PDA
View Full Version : 2nd Gen Durango
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19
  1. 2004 slt 4.7 l overheathing?????????
  2. 06 4.7L SLT / C.E.L. on won't go above 2500 RPM
  3. Jeep 4.7 Into durango problems
  4. Elusive Electrical Issues
  5. I lost all gears going down the road! 05 4.7l durango
  6. Dodge Durango owner
  7. 2007 Durango or a truck? Which is best?
  8. Ram long tube headers
  9. 2005 Durango 4.7L radiator questions
  10. AC Wacky
  11. Key FOB programming - PIN needed?
  12. Pcm retrain
  13. Timming help 04 4.7l
  14. Tranny help!!
  15. 05 Fuel Tank Filler Recall
  16. 07 Durango Vibration at 70 to 80
  17. Gas leaking through entire exhaust system?
  18. 2004 dodge durango 4.7 secondary tension arms
  19. Any power gains from CAI on 4.7?
  20. Thinking about buying a durango
  21. Intermittent Humming Noise
  22. Pleased with this new 2005 Durango to us
  23. Mode from Auto to 4wd lock
  24. 170K miles on original Hemi/trans - how many more miles?
  25. WIX oil filters?
  26. 2006 Durango Limited Grille Rippling
  27. Engine Issues!
  28. 2005 Durango, Hemi Shocks
  29. 2005 Durango, Hemi computer mods
  30. 05 5.7 ltr Durango whining noise
  31. Durango with P0456 code
  32. Fog lights not working need help
  33. pvc help
  34. 2005 Dodge Durango Limited Hemi Gas Gauge problem
  35. 04 drivers side clunk
  36. Lowering durango
  37. Engine light troubles
  38. Timing problem
  39. New to Chrysler/Dodge
  40. 05 Durango limited
  41. transmission problems driving me nuts
  42. Transmission failure, No warning.
  43. Please help! Mice getting in interior 2007 SLT Durano
  44. 04 Just crapped out - should I get another?
  45. 2006 Dodge Durango Ac issue
  46. CD Player, Dead Battery...
  47. 2004 Dodge Durango Amplifier Problems.
  48. 04 Durango 5.7 died while coasting
  49. 2004 Dodge Durango Amplifier Issues
  50. Engine replacement for 2005 Dodge Durango
  51. intake mod
  52. 5.7 L Mod Advice
  53. Transmission
  54. AC Fan control/direction buttons not working?
  55. I have no idea what to do...Please help!!!
  56. Towing/Load handling shock
  57. ESP/TSC light on when turning
  58. where's the trailer wire connector
  59. Flapping noise coming from engine
  60. help with windshield sprayer/hose
  61. cracks in factory aluminum wheels
  62. Engine Build Date
  63. DodgeForum at Chrysler Nationals!
  64. Can anyone check a VIN today? Looking at buying a Durango.
  65. Air is blowing hot or cold intermittently
  66. Fuel overflow recall and rust
  67. 04 dodge Durango
  68. Cylinder 6 misfire but can't find problem
  69. P0303 and p0303 p code
  70. Shop manual
  71. Plugs, coils, wiring, fml
  72. 2005 w/4.7L
  73. '04 Durango Won't Start - Transmission Grinding
  74. Can a battery cause a MIL to come on in 07 durango?
  75. 05 dodge Durango
  76. New Stereo/GPS - Need wire signals
  77. 5.7 V8 O2 Sensor Location Answer
  78. 05 will not start
  79. Rear light sockets.
  80. AWD noise question
  81. Died and won´t start
  82. Shaking between 40mph and 50 mph?
  83. Pass Airbag Off
  84. Replacement rear springs on the SLT 4.7 AWD
  85. Miss on cylinder #3 plz help
  86. Key program failed
  87. 2007 Durango Clunk when Accelerating on Highway
  88. P0841 issues
  89. Noooby here! Sound System on a 2008 Durango?
  90. Need help with 2005 Durango Problems
  91. 2007 wheel and tire help needed! 0 Offset?
  92. Dodge durango 2004 code P0100 problem help asap
  93. AC Evaporator Replaced on 2008 Durango
  94. Is there an easy way to lower a 2008 by 1-1.5"?
  95. 2 Problems: Gascap light and Gas Spits back out at pump
  96. fuse for cigarette lighter
  97. 08 Durango
  98. 2006 Durango automatically applies brakes at 60 mph
  99. 2 Row Raditor Or Wide Single Row?
  100. High RPMs at Start
  101. 05 Durango 4.7L Can't replace pcv hose.
  102. What i learned today with solenoid replacement
  103. Picked Up A 04 Durango 5.7.....Problems!!
  104. how to to engine code check
  105. Spark Plug Change Advise
  106. 2004 acting crazy......HELP
  107. Fuel Ratio rich and High air flow, constant limp mode when braking.
  108. Dodge durango EGR help!
  109. Car dies occasionally and wont start
  110. # 3 sparkplug black sout on it
  111. need help on a 2005 durango
  112. blinker light stays on all of the time
  113. Transmission in LIMP mode - could this be TPS?
  114. New tie rod on my 04 Durango, now I can barely turn it
  115. Burning oil smell in cabin and engine -4.7L
  116. 05 durango 4.7 awd steering hard
  117. I'm ready to get a lift
  118. 05 Durango 4.7L will not start
  119. Oil pressure light flashing
  120. Durango Seat Issue
  121. Possibly Durango Purchase
  122. power steering leaking!! Help!
  123. code P1129
  124. Electrical or Computer?
  125. 07 Durango Horn not working.
