PDA
View Full Version : Dodge Stealth
Pages : 1 2 3 4 5 [6] 7 8
  1. Gettin Preped for the Stealth World
  2. Engines being replaced frequently?
  3. 93 stealth problem
  4. Not Turning over
  5. Weird Noise
  6. Low Beam?
  7. vic system
  8. 92 stealth for sale
  9. Quick Question!
  10. what RPMs should i be at?
  11. 3sx long headers.
  12. Might be buying Stealth
  13. Tour/Sport light flashing?
  14. What muffler should i get
  15. Engine temp sensor or coolant temp sensor
  16. Stealth Clutch Play - 'loosy goosy' on hot days?
  17. strut bar, weard fit? help asap
  18. TOPS OUT AT 120mph
  19. 130+ MPH
  20. MUFFLER HELP plz
  21. Door replacement
  22. 1992 stealth rt/tt
  23. Door Panel
  24. 1995 Stealth engine swap
  25. 92 Stealth TCU Auto trans
  26. what size muffler and test pipe?
  27. 96 stealth input
  28. Srt4 stock Rims on my 92 Dodge Stealth?
  29. Hi my name is Joe and I'm a new member. I'm hoping you can help me.Auto trans in 2nd gear
  30. my budget stealth: stage log
  31. box connected to bottom of stock intake tube
  32. A few questions
  33. Exhaust system Question
  34. One more question
  35. Please Someone Help!
  36. Hi all new member with a couple questions
  37. 3000 gt vr4?
  38. Stuck In 3rd
  39. Stuck In 3rd
  40. computer chip upgrades
  41. no check engine light, but still problems
  42. Idle problem fixed
  43. breather filters
  44. Transmission Problems
  45. looking to get HKS Universal Muffler
  46. K&N Fuel Injection Performance Kit VS. HKS Super Mega Flow Intake System
  47. Good stealth aftermarket spoilers
  48. is it bad to drive w/out timing belt covers
  49. looking at after market oil catch reservoir tank/overflow radaitor tanks..few q's
  50. Fuel Filter??
  51. White Smoke, losing Oil
  52. Need help on built in visor lights on Stealth TT
  53. projector headlights for 91 to 93.
  54. Basic Idle Speed Screw
  55. HELP!!! Help me help my friend.
  56. speedfreakracing.com
  57. Throttle Position Sensor
  58. 1992 twin turbo engine ticking
  59. Transaxle Lock.... Help!
  60. Alabama Stealth Gathering
  61. powerwashing valvecover/plemum
  62. My ride!!
  63. looking for new brake pads, some other stuff
  64. stealth fuel problem?
  65. Help deciding to fix or sell
  66. Cold Air Intake
  67. 93 SOHC owner new to the board with a few ?'s
  68. NA fuel economy...PWR vs ECO switch
  69. is this stealth worth it??
  70. Need advice on a repair shop
  71. Front end jumping/vibrating on acceleration
  72. Dodge Stealth TT Lifter Tick? Other questions too.
  73. Anyone want to buy a Stealth ES??
  74. Idle problem too
  75. Please Help. Idle Problem
  76. swapped questions
  77. 12 years later I got my Stealth back
  78. supercharging the beats im keeping/ the plans!
  79. Temp. Gauge
  80. Wheels
  81. Gas coming out of the tailpipe....need help from thestealth
  82. N/A exhaust leak?
  83. for sale?
  84. a few questions
  85. Just bought, Need some help
  86. Car not idling right
  87. Front and Rear for RT
  88. Shutting down - Help
  89. August Car & Truck of the Month!!!!!
  90. Eureka!
  91. COOLEST COP CAR EVER!!!
  92. Idle/Revving problem
  93. New Motor Mounts- '91 Stealth Base Model
  94. I have searched my butt off...help??Another trans question
  95. Suggested work to be done??
  96. 2 questions
  97. Stealth Windshield decal
  98. My God.
  99. Dual Exhaust
  100. Where did my horse power go ?
  101. What do you think about this stealth?
  102. 91 Stealth ES ?
  103. parting out
  104. Fans not working right
  105. Back on the planet
  106. First Stealth problems
  107. ES/RT Models
  108. The Stealth Experience
  109. need to find a part quick
  110. I'm just curious about the Transmissions
  111. someone explain this Please!!!
  112. 1991 ES erratic miss
  113. Complete Wiring Diagram for DOCH, NA
  114. Starting but is not ideling.
  115. In the business of buying a Dodge Stealth TT
  116. car trouble 1992 dodge stealth es dohc
  117. Possible Purchase...R/T Twin
  118. Need Help ASAP
  119. just courious
  120. PLEASE HELP! 91 Dodge Stealth ES wont crank!
  121. Bad luck
  122. alright help me out here need support
  123. Changing spark plugs/wires...
  124. Value
  125. engine probs??
