- AC intermittent ... evaporator ?
- ? Options for upgrading radiator on 07 4.7
- 2005 Durango A/C issue
- 2005 Durango Center Console Removal
- egr valve
- Buying a 2004 Durango
- buzzing or humming noise
- 05 hemi durango headers?
- Dangling Exhaust Grounding Strap
- A/C Expansion Valve
- 2005 dodge durango limited questions
- 04 durango a\c compressor oil
- No turn signals or hazards on 04 Durango
- Stock Tire size
- fan clutch help
- Pati Stone
- Cherry Bomb on 06 Durango 4.7l 4x4
- creaking noise from back left wheel...
- Radiator fills Bottle but won't Suck back
- Cherry Bomb
- 2005 Dodge Durango limited ?
- Need picture to locate IAC valve on 2005 4.7L
- Automatic Headlights Do Not Go Off
- 05 Durango A/C issue
- EGR Valve Replacment 2008 durango 5.7 Hemi
- Need advice in deciding between an '04 or '06 Durango
- Horn and rear A/C problems
- plan on buying a 04-info please
- rear a/c
- a/c problems
- Dead Battery again codes, finally-HELP!
- Keys Won't Start Car
- 2004 Durango limited 4X4 with 5.7
- Doors Lock Automatically when Motor is running and door is closed
- '04 5.7L Durango 4x4 Rear Axle Shafts
- Door Sensor not working
- Poorman's Replacement Key Solution
- AWD MOD Question
- 07 Durango Power Seat Problem
- Please read BEFORE posting in this section
- Question
- chrome door handle problems
- change the axle fluid on a 05 Durango 4x4
- 2004 Durango flashing lightening bolt
- Tow/Haul Mode Problems
- 2006 Dodge Durango Car Trouble. Need help!
- '04 Durango Limited 5.7 Hemi overheating
- 4 X 4 issue
- Rear hatch
- EGR Valve
- 5.7 HEMI Power loss 2005 Durango
- Broken shock! What the...??
- Rango bogging down underload
- AC Lines?
- 2005 Durango AC
- 2005 Dodge Durango - Lifted?
- Running poorly after EGR
- '07 Will Not Start Unless Ignition Key is Wiggled
- 04 5.7 Hemi Limited - RUST BUCKET
- Need some help
- fuel pump relay and pcm
- Front sway bar bushing replacement
- Clunk sound while turning at slow speeds
- Ignition Issue
- 2005 Durango Key remote
- A/C Blend door?
- Normal Fuel Mileage
- Brake warning light came on
- A/C Problems
- Tow hooks 2006
- accelerator pedal
- Coolant Bleeder Valve
- Driver air bag light
- my 04 durango hemi stalls when it rains
- Thinking about new exhaust......
- New Member, 04Durango 4.7 stalls?
- Chrome handles?
- Replacing the Throttle Position Sensor
- 2004 Durango check engine light
- 4.7 exhaust manifold leak
- DTC P1128 and P1129
- 04 Durango 5.7 HEMI Limited rough idle
- AC compressor Top up
- Index for U-codes?
- 05 Durango stalling
- Central timer module
- Fan Clutch Don't Engage
- electrical issues
- valve problem?
- Looking to Buy a used 2004-2007 Durango
- Any ideas on front leveling suspension or lift kits for AWD?
- Performance Upgrade Advise???
- Durango 2004 Hemi, clauster gauge problem
- Power Drain Nothing Turns Off
- Get together invitation
- stalling
- New Member, Need O2 Sensor Help
- 235-65-17
- Check engine code on my 04 Durango
- Durango Shaking a bit at idle..!
- Cylinder #5 misfire
- windows not working!!! help!!
- 2004 Dodge Durango (Front Air)
- Dodge Durango 2004 Keyfob broken Help!!
- 2004 durango
- Spark plug change problem?
- Seat trim replacement parts
- Hood struts?
- Amplified system?
- Spark Plug Change Tips
- 2004 Manifold bolt?
- Back door problem
- 2007 durango ingine noise heeellllp!!!!
- Air Conditioned problems
- 2004 exhaust manifold
- Electric Fan upgrade
- Cats
- temp control wiring harness
- 2005 Durango - Need some off road tips
- socket trick
- 04 Hemi misses when wet
- 04 durango 4.7 misfiring!
- 04 Durango instrument problems
- 07 Ltd exhaust changes
- towing with a 2005 Durango
- Whats the best Programmer, Tuner for the 2007 Durango
- Looking to save at the Pump
- New member & need help!
