PDA
View Full Version : 2008 - Current Dodge Avenger
Pages : 1 [2] 3 4
  1. 2008 Dodge Avenger throwing code P0301
  2. Oil pressure light
  3. 2008 dodge avenger 4cyl window acuator
  4. Windshield Sprayer Low Pressure
  5. 2010 Dodge Avenger SXT A/C Problems
  6. Cant open door
  7. 2010 Avenger SXT overheating
  8. 2009 Avenger Hazard lights not working
  9. 2010
  10. 2011 Dodge avenger trunk wont open
  11. 3 alternators replacements
  12. P2016 Dodge Avenger 2008 / Mannifold Runner Position
  13. From SE to R/T
  14. 2009 Dodge Avenger Sxt 2.7
  15. New and looking for advice/opinions
  16. Dude, what year is my car?
  17. Cam/crank position sensor locations
  18. Won't start with weird symptoms
  19. 2008 Avenger Starter Replacement
  20. Key doesn't turn
  21. Radio Help
  22. ac/ heat not blowing
  23. traction control light is on
  24. Fuse for Rear Defrost
  25. Stubby Antenna
  26. Weird brake issue?
  27. Fuse for anti-theft
  28. Dodge Avenger sxt 3.6L exhaust
  29. Heater Blowing Cold Air -2008 Avenger
  30. 2013 Dodge Avenger Hissing Sound
  31. Reliability 2008-2010 vs. 2011-2014
  32. Input/Output speed sensors
  33. Can I connect a 2pin motor to 6pin harness??
  34. 2011 Avenger heat
  35. Remove Map light housing
  36. Electrical issues!?
  37. Dodge Avenger help
  38. Green light under left side of drivers dash
  39. Looking for Dodge Avenger Weather Tech Floor Mats
  40. Interior lights
  41. 2009 Dodge Avenger 4cyl Reving issue
  42. No Crank no Start
  43. Radiator Fans wont start-2009 Dodge Avenger
  44. Wrong time
  45. Alternator replacement
  46. Unidentifiable Liquid
  47. popping from the air vents
  48. receiver question
  49. 2012-2013 Avenger Opinions
  50. 2013 v6
  51. Is the 2012-2013 year any good?
  52. 2012 Cruise control issue
  53. Help
  54. buy avenger 2014 SXT with price 20300 or wait for avenger 2015 model?
  55. oil pan gasket help
  56. 2008 Avenger 4cyl P0017
  57. need help with your avenger i do
  58. 2008 Avenger with 2.7L
  59. AWD! Light on dash
  60. Transmission issue send help
  61. need help ASAP
  62. Tune Up
  63. 2008 avenger SE oil leaking
  64. Thermostat housing leaking again!
  65. Electronic Throttle Control
  66. 2013 led lights
  67. 2013 Avenger blend door actuator replacement
  68. 2008 R/T AWD (performance parts)
  69. Brown gel in coolant bottle...2013 Avenger
  70. Calibrate Recirculation Actuator
  71. 2012 Avenger Blend Door Actuator
  72. RPM Rev limit?
  73. 2008 dodge avenger rt all wheel drive
  74. 2008 Dodge Avenger Crankshaft Pulley
  75. oil light keeps coming on when oil level is fine
  76. 2012 Avenger side mirror
  77. Loud?
  78. 2010 Avenger r/t blower motor
  79. 2014 Speaker Issue
  80. my 2014 3.6 had no traction
  81. Dash displays are out
  82. 20 second high pitch beeping when turning car to on postion
  83. in desperate need
  84. avenger
  85. Installing a Backup Camera
  86. 2013 Avenger Passenger Front Fender Wheel Well Splash Guard Needed
  87. 2012 Avenger Trun Signal Assembly
  88. P2077 - Intake Manifold Tuning Valve Sensor
  89. think i have the wcm problem
  90. uconnect 130/730n radio
  91. weird clicking sound on idle
  92. interchangeable parts
  93. Speedometer, heat gauge and fuel gauge stopped working
  94. Check engine light
  95. I need help!!!
  96. A/C leak into passenger floor carpet
  97. oil catch Install
  98. pdf of shop manual 2013 avenger
  99. Perfect roof racks for Dodge Avenger 2014
  100. Tire Pressure Sensor Issue
  101. 2010 Avenger R/T brake upgrade
  102. Interesting Rear Spoilers for Dodge Avenger 2011-2014
  103. 3.6 vvt owners
  104. 2011 Avenger 3.6 engine light
  105. Map light replacement
  106. Front seat bolt location
  107. Removing the door panel on an '08
  108. 2008 Avenger oil pan removel
  109. Oil Catch Cans
  110. Hood Adjustment
  111. Dodge Avenger - Stuck in park...
  112. AC condensation drain line clogged
  113. Bluetooth kit?
  114. 2008 Avenger SXT - Key Programming Issue?
  115. Used 2010 Avenger
  116. Help! Warranty just expired, 100km later bad things happened
  117. door not locking window not rolling down
  118. 2008 Avenger - Fuel Door Repair
  119. Radio issues
  120. 2010 Avenger temperature gauge
  121. 2008 dodge avenger cluster flicker
  122. In Dash Power Outlet Not Working
  123. Center console coin tray
  124. brake pedal - clicking noise. please help!
