View Full Version : 2nd Gen Durango
Pages :
1
2
3
4
5
6
7
8
9
10
11
12]
13
14
15
16
17
18
19
- 04 5.7L 13k miles, won´t start, fuel pump?
- Synt oil change 5.7 L over 100k, grade?
- Trailer package questions with coolers?
- superchargers
- 2004 dodge durango with hemi....engine light and a red symbol
- Changing spark plugs/coils in my 2006 Durango 3.6
- Warning Chime Won't Turn Off
- Changing plugs/coils on my 2006 3.7 V6 Durango
- Question.
- Indicator Lights
- Brake lights
- 2004 Durango Limited exhaust leak sound
- blower motor resistor question?????
- 2008 Transmission, done?
- 2004 Durango Airbag ECM
- Need Replacement RF Headphones for 2004 Durango VES
- Where to buy FOB keys? Durango-2005
- K&N CAI, Magnaflow, Diablo, and Therm 180, whats next??
- Anyone Familiar with Front Suspensions
- Southeast members...
- starter 06 durango
- sway bar
- Speedo Adjustment
- 2007 durango Black grille shell - like night runner
- 2007 Durango - Sudden Acceleration when brake applied
- Over Charging issue on 07' Durango
- Challenge: Identify this Durango component!
- '05 Durango electrical haywire
- smell antifreeze, but no drip.
- gauges & blinkers go out periodically.
- a/c not working well
- 2004-2007 What is the big difference?
- Transmission problems....
- Replacing a serpentine belt
- durango heavy mod pics
- Hemi Overheating
- How to mount a 7" monitor?
- Oil pressure problem...HELP please
- Brakes
- Fusebox - which fuse goes to which item?
- Windows won't roll down
- 2004 Durango overheating?
- Defroster only cooling and heating
- Gas Cap issue
- Nitto Launches New Interactive Tire Finder
- 2006 durango, another blower motor resistor question???
- Problem with HID's
- blower motor ground ??
- How to change spark plugs on a Durango with a Hemi yourself
- Modifications....
- changing spark plugs in 2008 durango with hemi
- MDS problem
- front end clink & more
- Front end clunk
- new to DF
- Air Conditoner ?
- Radio Volume Problem after boost 2004
- Do It Yourself (top questions and answers) FAQ's
- Inspection problem
- 2gen pdf service manual
- 2007 Durango Won't Start !!!
- Instrument Cluster/Interior Lights?
- Low Side Service Port
- Want a bigger trans cooler
- Map Sensor and Diablo preadtor question
- My '04 5.7L Hemi Durango
- Need help. 2004 durango 4.7
- '04 4.7 Running Hot
- Rear bumper question
- Help durango 2004 hemi 5.7 limited
- E3 spark plugs and Leveling my truck
- Brake fluid capacity
- 04 Durango 5.7 Shifting Hard into 3rd gear.
- 05 durango max towing ?
- Temp guage
- oem 2164 or 2234
- 2007 Durango Night Runner black chrome wheel paint ?
- PCV valve?
- Knocking sound?
- 6 Disc RAQ Radio
- 2005 durango LIGHT problem
- 4.7L Headers????
- 26 inch Rims????
- Ignition System Problems
- body lift
- A few videos for you viewing pleasure
- Eye Lids
- Idle up and down...help
- Bass sounding growel rumple
- 2004 durango eletronics issue
- overheating problems
- Factory Radio
- 04 Durango Video Entertainment System (VES)
- No Roof Rack, But What are the Black Strips?
- Disc Read Error / CD Player
- 2010 All-Chrysler Nationals - BE THERE!
- Over heating or not???
- 2005 Dodge Durango wont start?? WTF
- Here is a stumper??
- towing
- Starter 04' 5.7
- Coolant
- Does my mechanic know what hes doing?
- Thud sound in rear of vehicle when slowing down
- Wheels and Tires?
- no cruise or horn
- Rear air bags?
- More shock questions...installation
- Bilstein question
- Aftermarket Radio question, what is needed???
- 04 durango fuse box question
- Clunking noise?
- HVAC control lights
- Durango hemi '05 OCM,front passanger seat issues
- Window console problems
- Help!!!!
- 05 durango navigation quit
- Radiator Change
- remotless key
- Lift kits for 2005 Durango & headsets
- Need spare key
- Hemi air intake +k&n
- Levelling the front end
- ebay performance chips?
- Durango 5.7 hemi 04 electrical fan convertion
- Brake controller conections
- Bluetooth in '06
- Fluid change
- What oil?
