- ECU went out on 91 stealth
- EMERGENCY!!!
- 6th gear
- 93 STEALTH R/T FOR SALE
- engine rebuild tips?
- anyone ever run into this
- Help please
- wiring issues
- 91 stealth front end needs work!
- reverse glow gauges?
- headers/speakers?
- '92 Stealth SE Part Out
- Idle speed
- Stealth Mechanic SF Bay Area (South prefer)
- timing belt tensioner
- overheating problem
- 92 Stealth Exhaust
- Radiator light, and power steering?
- Need engine help
- question on rim interchange
- Need Help with the head gasket!!!
- little part needed asap
- installing timing belt
- trying to find....
- Is a Stealth right for me?
- ECU question
- Light coming on-1991 Stealth
- turbo upgrade?
- burnin oil and oil pressure
- My Story please help
- Short Block Needed!!!!
- 90-96 stealth
- For Sale: 1994 Dodge Stealth R/T Twin Turbo
- Wire set change
- 92 dohc engine swap to 95 dohc
- 92 dodge stealth hard to start when cold
- Congrats to Yevgenievich
- 91 Stealth R/T ABS light
- A few Maintanance Questions
- 94 stealth rt down
- 3.0 SOHC Intake Availabilty
- Anyone have a short block for my 93 Stealth?
- QUESTION ABOUT ECM'S plzzzzzz help
- TT Speedo, Tach and Odometer not Working
- dodge stealth in the 8's
- 200,000+ Milage Stealth For Sale?
- looking for a mechanic
- fuel pressure
- misfire
- 92 stealth pls help
- BIG PROBLEM WITH 92 PLEASE HELP
- Steath quits
- Steath quits
- valve clatter,cheap gas?reguler unleded?
- Replacing Valve Stem Seals
- IM BACK HAHAHAHAHHAHAHA
- Paint won't adhere to rear bumper
- for sale
- Compression - what should it be?
- Coil Pack
- engine swap
- Tensioners?
- were to find parts for transmission
- sensor location
- Stereo wiring
- yes or no?
- '92 Stealth Parting Out
- Intercooler
- LOOKING VOR VACCUM LINE DIAGRAM
- Spark Plugs
- Where did these come from
- Went to the drags
- Newbie/Sick Car
- Octane booster
- Engine knock on startup when extremely cold
- Engine Rebuild and Others
- i need a white front fender!
- performance chip
- Maybe Trading for 1993 Steath RT/TT
- what is going wrong?????!!!!!!!
- 91 Dodge Stealth R/T Twin Turbo AWD for sale!
- Compression and vin decode
- Engine
- RIM ??
- FOR SALE 93 STEALTH R/T 49K ORIGINAL MILES
- Wanted 92 driver door panel graphite color
- TRANNY ECM QUESTION
- Please help me...
- Stock Info
- Steath rear bumper emblem/decal need photo or info
- Engine Prob Need Help From Anyone Plz
- NEED SOME TRANSMISSION HELP
- PLEASE HELP!!!!
- Repair Manual
- Upgrading!!!
- trans problem
- Intake kit
- Transmission
- Brake light?
- Selling 92 N/A auto $1000 OBO
- Green Rims!
- One Turbo out
- Pics from the first 2008 Show
- belt trouble
- motor spins over easy,no compression
- clutch prob
- ECU Question
- Here We Go
- ICH exhaust
- rectifier plate
- ECU NEEDED PLZ
- COTM
- hatch options
- ES?
- 1992 Stealth
- For Sale
- Speedometer problem
- Headlight conversion
- Stealth RT 93 backfire
- DOHC 24 Valve
- Where to buy ball joints for Stealth?
- 1/4 mile stealth
- 91 stealth es help
- 91 Dodge Stealth RT $3000 OBO CENTRAL CALIFORNIA & SOUND
- l@@king for a ECU...
- Voting is going on now!
- new upholstery
- Deleted
- Did anybody have tachometer problems?
- Clutch or Tranny problem?
- Regional Sections!!
- engine swap stealth r/t
- Sloppy Shifter
- 92 white stealth for sale! can be daily driver or parts car!! 900.00!!!
- Wheel Bearing
- Well if anyone wants to come pick my car up aroudn texas...
- Engine Light!
- Power Window Locks?
- 91 stealth engine problem
- wanna trade
- overheating
- 91 Dodge Stealth RT ENGINE for sale LOTS OF PICS
- gauge cluster
- No fuel from injectors
- 1991 tranny issue
- engine dies after 15 minutes-computer? HELP
- Stealth will not start.
- oil pressure light on.... then off
- wire harness
- 96 Stealth Parts Car and other Parts for Sale
- oem seats
- stealth power antenna
- stealth down
- Stealth RT won't start
- Please help. Had oil changed and put wrong oil. Synthetic.
- do you know
- reverse glow guages
- odd sounds =)
- Replace fog light bulbs
- Flex section exhaust pipe
- starting problem!!!
- new to the car
- BOV
- Who is the manufacturer of this bumper?!?
- active aero
- lowering springs
- 91 stealth repair bill questions
- 1993 stealth es want to turbo it?
- does anybody know?
- RIP Stealth 1994-2007
- Problem with gas getting to engine.
- rpm
- Is it oil or my TCU???
- Electronic Control Suspension
- lowering springs
- OD not working
- project
- Hello ALL
- Thought I had her all sealed up....but no
- Cat converts
- shifting problem
- Turbine Wheel Clipping
- muffler
- new engine.
- Clutch problem?
- want to help out and say hi
- Eliminating the cat
- Wire on Intake Pleuem
- 1991 Dodge Stealth SOCH won't start - smoke coming behind engine
- 1991 Dodge Stealth SOHC Overheating Problem
- Exhaust
- 1993 stealth es won't run
- Wheel problem
- Major help needed!!!!
- Rain and after market hoods
- Installing an intercooler ?
- intake
- Fuel Pump
- Whistle sound
- fifth gear popping out?
- Sputtering Problem
- Amp to stock stereo
- digital climate control
- wheels
- Re-painting
- Somebody help me please Stealth TT Problem
- sons 92 stealth r/t dash fire-car gone!!
- Turbo flange
- electrical problum
- Alarm and Starting Problems
- Where do i put the oil in??
- 91 Stealth R/T Twin Turbo for sale
- FOR sale : 92 stelth es
- valve adjustment
- 92 Stealth es DOHC non turbo, Starts and dies, Clicking noises
- wheels and tires
- DRIVER POWER SWITCH
- Replaced ecu, now may need mfi relay?
- does anybody know where i can get a motor
- interior customization
- son's 92 r/t running now after 7 weeks
- Stealth Service manual
- door sensors and rear wiper switch
- Customizing
- Wiper Fluid Fix
- Automatic Stealth has trouble shifting
- 92 r/t still won't start ecm rebuilt by ecmtogo
- no fuel to engine
- injector problems...
- Needing turbo
- 1992 Dodge Stealth R/T Transmission problems
- Looking for a bra for my 94 stealth
- ES from Holland with troubles
- 91 Stealth SOHC wont start
- which turbos?
- upgrade
- wing removal
- non turbo dohc v-6 superchargers or turbo kits
- Performance Chips/Modules?
- What seats fit my new stealth?
- NEED TRANSMISSION FOR MY '91 TWIN TURBO
- Trying to Remove Tint
- jdm motors/who's done non-t dohc????
- 92 stealth r/t and jdm motor won't start help
- Turbos
- dodge stealth steering wheel
- sohc ecu
- HEMI BABY
- TCU