  125. p2112
  126. 2010 Dodge Avenger Doors
  127. Uconnect 130/res
  128. 2008 avenger sxt
  129. How do I replace the driver sideview mirror unit?
  130. Need HELP!
  131. Problems with car?
  132. 2010 dodge avenger
  133. P0700 Error
  134. 2008 dodge avenger passenger head light low beam won't work
  135. Neutral Safety Switch
  136. 2010 Avenger Ticking noise when unlocked
  137. Avenger OEM remote start install
  138. ETC and heating problems
  139. Low Voltage Codes, can't find cause?
  140. 2008 sxt battery and labor cost?
  141. Fuel milage up grades for 2012 Avenger?
  142. 2008 avenger door sensor?
  143. 08 Avenger washer pump question
  144. Transmission Issues
  145. 2011 Avenger rear end issue
  146. Front passenger wheel fell off 2008 Dodge Avenger
  147. 2 Questions about a 2012 SE
  148. Problem with windshield wipers on my 08 Avenger
  149. caliper bolt
  150. 2008 Avenger Cabin heat issues
  151. Daytime running lights
  152. Trunk Light
  153. 2011 engine replacement not staying cool
  154. Oil Light "flickers" at idle
  155. 2008 avenger
  156. MIL light is on
  157. MIT Light is on
  158. 08 Avenger right tail light
  159. 2008 Avenger
  160. 2008 avenger
  161. 08 Avenger - Door Issue
  162. Handbrake cable adjustment
  163. 2011 Dodge Avenger loosing power going up hill
  164. My 2010 Avenger R/T has SXT rear disc brakes?
  165. 07 dodge avenger air bag light on
  166. 2010 blower motor resister location?
  167. Avenger handling problem. Suspension or tires?
  168. 08 sxt vibration from 55-70 popping in front when I go slow
  169. 2011 Avenger Front Fender
  170. repair from a certified body shop void warranty?
  171. 2008 Dodge Avenger Se tail lights, side-front turn lights, and dash board lights stop
  172. Need to buy black grill(crosshair)
  173. Transmission Help
  174. 2011 avenger A/C help!
  175. Sun roof drain tubes leaking
  176. 2011 ac not cooling but has pressure Help!
  177. Had her tinted
  178. Here is my Avenger
  179. Water in trunk lid???
  180. Impossible Firewall Pass-thru?
  181. a/c compressor runs constantly
  182. Halo Headlights.
  183. 09 Avenger trans problem, no codes
  184. mis
  185. 2008 avenger
  186. 08 Dodge Avenger Braking System Problems
  187. torque specs
  188. torque specs
  189. Fog, Park, and Interior Lights will not turn off!!
  190. Repair/Service Manual
  191. center brake light burns out on 08 avenger
  192. 2008 Dodge Avenger 2.4 engine-- Engine lights STAYS on--NEED HELP!
  193. Bad Wheel Bearing?
  194. Driver's Window Fell Down
  195. Seat belt light
  196. hydrolocking
  197. avenger code p0700 and p1775
  198. No Start Issue...
  199. Swapable engine and tranny???
  200. 2013 Avenger USB problems
  201. 13 Avenger USB problems
  202. 08 Avenger Turning over several times before starting
  203. Gator
  204. Gator
  205. 12 avenger radio wont play from ipod
  206. 2013 Avenger 2.4 vs 3.6
  207. Static Radio 2013 Avenger
  208. po 0013 on 2008 dodge avenger 2.4
  209. 08 2.4L question
  210. Coolant temperature sensor
  211. 2011 Dodge Avenger remote Start
  212. Front closure panel
  213. 2013 Avenger Help!!!
  214. Rear Struts
  215. Quick squeak or squeal
  216. need correct speaker/install help
  217. Falling door seal
  218. 08 dodge avenger
  219. 99 Aveng stalling/idling issues
  220. 2013 avenger shut off noise
  221. 08 SXT - whines, struggles for power, shudders, and stalls
  222. Install for Tint, DVD PLAYER AND REMOTE STARTER IN ATLANTA, GA
  223. dvd player
  224. dvd player
  225. In dash system, Remote Start and Tint
  226. Uconnect Update
  227. Where is number 6?
  228. Grille removal
  229. a/c inoperative
  230. 2008 Dodge Avenger door will not stay latched swigs open by self
  231. Heater is out of control.
  232. Radio Failure (08 Dodge Avenger)
  233. Replacing Windshield Wipers 2008 Avenger
  234. 2011 Avenger Hood Issue
  235. 2009 Avenger....running/parking/tail lights stop working
  236. Engine knocking but no codes
  237. 2011 dodge avenger coolant help
  238. Replacement key or fob and alarms
  239. Over heating 2008 dodge Avenger
  240. Check Engine Light and DTC
  241. 2008 Dodge avenger CHECK ENGINE LIGHT STAYS ON!
  242. Power Seat Failure
  243. CAN Interface question??????
  244. 2008 Avenger starting/stalling
  245. A/C Recirculation acting up
  246. Passenger door window cable off or broke
  247. VIN number and engine number
  248. 2012 Dodge Avenger R/T U Connect System issues
  249. 2009 dodge avenger sxt. sell or keep????? 76K MILESHELP =/
  250. Alarming question