- Gascap message
- Lowered 04 Durango
- Break Lights Not Working Please Help
- New noise with flowmaster cat back
- 2006 Durango Squeaking sound in the front???
- Rpm's jumping
- 2004 5.7 Hemi oil leak
- Please help
- Behind the grill.....
- Turning off DRL's!
- '04 5.7L Durango Won't Continue to Run
- 2007 5.7L 4X4 Rear Diff Leak?
- Stock intake box needed bad
- 2004 Durango 4WD AWD Shift Problem
- rear DVD
- grille help
- Goodyear Wrangler AT/S... Anybody run them on here? good or bad
- Wierd Radio
- Gas Mileage
- Passenger side airbag question
- 04 Durango 5.7L P0174 & P0172
- 2004 Hemi Durango -Poor acceleration and odds issues
- Sites for HID fog lights....2008 durango
- Weird Electrical Problem
- New to me Durango.. problems already
- durango Hemi transmission cooler size?
- Park Assist Problems
- 05 VES system help
- 2005 Durango
- 2nd row seat belt stops broken
- 2005 Durango sunroof drain tubes
- 04 durango seat removal
- Car stalling
- Engine help
- Wife whats a new durango
- Dodge Durango Failure
- Please help with pic of Infinity amp
- 2006 5.7 Rear O2 sensor voltage?
- Hemi Oil Burning No smoke/leakage
- Durango Sirius-no signal
- 2006 PCM C1 & C2 location?
- Which gear lube
- Durango v. Aspen
- 2005 Dodge Durango - Radio Problems
- Changing the coolant
- 06 5.7L RPM change
- 30K mi 4x4 service
- How to replace EGR Valve 2007 4.7
- engine knocking and rough idle
- rear windshield wiper
- New wheels and tires, now an issue
- 06-09 durango parts manuals
- Automatic Headlight Mod in 08 Durango
- P0404 changed to P0405
- Exhaust System Replacement advise
- Hemi Tick Tick Sound (Spark Plugs Knocking) Sound
- Aftermarket exhaust
- Front Diff. oil questions
- Cam Positioning Sensor
- How to replace EGR valve
- Superchips Tuner for 2008 Durango 4.7L
- Turbo?
- Need help !!!! 5.7 hemi knock!!!
- 2006 dodge durango limited transmission question
- Heat and A/C ventilation Problems
- Do I really need a trans/diff/transfer case service at 50k?
- Chilton or Haynes?
- best place for hemi oil change?
- 05 4.7 shifting issues
- 2006 SLT Durango head lights and interior lights flcikering
- 3rd row seat question '05
- Transmission Question
- 2005 Durango Hemi Problem
- Get em while their hot, PDF Service Manuals!!!!!!!
- Code P2175 Throttle actuator Ctl Sys - Low airflow detected
- 2008 dodge durango.....service park assist
- GF Performance Chip
- Removing rear subwoofer panel
- Exhaust help
- '04 radio mystery. HELP!
- Fog lights and srt 10 rims for a 2008 durango
- Superchip or Bully Dog?
- 05 Rear hatch water leak
- 2004 durango 5.7 hemi with the check engine light flashing!
- 2004 Durango
- 2006 Roof cross bars
- have a questions
- MIL dash light is on
- Queston about generations
- 05' dodge durango won't start
- Idle/Acceleration Issue
- 04 Durango - few issues
- '04 5.7L Durango No Cruise Control!!!
- airbag light
- Need help with fuel mileage
- iPhone interface for factory radio?
- Code P0404
- True Delta
- dodge durango 2004 SLT LIMITED Hemi.
- Does anyone know what this is?
- Bad PCM???
- New to me 2006 SLT
- Normal position for temp gauge for '05 D when running
- 08 headlight problem, alternating sides?
- Evic and Auto Climate Controls
- Rpm?
- codes
- Navigation unit not working
- Factory "Chrome Clad" wheel question
- 2007 Durango interior trim parts
- '05 Headphones
- Heater Core??
- 2004 Durango Hemi rough idle
- Electric front driver seat problem.
- Transmission Problems???
- '04 Durango 5.7L Hemi vs '04 Ram 5.7L Hemi
- 2005 Dodge Durango Sluggish on cold start.
- Water In Fuseblock
- Thoughts on this Durango?
- Dodge Durango Questions Advice
- Tire Size Options on 07 Ram w/20" Rims