  126. 2nd Gen Durango Rocks!
  127. cooling issues
  128. # 3 sparkplug black sout
  129. Instrument lights not working
  130. 04 Durango mystery leak
  131. Fixing a Durango "nO bUS" PCM for $5
  132. Durango wont start! Code P0522 Please Help!
  133. Went low on oil Durango wont start! Help
  134. 2006 Durango trans problem?
  135. New Durango issues
  136. 2004 2nd Gen Eating Front Sway Bar Bushings
  137. Seat Belt - Courtesy Lights
  138. Need help Dodge Durango SLT
  139. 2005 Durango
  140. HID light advice
  141. 07' Durango Hemi "gascap" light issue?
  142. 2004 Durango 5.7L Hemi Waterlocked
  143. hucklebuckin durango
  144. how to check for blown head gasket
  145. 07 Durango: Dash Cigarette Lighter/Power Outlet Not Working
  146. a/c heating problem
  147. Cabin filter on Durango 2006??
  148. 2004 Durango quit working.
  149. headlight problem
  150. 2004 Dodge Durango Limited VES System
  151. Fuse for power mirrors
  152. Pcm????????
  153. ing power train control
  154. Question Help
  155. Merry Christmas
  156. 2002 Durango Unkown issue.
  157. Remanufactured engine Causing problems.
  158. mess changing oil
  159. TPS? transmission?
  160. Mutlifunction Controller problems (Turn signal switch)
  161. p0499 what could this be?
  162. Remote Starter Question
  163. 2006 durango cooling/engine trouble (in the right section)
  164. 2006 Durango SLT cooling/engine mystery! Help!
  165. HELP! All light work except for brake lights
  166. Newbee Front Drive Shaft Question
  167. Won't start, one click, replaced starter
  168. Torsion/Shackle lift question...
  169. 2005 Dodge Durango - Replacing ignition lock
  170. 5.7L Hemi Misfires/Stalls/ETC light/Rich Fuel-Air ratio
  171. Open diff?? Limited slip?? Torsen???
  172. adding receiver hitch. which one?
  173. lower ball joints
  174. 2004 Dodge Durango Key-fob broken Or Just Not Working......
  175. HELP! No start after engine swap
  176. 2nd Gen Durango Service Repair Manual?
  177. How to check codes on 04
  178. 2005 RFE Transmission codes P0845 and P0846
  179. Aftermarket Key Fob
  180. Windshield Washer Fluid Level Sensor
  181. Bank 2 Sensor 2
  182. 5.7 hemi loud tapping (not HEMI tick)
  183. P0304 Misfire (Cold Engine only)
  184. black soot on plug
  185. no spark on coil#2
  186. where is coil#1
  187. idle rough
  188. 5.7L Hemi Misfires and Throttle control - ETC light - Wet/damp
  189. 2005 Durango oil light flicker/blink at low RPM
  190. Air Lift...?
  191. seat swap
  192. Can someone just confirm...please
  193. 2005 Durango engine runs hot
  194. Help me shop for a Durango, school me on what to look for
  195. Seat Belt Light & Air Bag Light
  196. Looking for Repair & Service Manual DD 2007
  197. Aftermarket Transmission Cooler
  198. Happy Thanksgiving
  199. Durango 2008 stop running engine
  200. 2005 dodge durango tune-up tranny flush questions
  201. trans problem wont go into gear
  202. 2004 Durango headlight blink out and blower motor for ac/heater
  203. Running boards for 04 Durango
  204. A/C Control Panel Bulbs
  205. 2006 Durango Battery Drain
  206. ESP light on Dash stays on?
  207. Tire Swap
  208. Starter/solenoid Location
  209. Loosing anti-freeze
  210. Horn Blowing by itself
  211. 2005 Durango TPS Keeps Going Bad
  212. HELP 04 Dodge Durango 4.7 Timing/Head Gasket
  213. 2004 Hemi Dodge Durango with a sticking accelerator
  214. 2007 durango trans slip?
  215. Climate Control Issues.
  216. Engine swap Question
  217. 2005 Dodge Durango ABS and Traction Control Light On AGAIN!
  218. Preemptive strike for 2004 with 5.7L Hemi?
  219. HELP! 2004 Durango 5.7 Hemi engine SUDDENLY DEAD
  220. When would you use 4x4
  221. Advice PLEASE
  222. Transmission Solenoid Pack Help..
  223. Head Gasket Replacement
  224. Rack & Pinion Durango '04 5.7L Hemi LIMITED
  225. EGR Valve replacement
  226. Slow shifting from 1st to 2nd
  227. error message on cluster
  228. Help! won't shift into any gear, like its in towing neutral.
  229. looking at a 2004 durango
  230. 2006 Durango - loud roar and loss of power
  231. 2006 Durango will not start and red light on dash
  232. Headlight Removal/Installation on 2008 Durango
  233. 2002 dodge durango 4x4 r/t. Transmission
  234. Question
  235. 2005 tranny?
  236. Trunk gate sometimes opens
  237. Q: No sound from multimedia. Why?
  238. Where is the TCM cable?
  239. Parking Lot Problems
  240. Replacing headlight bulb 2004 Dodge Durango
  241. Durango Vararam Intake
  242. no control for multimedia
  243. request duplicate key ignition with remote
  244. Hitch on 07 Durango
  245. oil drain plug
  246. 2007 Durango Hemi stalling after refueling
  247. 2009 4.7l
  248. Driver Window Switch
  249. 04 durango problem
  250. Problems with 2008 Durango