  126. Stock alloys sitting around???
  127. For thestealth: Plenum spacer help
  128. Paint codes help please!
  129. 3000gt and stealth question
  130. Stealth Buy need your opinion
  131. Upgrade Wheels and Tires
  132. Water leaking, engine running hot....
  133. transmission
  134. anyone know of a stealth for sale.....-
  135. weatherstripping
  136. Ball Joints
  137. July Ride of the Month Voting!!!
  138. Buying Dodge Stealth advice
  139. eBay rip off
  140. a/c problem
  141. boost control
  142. A few ???'s
  143. ECM keeps burning out
  144. Hello, I need help....
  145. Door Panel
  146. Transmission questions
  147. idling high
  148. Red 92 Wont Start - Sort of
  149. Mitsi to Dodge Conversion
  150. i need help!
  151. June Ride of the Month Voting!!!!!!!!!
  152. built in head lights
  153. 1992 STEALTH R/T PROBLEM
  154. New motor cranks turns no spark
  155. Need help with fuse box
  156. Problems with MY RT
  157. NA to turbo
  158. cold air intake
  159. Engine comparison...
  160. tranny problems?
  161. got 7k to spend on stealth!
  162. Can't seem to fix the problem
  163. Are these Stock Rims?
  164. A weird sound...help please.
  165. Hi New Guy Here need some help
  166. Small Problem/need Advice
  167. big problem with 92 stealth
  168. do i need a rebuild?
  169. i'm looking to get a stealth....
  170. what web site is good to order a DOHC stealth or mitsibishi engine from?
  171. will a mistibishi DOHC fit in a stealth 94 sohc ??
  172. Buying a Stealth
  173. PLEASE HELP BACK GLASS!!!!!!!!!
  174. DOHC ?
  175. Looking for a back intake censor
  176. Mega squirt vs Teck3 on a sohc
  177. 1st gen rt head lights
  178. 92 Dodge Stealth R/T
  179. Rear Wheel Studs
  180. Transmission question
  181. new paint? need opionions
  182. Did 1992 Dodge Stealths base models have spoilers?
  183. May Ride of the Month Voting!!!!
  184. Whistling Noise
  185. Exhaust question
  186. Getting a Dodge Stealth
  187. newb questions about turbo stealth
  188. to good
  189. despirate need of a swap!!!!!!!
  190. Dodge sealth base!
  191. Confused
  192. YOUR ATTENTION PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!
  193. stalling
  194. Need Opinion
  195. 92 ES probs with start-up
  196. turbonator
  197. 06 honda civic vs stealth 92 es
  198. 91 stealth problems..... help!
  199. I need help with my new Stealth
  200. Hooking up a BC
  201. Belt Manuals
  202. can a stealth do a burn out?
  203. no oil pressure
  204. Help Please
  205. runs like crap
  206. will not "crank" for a while ???
  207. will 93 trans fit in 91 stealth?
  208. overdrive quit working
  209. April Ride of the Month Voting!!!!!!
  210. '92 Dodge Stealth ES
  211. Still not doing anything!!!!!
  212. UPDATE NEED HELP
  213. I found a few worthy stealths!
  214. Custom Exhaust
  215. antifreeze leaks from around the crankshaft belt area
  216. Becoming fond of the stealth
  217. Clutch/Cruise Control Question. Seat Belt Question.
  218. wobbiling if thats how you spell it
  219. poping from under front end
  220. TCU Question
  221. NA Upgrade Bible
  222. Aftermarket Stealth/3000gt
  223. Question
  224. Plastic molding removal
  225. Steering rack leak???
  226. New to Site, 92 ES tranny problem
  227. TCU Problems
  228. 92 DOHC Non Turbo Idle Problem
  229. stealth work
  230. Stealth won't crank/start
  231. I need a Used Throttle body for a '92 Stealth
  232. help with 92 es stealth
  233. whats wrong with it?
  234. Antifreeze leak
  235. Blow-OFF Valve
  236. FS: TD04HL Turbo (not 9B like previously thought)
  237. hot rod tips?
  238. i want parts
  239. Where can i find a cold air intake for my car (stealth es 93')?
  240. cv axle still coming out HELP
  241. new to stealth RT
  242. Camshaft Pin Broke ???
  243. 3000GT/stealth Lower intake manifold Port and Polishing Services! check out what i have to offer!
  244. cv axle slipping out
  245. Turbo boost controller and blow off valve
  246. need help
  247. White Smoke
  248. Ticking sound.
  249. What engine options?
  250. You want a Monster Motor? At the best price? Check out What I have to offer! 3000gt/stealth
