View Full Version : Dodge Neon
Pages :
1
2]
3
4
5
6
7
8
9
10
11
12
13
14
15
- Size of spark plug socket
- I Require Assistance, Manual Transmission 2.0L Dodge/ Throttle Cable Replacement
- signal lights
- My expansion tank bubbles over
- 2000 neon lag
- Aloha car no go 2000 neon
- 2002dodge neon won't start
- 2004 neon no compression
- Rear Brakes Locked Up !! Help!!!!!
- right rear wheel locked up
- EVAP canister hoses
- Engine surge and headlights flickering
- 1998 Dodge Neon overheating
- 2002 dodge neon cutting power to the engine
- Heellp !!
- my 2004 dodge neon temp gauge slowly goes up when im at a red light or stop
- 01 neon no spark
- 2005 Neon Computer Problem
- 2.0 head swap
- 2001 Dodge Neon; No Crank no start
- having problems
- 2000 neon heater blowing luke warm
- compatible years?
- "Humming" sound while driving.
- P0505 code 1998 neon HELP
- 2004 neon se no start no crank
- PCM Issues 95 Neon
- DOHC Motor rebuild start-up tips
- 1998 neon window wipers fuses
- Gear Shift Light Bulb won't come off
- Getting Neon M/T looking to put some horses on it
- 2005 Neon with Engine Trouble
- 2000 dodge neon codes 1 and 152
- 2003 Neon 2.0 code p0204???
- Wiper trouble
- transmission as a jack point?
- Heater dial difficult to turn
- Would srt4 body parts fit on my sxt its a 2005
- Help with a Field Service Manual for G1 Neon?
- 02 neon
- fuel problem leading to bad acceleration?
- New Dodge Neon
- 2001 Neon Rear Drums to Disks Converstion
- 2004 Dodge Neon SXT 2.0
- MULTI FUNCTION SWITCH TURN HEADLIGHT WIPER Dodge Plymouth Neon 2005
- 2002 dodge neon
- Why turbo hood and spoiler on non-turbo car?.
- Problem with A/C & Heat dials on 2003 Dodge Neon SXT
- Where is the fuel pressure test port on 2005 Neon SXT?
- 2000 Neon electrical system
- 2002 Neon issuse help please
- no power.
- Occassional problem starting - Engine Light - Followed by problems accelerating
- 2003 Dodge Neon SXT Over heating?!?!
- Did my new post get eaten or dicarded by mods?
- Oil on The Threads Of one (1) Plug
- 02 Neon overheating
- occasional spit and sputter
- 97 neon no power to interior fuse box
- False? Overheating Indicator Warning
- Building car
- Looking for a long block
- Dodge Stratus , Neon ecm,s the same ???
- help, afraid to drive
- Sharp chrome LED Tail Lights for Dodge Neon
- 2004 Neon wipers won't stop running
- Moparnut228's Neon SRT4 on the DF Front Page!
- 2000 dodge neon shift solenoid
- 2005 Dodge neon sxt 2 problems
- Help! Car shifts but won't go over 2500 Rpms
- 05 Neon SXT 2.0 Overheating, P0300 P0303 and P0304. Runs rough at start
- over heating issues
- New here , need a honest question answered
- Gas leak near passenger rear tire
- Engine Swap Time
- Dodge neon cuts off while driving
- 2003 Neon R/T Cat back question
- 2000 Neon Dash Removal for heater core
- Problems with brake light
- neon coil pack getting hot
- Air conditioner
- 2004 Dodge neon sxt won't start
- p0700 code
- 98 Plymouth Neon dashboard
- 2001 nrt
- neon, valve ticking
- 99 neon fuse 22 for a/c always burns
- Shifter Cable Spare Parts. (?)
- 05 Neon Fog Lamp Wire
- 99 DOHC valve cover removal
- 2004 no crank when hot?
- Broken Wheel Stud
- Lukas Fuel Injector Cleaner
- Hood question
- ECU Replacement Problems and Questions.
- ILoveHID Sponsor Special 20% off all items for Dodge Neon Forum Members!
- Dodge Neon 2003 Acceleration Problem
- New Here so be nice! Please help
- Battery light on, not charging. HELP!
- stereo system 98 dodge neon
- door ajar and doom light
- 03 Dodge Neon got me stumped
- Neon 2003 - Auto Transmission leak
- what sensor is this?!?
- Oil leak coming from starter area!?
- 2002 dash speakers
- Rear Brake Conversion
- My Stage 3 just won't go
- Timing Belt, WP, Tensioner Service
- '04 Neon, daughter hit snowpile
- 2003 Dodge Neon Blowing Wiper fuses
- Charging Problem on 2004 Neon SXT
- 1999 dodge neon coupe questions
- ignition cylinder bracket damaged by thief
- New Member, shaking issues while car is idling
- 04 SXT, Automatic. Broken shaft selector on trans. repair advice?
- i need helpppp
- Where to buy new or used factory 2.0 R/T piston
- Can't get codes - 2004 sx 2.0/Neon
- Gen 1 1998 Neon
- 700$ to replace belt tensioner?
