Anti-theft system
  95. 05 Durango ABS, Traction, Brake, Engine Lt
  96. Loud noise from driver's side valve cover
  97. 2007 Durango Headlight flicker/blinking
  98. 06 Durango Rims (08 D fit?)
  99. 2004 CD player
  100. Changing a 2 wheel drive into a 4 wheel drive
  101. Starter issue
  102. 07 durango 5.7 hemi will not turn over/start
  103. 2005 5.7L Suggestions
  104. Transmission issues PLEASE HELP
  105. question
  106. 2007 Durango Low beams don't work...battery died...
  107. Locations of fuel pump fuses
  108. Remote Starter for Durango 2007 SLT 4.7
  109. 04 Durango electrical Issues
  110. 2008 Dodge Durango SLT Hemi making popping sound
  111. AC Compressor always seems on
  112. Questing regarding MIL and Pcodes
  113. 255/75/17 Anyone running this size
  114. Tow hooks
  115. New Poster, Annoying Electrical issues...
  116. Stalling 2005 Durango Hemi
  117. Key won't start Durango
  118. Fuse box clicking after shutoff - 2008 durango
  119. Doors will not unlock...2005dodge durango
  120. Oil level warning light problem & what spec oil to use
  121. Gen2 D as a tow vehicle - n00b w/questions :)
  122. 06 Durango Auto Start
  123. SETINA PB400 for DURANGO?
  124. Help here please
  125. Air Bag Light
  126. PCV valve questions/mpg
  127. 05 6 cylinder tranny slipping 2nd gear?
  128. Caliber Break Problem - Cracked
  129. Bits of plastic in oil - timing chain guide?? or???
  130. Muffler Grounding??
  131. yet another plug question
  132. 06 Durango Gas out of filler
  133. 2006 dome light issues
  134. 04 Durango
  135. Shocks for 2005?
  136. Trailer light fuses
  137. Brake issues
  138. Durango stalled, but restarted HELP
  139. 2008 Durango Climate Control Lights out
  140. 2004 Dodge Durango 5.7 stalled
  141. 06 durango advise
  142. drive line
  143. help please
  144. ABS flashing after tire size correction
  145. '05 Durango A/C slow leak
  146. 2004 Durango starts humming at 30 mph, HELP
  147. Dodge Durango Sensitive Overdrive
  148. 300 and 308 code help
  149. **Prevent Your Hemi From Throwing Rods**
  150. Transmission
  151. MIL and engine surging, stalling
  152. How easy to swap 07-09 face on 04-06?
  153. service 4wd light 2004 Durango
  154. 2004 Durgano Hemi starting issues
  155. Vents Not Switching - NOT AN ACTUATOR PROBLEM!
  156. Liftgate won't open
  157. 06' Durango A/C not blowing & overheating when idle
  158. Difflock
  159. 09 Hemi 5.7 in My 04 Durango 5.7??
  160. P0734 Problem -- Help Please
  161. P0734 Problem -- Help Please
  162. Hemi threw a rod need to swap new one in. Proud new owner none the less ;)
  163. 4wd lgiht flashing then the smell of 90wt oil
  164. dont suppose anyone knows??
  165. 04 Durango 5.7 P0174 & P0171 codes
  166. Oil Light Came On
  167. Superchips Cortex Tune... now dash lights up
  168. 04 Hemi Limited randomly loud at start up?
  169. Best Option for Engine Swap????
  170. 2005 Durango minor window problem
  171. Ignition Accessory Delay
  172. 2nd row middle seat release strap.
  173. need help programming factory nav clock
  174. durango want start
  175. Power windows died
  176. 3rd row seet
  177. cat stuck in my truck
  178. Weird electrical issue
  179. Rear park assist not beeping
  180. Here's one for you all to ponder
  181. Engine Noise
  182. Front Sway Bar End Links
  183. Cleaning out Garage, All Durango stuff.
  184. Bakup light wires 2004 Durango
  185. Starting isues
  186. T B for a 2008 $.7L durango. SLT.
  187. 06 Durango trailer wiring bracket
  188. 04 Durango Intermittent A/C
  189. 2005 transmission dipstick tube broke
  190. 2006 Durango security system locked up?
  191. Engine Vin number
  192. 2004 Strange shifting, winding down noise
  193. front shock replacement
  194. 05 4.7 Durango stuttering issue
  195. Need help finding shift solenoid
  196. Help me please.. Code p0420
  197. 06 Durango Hood protector
  198. Towing with a 2005 4.8L V8 Durango with 3.55?
  199. 2007 Durango LTD Battery Light / Alternator
  200. New Key Blanks?
  201. 2006 Durango 5.7 Hemi Air bag seat sensor light going off
  202. 2006 Durango 5.7 Hemi Wind breaking door seal
  203. 2004 Dodge Durango 5.7 Hemi Overheating
  204. 08 aspen vibration at speed.
  205. 04' 5.7 hemi exhaust valve spring replacement questions
  206. please help
  207. Misfiring and Revving while idle 05 Durango
  208. Water getting on Serpentine Belt???
  209. Overhead console programming
  210. 06 Durango 5.7 Hemi possible problems
  211. After market keyless remote start + alarm installation
  212. All wheel drive to 2 wheel drive
  213. power seat doesn't recline
  214. 2005 Dodge Durango Cam Shaft
  215. Need help - water issue
  216. Battery OK but clicking only, jumpstarts fine?
  217. 2005 Durango
  218. Electrical System is Possessed
  219. Shift solenoid A malfunction
  220. p-2074 guestions
  221. O2 Heater Poblem, anyone been through this?
  222. 2005 durango limited 49k miles
  223. 3.55 to 3.92 swap fuel savings?
  224. DVD player-GPS and multimedia stereo replacement
  225. Nothing stops working when opening d/side door
  226. Airbag light
  227. Replacement headphone assistance please
  228. Performance exhaust without the noise?
  229. 06 Durango Navigation satellite radio installation
  230. Hemi Swap into 04 Durango
  231. K&n good Superchips not so good?
  232. Rebuilt 5.7L won't stay running - help!
  233. 04 Durango 5.7L 180k miles. Electrical Drain issue
  234. 2005 Durango Limited Satellite Radio
  235. 04 HEMI Gauge problems
  236. Auto Climate Control - Disable Passenger Side Control
  237. Quick trans question
  238. Warm Air Front / Cold Air Rear
  239. 06 Durango,wont start, has me baffled!
  240. Electric/transmission help!!!
  241. Auxiliary pump
  242. 2004 Hydrolocked, best options..
  243. Trouble with 2000 Durango
  244. Swishing sounds
  245. Part number - right side piston, 5.7L
  246. 2004 durango 5.7 smoking white&blue small tick?!?!?
  247. 2006 Dodge Durango TPMS light and Cargo Lamp Problem
  248. trans problems 5.7 hemi
  249. 3 questions on one
  250. 4.7 Durango engine siezed