- A little BLING for show ( New Grill )
- Brake pedal wobble???
- 3rd gen ram totm! Yall come vote
- Car smell part 2- Please help!!!!!
- 06 Durango SLT AWD vs 4x4??
- Got Mods???
- Biggest 22" tires for an '05??
- 06 Durango..fuel overspill
- P2175 5.7L 04 Durango & ALTERNATOR ISSUE?
- 2006 durango Nav and a/c ???
- 5.7L heat gauge goes up very slowly
- Temperature Gauge Question - 5.7 Hemi
- Wheel fitment question - 2005 to 2008
- Is this possible? Third seat install?
- idea for possible inch or 2 durango lift
- navigation system
- Lift Kit!
- Durango coolant problem?
- CD Changer not working
- '05 3rd Row Bench seat??
- Transfer case problems
- Poor fuel economy? 11 mpg hemi -2004
- If you can't turn key-how can you remove lock cylinder?
- Help! Rear pinion seal.
- Need help understanding P0430 code
- ABS Light and Cruise Control
- Inner Tie Rod failed inspection
- aftermarket stereo
- 2009 Durango SLT
- Ign.lock cyl. problem
- 2007 durango hid's help
- O4 Loose front end and no steering
- change in tire size
- 04 Durango A/C blowing warm air!
- 2nd row center console removal
- 2005 Nav system replacement
- Mice, Durango's 7 insurance companies
- Durango Rear Wiper Blade
- 2004 Durango Passenger "Mirror Molding"
- Help!replacing EGR Valve 04 durango
- P0404 2004 durango engine code-help!
- Rod bearing? What am I in for??
- ETC light
- How do I remove the Navigation Disk on 2007 Durango???
- Engine Removal ?'s
- Can't get audio through head sets
- VIN location on Engine, Tranny
- Airbag Calibration Cosst?
- 04 unlevel suspension
- @nd Gen suspension and tire size
- Noise when gas pedal is pushed
- annoying noise coming from ??
- How do I know what gear ratio I have
- Uconnect and DVD
- Please read BEFORE posting in this section!
- Help plz 05 durango no power !
- Link to Wiring Diagram for (2004 - 2011) Durango, Ram, Caravan, and Dakota
- '07 Hemi Durango Programmers
- Torsion bar lift on an 04???
- Big wheels - Small spare tire ??
- 20's to 18's and tire pressure sensor.
- Replacing stock HU in an 04 Durango Limited
- 2006 Dodge Durango
- Need Help Can't get rear calipers off!? 2007 Durango
- Fill plug on rear diff
- Ignition switch Code U1120
- Fuel Filter Location
- Latest Superchips badges available
- New guy with a question and saying Hi
- spark plug idle problem
- Oil
- Please help, 06' Durango P2074 code and dieing issues.
- Front diff synthetic fluid?
- 05 Durango 4.7L engine
- 2007 Durango - Idle Issue
- Stock 05 Durango SLT improve MPG and Power?
- Replace fog light in bumper
- Another tool to buy
- Oil Light Intermittent
- newbie with 04 5.7L durango
- Hey Durango friends!!!!!!
- Drive Belt
- Tinted Tail Light
- MIL Light on
- Starting problems on 2004 Durango Limited
- Need tire advice
- Tranny / diff. Oil question
- Diff. fluid / Tranny fluid questions
- 2005 Headlight bulb replacement
- 07 dodge durango ride height adjustment
- Problem/Concern with Traction Control
- 2004 Hemi Durango hesitation at initial acceleration
- 5.7 what gas do you run?
- need help find name for this part
- To K&N or not to K&N
- Tires what do you like
- Location of the oil pressure sensor - 04 5.7
- Wire diagram for 04 Durango 5.7 Hemi?
- 2004 Durango Limited - NEED HELP
- 2004 Durango Evaporator Change Out
- NC get together
- 2nd seat center swap
- 2004 Durango 4.7L Exhaust Manifold Gaskets
- Orlando get together Feb. 28th
- Keyless Entry Wiring Trouble
- 04 Durango won't start, no spark.
- Adjusting Camber on 06 durango
- Fuel Pump
- Spark Plug
- tire chains
- Durango aftermarket rotors ???
- Navigation System
- 2004 Durango SLT - Engine knocking when cold
- Heater not working on my 2005 Durango
- Interior Lights - HELP!!!
- Changing Headlights
- odd dash light activity???
- 07 Durango Suspension Bounce
- 4.7 Club..........