- Heater Not Getting Hot
- running rough
- 2004 SX 2.0/Chugging + Engine & Oil Lights
- Have 2000 Neon sohc 2.0. What other years will this engine fit w/o modifying things?
- 98 Neon security light keeping car from starting
- car wont start...freaking cold
- 2005 dodge neon Limp Mode
- 05 dodge neon struggles to start
- finally took it to mechanic
- 2.4 l dohc compatable with 2.0l neon
- 4 disc changer 2 lights blink then other 2 lights blink, then repeats??
- need help please with 2005 neon sxt
- Spark plug wires
- Bigger throttle body
- almost cold heat wierd idle and oil light
- running really rough
- 03+ front end swap on 02?
- 2004 Dodge Neon won't reverse and jerks hard when shifted to drive (automatic trans)
- the car wont drive for more than 15 min
- Neon automatic tranny troubles
- Removing hazing from headlights
- How long...?
- Dodge Neon 2005
- Im back.. same Neon more issues.. R/T
- engine swap from 98 plymouth neon to 98 dodge neon
- P0117 even with new temp sensor
- transmission problems
- Need Help from Dodge Experts !!
- How to make a neon fast
- CV shaft removal
- battery heater
- Cat vs dual
- 2004 dodge neon
- Do 2001 dodge neon bodykits fit 2001 plymouth neon
- Motor Oil In My Radiator
- ac/heater blower not working
- Bad Vibration / Grinding when cold and accelerating
- strange starting problem on an '04
- PLEASE HELP!! 2005 Neon SXT
- 02 neon auto bucking when slowing to 5 km
- 02 neon auto bucking when coming to stop
- Dodge Neon - No Reverse
- Dodge Neon R/T Front Bumper Wanted
- P0300 & p0351
- Dodge neon 96-99 need advice
- Wipers, A/C and horn switch crossover
- compmression psi
- coil pack eltrical hookup
- Simple to find, or??????
- RPM dropping
- High Idle
- Replaced tranny on 2001 Neon, now won't shift
- how are you guys making 17" rims fit on your neons?
- 05 Neon SXT Manual Trans Slips Out of Gear at 2300 rpm
- Ok Flustered Reaching for help.
- 03 Neon won't start
- fog lights not working
- Hard starting
- 03 SX 2.0 Hesitation
- Student - Neon Problems
- 2000 Dodge Neon engine stutter around 2000rpms on launch and shift to second gear
- Range Sensor harness wire colors?
- Rear end whine
- Connecticut neon owners
- '01 Neon Cruise Broken
- dodge neon miss please help
- For Sale 2005 Dodge Neon SRT-4
- 05 Neon strange clunk/thump sound right before final "stop"
- 03 Neon Sxt Body kit
- running rough
- Need Help with a 2000 Dodge Neon
- 95 neon burning PCMs
- I need help ASAP
- HELP, When should this fan engage? At what temperature?
- Need a body kit
- 1999 Neon died, won't restart
- 2003 neon sxt starting problems
- 2001 neon rt starting problems
- Rally onboard video New England Forest 2013, Chris Greenhouse SRT4
- Boost and misfire issues...NEED HELP!
- 2000 Neon Hood Locking Striker
- 2000 Neon P1490 - Chasing the Fault
- A/C question....
- Double din neon bezel
- Problem with proper cooling
- 2.4L vs 2.0L how mush rpm will the 2.4 take?
- 2003 Dodge Neon sx 2.0 p0700 code and symptoms
- 2001 Neon Running Hot
- 2000 Dodge Neon Loud Noise Help
- No A/C
- muffled sound
- 97 Neon Charging Trouble
- srt wiring issue
- voltage reading
- Please help! Head Gasket vs. Radiator Issue?
- 2005 dodge neon, blowing my mind
- No start
- Can't figure out this problem! HELP!!!!
- My Neon won't start
- 2005 Neon input speed sensor circuit
- oil light
- engine swap
- brake line help!
- Parts pricing through the roof?? What happened??
- sx 2.0 won't move in gear
- Oil Change
- Rally onboard video STPR 2013, Chris Greenhouse SRT4
- New to this and need help on a 2004 Dodge Neon R/T
- Remove or keep spoiler on?
- 2001 Nean whining noise
- Neon convertible?
- Strange, No Crank/ Turn over
- neon problems please help
- 2000 neon weatherstripping
- Exhaust inlet/outlet size
- Humming sound when I turn fast
- dodge neon
- low voltage
- I cant figure out how to unplug the driver door harness from IP harness
- Won't start, cranks, no spark. Please help
- auto to maunal swap 2002 dodge neon
- Hole In Back Of Coolant Tank
- Replacing Battery Cables
- 420a?
- 2005 Neon Cam position sensor problem
- 2003 Dodge Neon SXT: jerking
- 98 Neon HID Flickering and outage
- P0172 P0456 Trouble Codes 2000 Neon
- 99 Neon right side engine fan
